base map for b20vtec??
Old Oct 7, 2008 | 06:26 PM
b20vtech's Avatar
Default base map for b20vtec??
need a base map for a stock internal b20vtec
motor is running on the lean side cause spark plugs are white *** ****
motor spec:
b16 head
gsr cams
jg edlebrock mani
OEM type r header
68mm tb
stock b20b injectors
b20b block untouched
help a brother out, before motor goes "BOOOoooM!!"
thanks in advanced
cityofcaterpillars
Engine Management and Tuning
Oct 3, 2016 11:35 AM
axavier23
Aug 29, 2011 07:05 PM
keving85
Sep 25, 2009 08:10 AM
b20vtech
11
Oct 8, 2008 02:25 PM
boostingisfun
Jun 8, 2007 08:48 PM
