Idle air control valve
I installed a new idle air control valve on my 2001 Honda Civic LX and I’m still having idle problems. I am in need of it fixed what should I do next if anyone could help me please?
Re: Idle air control valve
Yes I have a check engine light and it is a manual transmission I just replace the idle air control valve and it still throwing a check engine light it is revving from anywhere from 1000 RPMs to 2 1/2 thousand RPMs
What is the check engine light code? P#### Check for vaccum leaks or manifold cracks. Make sure all fittings are corrosion free and all bolts are secure. Vape in the engine bay a little, see if it sucks fog in somewhere where it shouldn't lol
Somethings I suggest checking, if it is P0505 (Idle air control system malfunction)
>IACV or wiring to it
>Gasket leaks at IACV, TB, or intake manifold
>Carbon build up on TB or otherwise sticking TB
Thanks will look into it has soon has I get time off work . Sorry for the late response I am a busy person and forgot to get the code till last night.
OK so I have sent about two hours looking over wires and I did not see any thing wrong with any of them from the Engine bay, I made sure there was no carbon build up or sticking tb I just have not looked in to if the gaskets are bad, I will do that this week. Would a bad map sensor cause this issue?
I had to replace the intake manifold but that was it. I live in Phoenix,az and right now it is to hot for me to work on it when I can see and I do not have a work light so I would hate to take the intake manifold off to replace the gaskets in this heat.
Another method I have found scary useful is vaping into the engine bay and watching the fog move, that'll give away vaccuums as well.
Sounds like you have a vacuum leak from replacing the intake manifold.
https://www.youtube.com/watch?v=9CPqbaSgcok
LadySi2000
08-15-2013 06:39 PM
frostykue
03-28-2013 08:29 PM
