Transmission & Drivetrain Gearboxes, Differentials, Clutches
Car doesnt move in any gear
Old 04-29-2018, 08:59 AM
radiotech's Avatar
Default Car doesnt move in any gear
I'm looking for some help. I have a 1994 Eg hatch with a B20b block, far head and trans.
I down shifted on the highway today and suddenly had no acceleration so I pulled over. Car will not move in any gear now. Engine running fine and revs, clutch pedal is still firm and not leaking any fluid, transmission shifts right into gear, but it won't move in any gear. I dont hear anything "expensive" when I rev it in gear either. No sounds of broken clutch or grinding metal. I looked things over and it looks like the passenger side drive shaft is seperated from the transmission some. I can grab it shake it around and its leaking gear oil from wear the shaft goes into the transaxle. I understand this is an open diff so I assume an axle being detached would cause the car not to move?
How do I go about testing if it's the transmission? Can I just reseat the axle or do I have to replace the set? What would cause the axel to move out laterally like that? I bought the car already swapped so I suppose it's possible the person who did swap it didn't use the proper axles for the swap, I'm not sure
adp1
11-19-2017 06:50 PM
Jcampa19
16
11-09-2014 01:31 PM
Spludeeee
Honda Civic (2001 - 2005)
02-17-2014 08:29 PM
jdmchickx
12-03-2011 04:09 PM
dazelman
05-27-2010 11:34 AM
Quick Reply: Car doesnt move in any gear
