wire tuck help please!!!
Old Oct 15, 2008 | 02:10 PM
notmightydx's Avatar
Default wire tuck help please!!!
okay i just finished up the passenger side wire tuck. relocated battery to trunk, and fuse box found a newer home in glove box. heres my only problem. the battery light on guage cluster is on. i ran 4 guage wire from battery to starter, and 8 guage from battery to fuse box in dash. i maid sure to mark the 2 main 8 guage wires going in to fuse box so im pretty sure there connected properly. only thing i can think of is to try a different grounding point. any advice please....
Old Oct 15, 2008 | 05:23 PM
postman's Avatar
Default Re: wire tuck help please!!! (notmightydx)
chargeback wire from alternator issue maybe
Old Oct 16, 2008 | 04:50 AM
well i spliced the wire into the original one. im gonna grind down my ground spot. and then check all connections with a voltage reader. thanks
Old Oct 21, 2008 | 08:00 AM
almostjdmeg's Avatar
Default Re: (notmightydx)
Will your car not start? I did mine last night and i cant get it to start, i turn the key and nothing happens except my battery light goes dim.
evilho75
May 13, 2012 01:35 PM
notmightydx
Oct 16, 2008 06:55 PM
philkehn
21
Jul 5, 2006 08:29 PM
slowone
Mar 11, 2004 03:53 PM
