adjusting cam gears
Old Oct 13, 2008 | 07:59 PM
JUNstageIII's Avatar
Default adjusting cam gears
i wish i can do things the right way by geting tuned on a dyno but i was wondering if any one would no a good cam gear setting besides 0 degrees im running a gsr head built with supertech velves jun springs and retainers jun stage 3 cams jun cam gears bottom end is a b18c1 block also with gsr crank and itr rods and pistons
Old Oct 17, 2008 | 02:53 PM
Jdc5's Avatar
Default Re: adjusting cam gears (JUNstageIII)
I belive it depends whether your looking for top end power which would be advance timing and bottom end power which is retarding timing. but for the degree i couldnt tell you.
sh4k3r
Jan 23, 2011 01:03 PM
nigel
Feb 9, 2004 11:20 AM
Ronin Panda
Oct 23, 2003 01:52 PM
Lord Quaalard
Feb 11, 2003 07:15 AM
MaxBoost
Jun 26, 2002 02:04 PM
