neptune question.
Old Sep 18, 2008 | 06:02 PM
dart2.2's Avatar
Default neptune question.
so i can get the emulator connected on my rtp but i cant get any of the datalogging to work. ive uploaded the base code but the datalogging says disconnected. help please!
Old Sep 18, 2008 | 06:32 PM
HRTuning's Avatar
Default Re: neptune question. (dart2.2)
You're posting on the wrong forum, this belongs on the NepTune support forum.
Check your 4 pin to make sure it's on the correct way. Make sure J12 has been removed from the ECU. Make sure you have no check engine lights. Make sure you've chosen Start from the datalogging menu once emulator status says Connected.
If you have *no check engine light* and you've done everything else, try revving above 4000 RPM. If you hit a limiter the RTP can't communicate with the ECU. Check the 4 pin cable out again. It's either the CN2 header or the 4 pin cable at that point.
Old Sep 19, 2008 | 04:03 AM
dart2.2's Avatar
Default Re: neptune question. (HRTuning)
i have no check engine light, does not hit the rev limiter at 4000 rpm. the car has been tuned allready just trying to set up my antilag,2 step. could the cable be messed up? sorry for posting in the wrong forum. thanks for your help.
Old Sep 19, 2008 | 07:36 AM
HRTuning's Avatar
I doubt it's the cable. Your tuner had it working, right?
Old Sep 19, 2008 | 01:10 PM
dart2.2's Avatar
yes. servion was the one who tuned it. i know its working i think im doing something with the computer wrong.
Old Sep 19, 2008 | 01:30 PM
HRTuning's Avatar
Was he using an old version or did he use your laptop? If you're connected to the emulator all you have to do is select Start from the datalogging menu. It will change to stop and should be showing you data. It will either show you live values or 0'd out values, but it will show SOME values. If you see no values then it's nothing you're doing, it's not the hardware, and it's not the software either, since you're connected. There's been two cases of that scenario so far and there's absolutely nothing to be changed to correct it.
Old Sep 19, 2008 | 01:57 PM
dart2.2's Avatar
he used his laptop.i just connected to the emulator again to try and figure it out and i still cant get it to work. does the car need to be running?
Old Sep 19, 2008 | 02:16 PM
HRTuning's Avatar
No, with just the RTP board or if it can't communicate with the ECU it'll show 0'd out values. In a car with key on it will show live data.
Old Sep 19, 2008 | 02:19 PM
dart2.2's Avatar
it shows my fuel and ignition tables.
Old Sep 19, 2008 | 03:49 PM
HRTuning's Avatar
In the datalogging, which is what we're discussing here.
Old Sep 19, 2008 | 04:13 PM
HRTuning's Avatar
Close the edit window with the tables in it and try to download the base code. If it works and it's communicating fine, again, even if the datalogging to the ECU isn't working you should still see 0'd out values in the data window and gauges. If that's not happening, as I mentioned before, your laptop is having a problem getting the data to the software appropriately.
Old Sep 20, 2008 | 05:23 AM
dart2.2's Avatar
problem resolved. i downloaded the old version of the rtp and it started working. i dont know if it was a bad download or what but all i care is i got the data logging working. thanks for your help hrtuning.
Old Sep 20, 2008 | 07:45 AM
HRTuning's Avatar
No problem.
vr4twinturbo
Jul 25, 2017 07:57 PM
ElCivic89
Apr 22, 2012 09:02 PM
jw 1
Mar 14, 2009 10:39 AM
JustinG60
Mar 30, 2005 08:29 PM
linx
Oct 14, 2002 02:59 PM
