Honda Civic single power door lock not working
good day!
I have a 2003 DX-G sedan
My driver’s side rear door power lock is not working.
the lock works fine manually (meaning the mechanism isn’t seized or broken)
i assumed it was the door lock actuator as all of the other door locks were working with the switch and fab.
I just replaced the door lock actuator and nothing!
no power or movement at the actuator
what else can it be if only the one door lock is not working?
Re: Honda Civic single power door lock not working
The relay that clicks to send power is likely to blame, and for the life of me I can't remember where it is.
The cause may possibly be due to an open (break) in the wires. Gently pull back the rubber grommet boot at the B-Pillar. The Yellow (terminal no. 8) wire and Yel/Blk wire (terminal no. 7) are for the left rear door lock motor.
tapau
04-03-2019 04:00 PM
johnboy1313
Honda Civic (2001 - 2005)
13
08-10-2014 01:46 PM
