crome problems
Old Sep 21, 2008 | 11:51 AM
Boostdc4's Avatar
Default crome problems
car is 94 integra
b18b1 turbo
ecu p06
running a p30 map
tuned running great
went to add rev tools to put on boost cut and lauch control
soon as i add it the car shuts off CEL comes on and if i try to start it the cel stays on and the fuel pump wont shut off
any ideas ?
Old Sep 21, 2008 | 01:09 PM
98vtec's Avatar
moderator emeritus
Default Re: crome problems (Boostdc4)
dont add plugins with the car running.
rev tools does not add boost control or launch control
add extra features
boost tools
Old Sep 21, 2008 | 07:20 PM
Boostdc4's Avatar
Default Re: crome problems (98vtec)
i added it car runs but have a CEL still
code 19 Lock Up solenoid auto tranny
code 17 VSS
but i have a manual tranny so code 19 i dunno?
and VSS works fine
load on old map and no codes
Old Sep 21, 2008 | 07:38 PM
mtber's Avatar
code 19 is due to you needing to remove rp18 and rp17 from the ecu and jumping rp18 with a 0 ohm jumper
VSS may have to do with your speedo not working ?
Old Sep 22, 2008 | 08:23 AM
Relic1's Avatar
I'm guessing the car was tuned on an earlier version of Crome, and the updates were on a later version. Pre-1.4 is not compatible with post 1.4
Old Sep 22, 2008 | 05:20 PM
Tomdata's Avatar
Default Re: (Relic1)
To sum up all of the advice so far. You should get the latest version of crome. Add boost tools and any other plug ins you want before trying to start the car. Then make sure you don't have a VSS issue or a VSS wiring problem. Also it sounds like you are using an automatic ecu. If so you need to follow <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">code 19 is due to you needing to remove rp18 and rp17 from the ecu and jumping rp18 with a 0 ohm jumper</TD></TR></TABLE>
Then you need to retune the car all over again and you should be good to go.
Old Sep 24, 2008 | 01:32 AM
Boostdc4's Avatar
Default Re: (Tomdata)
i got it all working now thanks for the help
Old Sep 24, 2008 | 08:13 AM
Relic1's Avatar
and the issue was?
stc876
Oct 2, 2013 10:53 PM
jbiel
11
Jan 11, 2009 06:27 AM
jeffk182
Jan 20, 2007 03:27 PM
Gixxerboy02
Apr 30, 2006 01:16 PM
ophdehEEzY
Dec 16, 2003 10:28 PM
