throttle position sensor
Old Oct 11, 2008 | 06:36 PM
dhdave2509's Avatar
Default throttle position sensor
hi got a bigger throttle body for my b18 and need to know how to set my throttle position sensor. i've been told i need to use a fluke to get the correct readings at full/half/no throttle. can anyone point me in the right direction on how to do it properly. thanks in advance
Old Oct 11, 2008 | 09:40 PM
Tomdata's Avatar
Default Re: throttle position sensor (dhdave2509)
set the TPS to 0.5Volts on the signal wire @ closed throttle with the key on and the engine off. Thats all you need to worry about. Make sure the TPS is adjusted after the final throttle stop screw adjustments are made on the new throttle body.
Old Oct 12, 2008 | 12:53 AM
dhdave2509's Avatar
Default Re: throttle position sensor (Tomdata)
cheers mate i'll give that a go
Old Dec 7, 2008 | 12:38 PM
TheREGULATOR's Avatar
Can you expand upon that please?if you adjust the TPS after its been set to .5 closed, wont adjusting it after that change the readings? Thx
=[REG]= ARRR
Old Dec 7, 2008 | 06:53 PM
mtber's Avatar
0.50 100% closed and 4.5 100% open (If memory serves correctly).
Old Dec 14, 2008 | 02:34 PM
b20beast83's Avatar
Which one is it?
.45 or .5?
Mine is set .45V and TPS in Freelog Reads -2%
Old Dec 14, 2008 | 03:54 PM
mtber's Avatar
Originally Posted by b20beast83
Which one is it?
.45 or .5?
Helms says .5 so go with .50 :-)
Old Feb 17, 2010 | 11:18 AM
huarachez33's Avatar
New User
where can i purchase a throtel position sensor for a Honda Civic Lx... nobody seems to carry it.. if any one knows a site or even a store around Los Angeles
Old Feb 20, 2010 | 08:15 PM
boosted 528's Avatar
Goto a local u-pull it yard
Old Feb 20, 2010 | 08:59 PM
GhostAccord's Avatar
There are approx 170 of them for sale on ebay. Or you could go to your local junk yard as mentioned. It doesn't have to be one from an LX Civic. Any Honda & Acura throttle body that uses a 3 wire TPS are the same .5v - 4.5 (5v) sensor. (potentiometer)
elynen
Honda CR-V & Element
May 25, 2018 10:51 AM
TwoKSiR
Mar 25, 2008 11:11 AM
dmingis
May 28, 2005 09:25 PM
GSRcivicGSR
Dec 20, 2004 04:29 AM
Redsim
Jun 11, 2003 09:37 PM
