boost by gear on neptune?
Old Sep 28, 2008 | 05:56 AM
dart2.2's Avatar
Default boost by gear on neptune?
just sent my rtp out to get it ready for the pwm setup so i can run mac valves for boost control. my question is how does the ecu see that you are in a certain gear. i have a dss spool an there is no vss gear so i have a bracket made to run the vss off the back brake drum. does this work or does the vss need to read something that spins faster like the half shaft? thanks for any help.
Old Sep 28, 2008 | 07:58 AM
mtber's Avatar
Default Re: boost by gear on neptune? (dart2.2)
You must set your gear ratios & use a speed sensor for the ecu to know what gear you are in to use boost by gear.
Old Sep 28, 2008 | 08:06 AM
HRTuning's Avatar
Default Re: boost by gear on neptune? (mtber)
Like John said, pick your tranny in the gear correction section. You'll notice while datalogging that the data window has an item for gear which tells you what gear you're in.
Old Sep 29, 2008 | 05:30 AM
dart2.2's Avatar
Default Re: boost by gear on neptune? (HRTuning)
like i said i have no ring gear for the vss, so is running the vss off the rear brake drum acceptable place to put it. what would you recomend for this situation?
Old Sep 29, 2008 | 07:38 AM
HRTuning's Avatar
You'll have to try it. I don't have a recommendation, you're the first.
onlinehost
Dec 28, 2011 12:03 AM
JBLAZE622
Oct 10, 2008 12:42 AM
Sinner
Aug 20, 2004 06:35 AM
speed
Nov 29, 2002 07:01 PM
Etylorcen
Nov 15, 2001 11:24 AM
