stupid annoying idle problem please help
Old Sep 21, 2008 | 12:18 PM
siregcivic's Avatar
Default stupid annoying idle problem please help
my setup consist of a 95 cx hatchback, with a 97 jdm itr swap, cold air intake, itr 4-1 header, 2 1/4 no cat with resonator and eg6 muffler, hondata intake mani heat shield, jg cam gears +2 on intake and -4 exhaust, valve lash set at .006 all around, all the coolant lines have been disconnected from the intake manifold including the iacv and looped back to the block
engine management is crome free 1.5 the problem im having is sometimes the car has a hunting idle, its annoying as [freak] and sometimes it causes the car to die, but it doesnt always do it, i have bled the coolant system a couple times theres no air pockets, i am also running no thermostat, sometimes it idles normal and sometimes it jumps around and is verry annoying since i have innovative 95a race mounts..
if anyone has a clue... the car does not have a fitv only the iacv
thanks for the help ive looked at everything
Old Sep 22, 2008 | 07:55 AM
siregcivic's Avatar
Default Re: stupid annoying idle problem please help (siregcivic)
wow...
also when i set my tps voltage to .65 closed it stops doing it, but when i set the voltage to .5 volts closed it does it
its [freak]ing annoying...
anyone have any ideas?
Old Sep 22, 2008 | 08:38 AM
98vtec's Avatar
moderator emeritus
your not running a thermostat? That would explain a lot in my opinion.
make sure your throttle stop is position appropriately. How are you datalogging?
Old Sep 22, 2008 | 03:05 PM
siregcivic's Avatar
Default Re: stupid annoying idle problem please help (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">your not running a thermostat? That would explain a lot in my opinion.
make sure your throttle stop is position appropriately. How are you datalogging?</TD></TR></TABLE>
i data log with freelog
rsa0905
Feb 27, 2010 07:01 AM
VTECchris
Nov 7, 2008 11:20 PM
90crxdriver
Jun 24, 2007 03:32 AM
4doortypeR
Mar 23, 2003 07:27 AM
Lysawy
Dec 10, 2002 04:46 PM
