Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Starter problem?
Old Aug 22, 2018 | 02:08 PM
Zigory's Avatar
Default Starter problem?
Recently my car didn't start, thought it was a dead battery but the battery is fine. It now starts fine intermittently, when it doesn't if I leave the key in the ACC position for 10 seconds it will start, if that doesn't work if I depress the gas pedal halfway and wait another 10 seconds it will start fine. Is this a problem with the starter? Thanks for any info
Old Aug 23, 2018 | 05:31 AM
NDNV's Avatar
Default Re: Starter problem?
Check the fuel pump and fuel pressure.
Old Aug 24, 2018 | 07:20 PM
b3nma0's Avatar
Sounds like the fuel pump is going bad it should only take a couple seconds for the pump to send gas.
Old Aug 24, 2018 | 11:09 PM
alishrouf's Avatar
you need to check the fuel pump and sometimes the fuel injectors need cleaning
Old Apr 1, 2019 | 08:19 AM
Zigory's Avatar
Update: it was the starter, replaced it and haven't had any issues since. One hint was that hitting it with a wrench before replacing it helped the car start lol
lif3tak3n
Jun 24, 2014 06:00 AM
jefroa
Jan 20, 2013 12:04 PM
woodwardba0526
Apr 13, 2010 01:31 PM
jdavis94teg
May 12, 2009 09:28 AM
thatbluecrx
Jul 26, 2006 09:21 PM
