Unplugged oxygen sensor
Hey guys my 05 SE 1.7 has been surging. I unplugged the first oxygen sensor and it runs reapy good
What happens when i unplugged it? did the car go into some limp mode, or like a "Base tune" where it runs good but not perfectly?
Re: Unplugged oxygen sensor
Iam okay with everything but wear on the motor. Its got 250000 already. With the original sensor and the aftermarker sensor it drives like your pushing the fuel pedal up and down every second or so while your driving.
I need a honda sensor. 300$ yuck
I put the same exhaust on my si and my old dx without a problem. Only because the stainless header is 85$ with bolts and gaskettes from ebay and the cheapest one around gere is 400$ish
Sanji
Without a catalytic converter, you're going to be running super lean or in Open Loop (if you don't run a primary O2 sensor) without some form of either O2 sensor fooler, or running a combination of spark plug fowlers to get the secondary O2 sensor out of the stream. Neither of those conditions is good for your engine.
91ef8sir
20
01-29-2013 11:24 AM
