thisguyaves turbo 1.7L build - F you, K series!
The theme: Build slow, over time, and keep the car driveable as much as possible, while on a general budget that rivals built K-series NA swaps ($5K). Sacrifice nothing (AC/PS retained, subs in the trunk, heated leather seats... a nice street car.) Buy used name brand parts when possible, overbuild it and tune conservatively for worry free driving.
Goals: 300-ish hp, 200-ish tq, but honestly anything over 270/150 will make me happy. I just want to be able to run with my buddy's RSX-S (bolt ons)
I really kicked rocks on making this post, not sure what kind of praise/criticism it'd receive, but I figured maybe someone would want to follow in my footsteps so I should document it. I've been collecting parts for almost a year now (As of August 2018). I have an EP3 as well, but started this before snatching the hatch, so single cam race car it is. That being said, I have no rush and can handle downtime, but I'd like to get as much done as quickly as possible with as little downtime as I can.
inb4 "why not K swap it! SO much easier!"
1- I want the experience
2- turbos are fun
3- I can go back to NA quickly and easily if I stick with D17.
4- K swaps are in large expensive chunks, and whatever I did I was going to build it anyways. Less upfront cost mostly. ($1k for used K20A engine/trans, $800 for kpro, $500 for conversion mounts, $100 for subframe, $400 for wiring... exhaust... shifter cables... radiator... Air conditioning... and then the internals!)
So far I have picked up:
Full D17A2 and transmission with accessories, 130k miles (stock): $200
K1 technologies 4340 H-beam rods: $350
Supertech low comp pistons 8.8:1 (0.5mm overbore): $430
Supertech block guard: $50
OEM Oil Pump (shimmed and ported): $75
Stage 2 head (PnP head, BC stage 2 cam, Ferrea valves/springs/retainers, 20k miles): $400
D16Y8 intake manifold: trade, $20? value
K20A3 throttle body: Free from previous part out. RIP Shitbox Mk.1
Turbo bundle (Garret turbo, ram horn header, tial wastegate w/dump tube, AEM fuel rail (new!) 60k miles): $1000
Kpro and modified Kpro D17 gear: $700
Dezod intercooler and all piping: $500
What I still need:
Fuel system: returnless, fuel pressure regulator, fuel pump, injectors, lines
Engine machine work: Nobody around me likes Hondas. I am having a hard time finding a shop that is willing to clean, bore, and deck my block/head, nobody will notch my block for H beams so I guess I'll do that myself.
Internals: Piston rings, ARP heasdstuds, clutch/flywheel, gaskets/seals, bearings
Forced induction: All guages, oil feed line, BOV
Transmission: Axles, syncros(?)
This will be a slow build. Subscribe at your own risk.
2- turbos are fun
What I still need:
Sanji
Re: thisguyaves turbo 1.7L build - F you, K series!
No offense, but those are fairly lofty goals for a D17 while staying under the $5k mark. And, I have no idea why someone would invest $1k into a K20A transmission. The gearing isn't THAT great, and the LSD is overpriced compared to aftermarket alternatives. Picking up a used K20A2 or A3 transmission would be in the ballpark of $150 - $300.
But, with that said, best of luck with the endeavor.
Sanji
Something worth noting, the only thing you'd need to change in your transmission to get the same top gear ratio as a Type-S RSX transmission, is the final drive. The 6th gear ratio is the exact same as your EP3's 5th gear. If you really want to get good fuel economy, source a Final Drive gear combination from an Indian CR-V. It's roughly a 4.0:1 FD, and would really bump your fuel economy. Sure, it'd definitely reduce your off-the-line performance, but not so much as to make the car a complete dog.
I was also looking at the TSX 6th gear. Didn't know about the indian CRV, thanks for that!
