neptune question
Old Sep 16, 2008 | 05:26 PM
bertsb18hatch's Avatar
Default neptune question
im getting my car dyno tuned on the 27th and i have a question. im getting it tuned on all motor, then nitrous. my tuner said i could use neptune to switch maps from motor to nitrous. the car is a 91 civic hatch with built b18a1 converted to obd1. the tuner said i have to hook up a toggle switch so when it is flipped it will switch maps. can anyone help me on what to do?
Old Sep 16, 2008 | 05:51 PM
HRTuning's Avatar
Default Re: neptune question (bertsb18hatch)
The switch has two pins. If you're using a grounded input (You should), one goes to ground, the other goes to the ECU pin you want to use as an input.
Old Sep 16, 2008 | 05:56 PM
Default Re: neptune question (HRTuning)
so the plain toggle switch i have with the two prongs on back, one gets grounded and one runs to whatever i hook it up to? my tuner said something about the vtec pressure switch wire. so i would connect that wire coming off my jumper harness, to the other prong of the switch.
Old Sep 16, 2008 | 08:12 PM
Dartanian's Avatar
You can connect it to:
B5 (AC Switch)
B8 (Power Steering Pressure)
D6 (VTEC Pressure Switch)
D4 (Service Connector)
D2 (Brake Switch)
B9 (Starter Signal)
Old Sep 16, 2008 | 10:28 PM
HRTuning's Avatar
Default Re: neptune question (Dartanian)
B5 (AC Switch)
These are all grounded inputs.
malcolm2
Jul 27, 2023 04:21 AM
B18EG6
Jul 23, 2008 01:03 PM
Threads
11
Jun 28, 2006 04:52 PM
morepoop4u
Mar 14, 2005 04:07 PM
