Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Honda civic 04 water leak
Old 06-12-2018, 08:39 PM
Tamer_n_t's Avatar
Default Honda civic 04 water leak
Hi,
I used blue divel for my civic 04 because it was overflow from expansion tank, 3 month later I had saver leak from water pump side, the next day i took it to mechanic to check it, but it stop leak suddenly with no heat. 3 days now.
How could I know what's wrong?
thank you in advance
Old 06-13-2018, 09:11 AM
thisguyaves's Avatar
Default Re: Honda civic 04 water leak
I don't know why this is so hard to understand...
What I think you're saying is that the coolant tank was empty so you filled it and now it's randomly leaking from the water pump? But the water pump is inside the timing belt cover, not sure how you would be able to verify that.
Replace water pump gasket, flush coolant is my recommendation, if I got that right.
justint7121
11-21-2010 09:46 PM
wedtm
03-26-2008 07:59 PM
mike0503
07-11-2007 04:54 PM
Mrob91GS
03-26-2005 08:25 AM
intezn
04-04-2003 09:20 AM
Quick Reply: Honda civic 04 water leak
