PDA
View Full Version : Transmission & Drivetrain
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. Shift linkage flipped upside down somehow.. please help
  2. L3 Mainshaft needs a smaller shim than Honda ever sold?
  3. Help ID transmission/engine noise 92 civic B18B
  4. AWD Civic Rear Differential Play/Clunk
  5. Big bearing L3 gearbox in CRX. What axles?
  6. Manual transmission gear ratios
  7. 91 accord automatic transmission shifting problem
  8. Car doesnt move in any gear
  9. Inside CV axle problem, transmission problem, or both?
  10. 1990 Honda Civic DX with shift problem
  11. 4.7 jdm itr transmission question
  12. S1 tranny shift forks
  13. 2000 Integra Type R gearbox hole
  14. Unable to downshift to second, fourth. YS1
  15. Automatic Transmission Rebuilder
  16. How much is a blown b18c1 worth?
  17. S80 Integra Shift Change Holder Assembly broke
  18. 2002 RSX Type S K24 Tranny
  19. honda
  20. can a honda civic 012 torque converter work in a 01 honda civic
  21. Hydrolic clutch line problems?
  22. gear syncros d series honda L1 gearbox
  23. 4th GEAR NOT GOING IN AT ALL!!!!!!! HELPPPPPPPP
  24. 2013 Si - 2nd Clutch Release Bearing at 56k
  25. 95 civic manual trans issues
  26. Full k20a3 boost build
  27. B16 Snap Ring Countershaft
  28. Fair price for b17 ys1?
  29. 2003 Civic -New clutch won't engage
  30. 2015 Honda Odyssey EK-L - Shifting Rough
  31. REPLACING CLUTCH
  32. Axle issues
  33. Auto Transmission slips and shifts bad
  34. Y1 LSD taken out, Which lsd is this?
  35. I have a 95 honda civic lx no power in the gas in any gear
  36. 95 h4a auto tcu question
  37. P2U5/M2S4 5th gear Synchro Spring/Collar
  38. 08 Civic ATF leak
  39. CV Axle fell out of tranny while car was doing 30.
  40. CR-V 1st generation AWD
  41. H23a blue top with BOYA transmission
  42. 1999 Acura cl 2.3 manual transmission shift linkage leak
  43. CR-V 2005 AT problem with lock up system in transmission
  44. Gears sitting in weird spots...? [96 civic B18 GSR]
  45. B Series Tranny Cases
  46. RT4wd all gears but 2nd have stopped working
  47. Vibration after refitting same old good driveshafts??
  48. Not getting the 5v on my countershaft speed sensor.
  49. BMXA - Reverse slips after Rebuild
  50. Transmission
  51. 2002 Honda Accord EX Transmission slippage
  52. Determine LSD Type Without Opening Trans
  53. Urgently needing your help guys
  54. civic wagon intrac
  55. Need new shift linkage! D16y8! Part discontinued everywhere!
  56. final drive question
  57. Mainshaft spins both ways in reverse- normal?
  58. LS trans vs B16 trans: how much quicker is it REALLY?
  59. clutch pedal feels loos
  60. car moving in netrual
  61. 2006 CRV with slow and very hard shift from 1st to 2nd.. solenoid?
  62. Del Sol RWD?
  63. 91 Crx Shift Link....
  64. dual bend short shifter options
  65. 07 Civic EX *TRANSMISSION PROBLEM* - Am I screwed? :(
  66. shift linkage
  67. what would be a good clutch to get for my car?
  68. LSD Type on B18C S80 transmission
  69. 2000 CRV code P0740
  70. MGSA vs M7WA
  71. 95 Civic Shift lever help
  72. 2004 civic ep3 transmision nightmare
  73. Trans issue after I put another one in.
  74. Need help clutch confusion
  75. Need clutch help before I go to far
  76. Transmission and AWD durability on 2nd GEN CRV
  77. a1 vs gsr trans
  78. Spoon LSD 1.5 way and Spoon 5.1 FD in on DC5
  79. Cable tranny gears into hydro ls tranny
  80. Odyssey build
  81. car won't move in any gear
  82. Gear-X 1-4th K series Mainshaft thickness
  83. Selector Fork Types
  84. Clutch and FD choice for B16
  85. Valvoline maxlife transmission fluid
  86. Transmission Weak Points
  87. sequential shift with stock gearbox?
