2005 Misfiring Randomly!!!!
2005 ex, randomly misfiring is occurring, checked the spark plugs and th all were burned to needle points. Changed all the coils and still happening. Thinkng to change the leading wires to the coils. Any options on trouble shooting??
Re: 2005 Misfiring Randomly!!!!
Misfires are not only a spark plug issue. Your coil pack wires are the least of your worry right now. Fuel - Compression - Spark. You've checked spark. Next easiest, check fuel flow and pressure, fuel pump, and fuel injectors. Then compression with a tester and/or leak down test.
It's probably not spark related, bud.
Have you had it scanned for any codes? Does this happen only in certain situations like when idling/driving or hot/cold? We need more information before providing a concrete diagnosis. It could be lots of things at this point.
