Power Steering Leak
Power Steering Leak
Hi,
I've noticed some leaks from my power steering reservoir/pump?, it seems to drip more when the car is parked on an incline. After a few weeks it is noticably low and the PS reservoir has some bubbles when I check the fluid level while the engines warm.
One of the hoses connected to the reservoir looks wet with oil, anyone else experience this problem? Thanks
Re: Power Steering Leak
I believe it was the o-rings, thank you. Not sure if I got the wrong ones but it didn't quite seal so I used two and then sealed it with some silicone gasket stuff. Also does anyone notice when starting their car the idle will lower a bit, then find a steady place? I read somewhere here it may be related to the power steering.
nexusRawr
11-14-2016 06:22 AM