  88. Cabel trans to hydro gear / bearring swap
  89. Trans speed sensor (VSS) problem
  90. automatic transmission solenoid
  91. LS 5th work on a B16a Cable tranny???
  92. Transmission solenoid inquiry: 98 accord v6
  93. 97 Prelude SS transmission in 94 Accord --Thoughts?--
  94. 92 accord won't go in to gear even when off
  95. Gsr clutch/Trans HELP!!!
  96. Gsr trans and new clutch issue HELP!!!
  97. 91 accord transmission shakes at 40mph
  98. Possible Axle issue 2000 Civic Hatch w/ b18c-r
  99. 97 cr-v axle won’t seat properly
  100. 94 civic clutch pedal
  101. Civic ed transmission swap
  102. Anyone Use the Clutch Masters Internal Hydraulic Bearing N817- H?
  103. No Blinking D4, No CEL. Transmission replaced, still slipping....
  104. 1999 crv transmission dead?
  105. Parts Suggestions: LSD fitment in a 6th gen Accord. WaveTrac or Quaife?
  106. 2009 CIVIC SI CLUTCH PEDAL ISSUES
  107. Need advice...
  108. GSR trans wont go in reverse
  109. Should I shift to neutral at idle?
  110. AT dipstick
  111. Clutch will not disengage
  112. THE CORRECT ATF FOR THIS....
  113. Accord wont shift into gears! Please help!
  114. New clutch for '96 Integra won't engage
  115. axle fits in what?
  116. Manual 5 speed tx weird issue
  117. Quaife LSD - Bad Installation?
  118. B20b4 all wheel drive
  119. 1st gear problem
  120. temporary axle boot fix
  121. Auto Tranny swap 94 to 01 Accord
  122. Which model
  123. 6th gen gearbox replacement guide?
  124. Y1 vs YS1?
  125. Clutch Fluid problems?
  126. AP1 Master Cyl in 97 Prelude. Pushrod help
  127. Speed sensor gear fell in transaxle
  128. 97 EJ hatch b series swap what axles
  129. Need help identifying transmission
  130. How to keep transmission cool in traffic?
  131. Transmission Wont Shift Into Gear Even When Off?
  132. South East Clutch
  133. 92 Honda Civic issue
  134. 2013 Accord Coupe - Factory Powertrain coverage
  135. 98 Honda Accord Gear Shift Button Replaced
  136. Main Shaft & Counter Shaft Speed Sensor
  137. cananyone help with a range sensor wiring diagram for 98 civic?
  138. LX 2006 Manual transmission noise
  139. Tried to reset pcm but code remains... help please!
  140. Action Clutch selection
  141. Can anyone help with p0705 trans code?
  142. Plea$e help!
  143. Loose Clutch Problem (2002 Civic Si)
  144. Anyone ever bolt the front of their tranny to the traction bar?
  145. Clutch/Transmission Issue
  146. 96 jdm itr transmission swap into 2000 gsr axle fitment
  147. Clutch problems
  148. 94 civic tranny go into 98 accord? Auto
  149. Accord 96 Automatic Trans TCM problem
  150. 1998 crv transmission issues. Need help
  151. Manual Transmission Snap Ring Broken
  152. D series axles auto to manual
  153. my honda civic
  154. I need help!! Car wont move
  155. Clutch / Transmission issues in EP3
  156. B series vs H series trans
  157. Where do I buy cv axles. 1991 civic hatch with b18a1
  158. 98' spec ITR trans- How do the internals look?
