AC - High side is low, low side is high.
I recently went to recharge my ac, and the guages showed the low side being high and the high side being low, it took most of the 12 ounce can that I put in and then wouldn’t take any more. Any thoughts on what could be causing the problem or possibly how to fix it? Thanks in advance!
Re: AC - High side is low, low side is high.
What car? Was the compressor clutch running? A high low side and low high usually means the system is either off (equalized) or the compressor is weak.
We're going to need a bunch more information to help you out. Let us know how you charged it, and if it was from a deep vacuum. What's the history of the system, ambient temperatures, and any other miscellaneous symptoms it may have?
arielb1
07-15-2017 04:43 PM
RFEwing
08-15-2016 10:20 AM
Muckman
06-01-2011 10:59 AM