  159. hf tranny question
  160. transmission oil leak
  161. clutch has been changed but wont go into gear
  162. HELP
  163. B16 transmission with GSR axles. What seals??
  164. 99 Accord auto trans problems
  165. p0797 clutch pressure solenoid valve C stuck ON
  166. Replaced axles and it's still clicking
  167. Honda crv 2003 not engaging
  168. Bearing "whine" after rebuild?
  169. Clutch,axles,diff???
  170. Benefits of YS1 over A1 trans?
  171. Clutch, axle or trans?
  172. Newly acquired: H22A Type S, NEED YOUR HELP!
  173. Trans or clutch?
  174. s20/s40 new bearing noise.
  175. Hard clunk and then squawk from transmission when changing gears
  176. K tuned pro circuit shifter rattle
  177. Hard Shifting Into Fifth
  178. Metal in transmission. Are my synchros fine?
  179. after replacing clutch my car moves slow
  180. Swapped tranny, now clutch cable too short?
  181. transmission problem
  182. Squeaking sound coming from manual transmission.
  183. my 99 civic manual shifter is moving forward
  184. Shift linkage, I think.
  185. shifter repair gsr?
  186. Wrong linkage? No 5th or reverse
  187. Civic gearbox issue
  188. Automatic not shifting into first from a stop
  189. What did I just do to my clutch?
  190. Transmission problems need help
  191. D16Y m/t. leak coming from tranny / block ?
  192. Looking for options on cable LS trans, replace or repair
  193. Auto trans external cooler, OEM delete, questions
  194. honda civic LX '00 honda civic LX '00 the Car wont shift into drive
  195. how much play should i have in the diff?
  196. Strange 1st gear shifting problem
  197. 92 Civic d16z6 tranny problem
  198. HX final drive in an EX box?
  199. Broke down and confused. Need advice
  200. Putting DOHC Triptronic Tranmission on SOHC
  201. Dive my clutch just blow? 05 Acura RSX
  202. EK tranny on EG, which clutch/flywheel to use
  203. Transmission fluid
  204. 05 RSX Revs dropping when braking?
  205. RSX 6th gear add-on
  206. Crx D15B7 HF tranny issues help me
  207. New synchro tech crx si tranny vss help
  208. swra
  209. Identify trans type/model #
  210. In-line Trans Filter-Direction of Flow?
  211. Questions about new 96 Civic DX axels.
  212. How hard is it to change a transmission filter?
  213. Will this overheat my transmission?
  214. Need help identifying and sourcing parts for LS cable trans
  215. Transmission trouble
  216. GSR Trans: What work is needed for 550hp?
  217. 97 Civic EX MT acceloration problems
  218. 97 civic coupe manual tranny problems
  219. 95 honda accord transmission issue
  220. can i swap 5 speed into 6 speed for 8th gen civic
  221. 2006 civic ex 5 speed can i swap into a 6 speed
  222. 2006 civic ex 5 speed can i swap into a 6 speed
  223. Honda Mainshaft Holder Tool
  224. Axle spline chips in tranny-my bad
  225. 4.7 swap 4,5 or 4.4 swap fd?
  226. Where you you buy bare axles (with no CVs)?
  227. Where can I sleeve/repair the transmission bearing hole?
  228. ATF Change with Limited Service History
  229. s20 b000 and p9a b000
  230. 1997 Honda Civic shutters and revs when accelerating
  231. 1996 accord EX transmission problem
  232. honda s2k Clutch master / Slave Cylinder
  233. Automatic Transmission Rebuild
  234. Civic awd system power limit?
  235. Axles wont fit new trans
  236. Pressure plate damage? Inoperable?
  237. JDM 2003 Civic AWD trans info wanted
  238. Sticking 02 Accord Clutch
  239. GSR swapped eh9 eg sedan
  240. Stiff shifter
  241. Jdm b16a trans non LSD
  242. B Serie Hydro : 3th gear into 4th gear.
  243. B Serie Hydro : 3th gear into 4th gear.
  244. a00 2nd gear vs b00 2nd gear
  245. 2014 crv down jerks when applying brake slowly and comes to stop
  246. Help! No Reverse Bench Testing Rebuilt Manual Transmissions
  247. 1st/2nd Gear
  248. 91 Civic Shift Linkage Pin and Clip Installation
  249. 03 MDX transmission
  250. 1997 CR-V Transmission Help!
