PDA
View Full Version : Transmission & Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. Squealing when in reverse
  2. New info for B-series guys looking for cheap synchros
  3. Shift Linkage
  4. used 98' spec vs. new 96' spec type r tranny?
  5. What trans do i have??
  6. 2003 LX no pilot bearing??
  7. Exedy 6puck d16y7 clutch
  8. Type R gears need a new case
  9. rebuilding b16 tranny
  10. LX vs EX automatic trans different?
  11. M2Y4 5th gear swap
  12. 'Notchy' feeling when shifting
  13. Best clutch for now, turbo in the future?
  14. Where to get F22A Straight cut gears?
  15. How to check for defects transmission bearing? (not the comman ISB)
  16. h/f series tranny gear swapping
  17. Pilot bearing disintegrated.
  18. lightweight flywheel
  19. $3000 budget Help me spend it
  20. b series tranny main shaft won't spin with bellhousing bolts on
  21. what type of clutch for turbo
  22. im painted into a corner... awd civic problems...
  23. Tranny help
  24. Need Help With Clutch issues
  25. 2006 Civic AT transmission problem
  26. redline MTL or superlight shockproof oil
  27. Oil guide plate part number
  28. 98 spec itr tanny 4th gear problem
  29. Tsx clutch whinning on engagement...
  30. Need help! Clutch not disengaging.
  31. help with b series trans
  32. New slave cylinder problem
  33. 96-98civic vtec 4dr A/T TO MANUAL HOW TO HELP guide
  34. Announcement: MFactory R&D
  35. what trans???
  36. 1990 civic with a d16z6 and cable clutch
  37. competition clutch!
  38. 3rd gear from an ls cable tranny into an ls hydro tranny
  39. What SAE Trans oil for s4c ?
  40. need help choosing a clutch
  41. h22a on LX trans help
  42. casing damage
  43. Anyone Running Twin Disc in a Cable Box
  44. Best place to buy a clutch
  45. Is this pressure plate reusable?
  46. LS Final Drive in ITR Transmission
  47. Transmission code help!
  48. delete
  49. m2u4 atts transmissoin in h22 swapped eg
  50. 93 Auto Tranny Fourth Gear Slippage
  51. clutch dilemma
  52. 94 civic dx trans issues
  53. Recent Misshift, Over Rev
  54. IDK WTF is going on with my clutch. I need some advice
  55. mainshaft thrust clearance
  56. gsr tranny no more 5th gear!
  57. tranny rebuild ?
  58. B16 Transmission Issues
  59. Indigo flywheel??
  60. Jdm 98spec Itr trans. Which vss gear?
  61. Help with tranny questions...!
  62. 2nd Gear popping out. What to do now?
  63. interchangeable transmissions
  64. 1994 Honda Accord
  65. Stumped by b16 trans problem
  66. Close gear ratio, which final drive?
  67. s40 transmission bearing replacement help!
  68. question bout swapping final drive gears.
  69. Chatter problem
  70. M2B4 Transmission
  71. transmission with no gears??
  72. can someone identify this lsd + fd?
  73. LSD problems
  74. absolutely no 3rd gear. what can i interchange
  75. 96 civic transmission problem
  76. Final Drive Gear-X on Y2 (b16a1)
  77. Transmission problem
  78. Help with lsd diff final drive?
  79. 98 civic LX auto transmission swap?
  80. what axles do i have???????
  81. Powdercoating transmission case
  82. Bell Housing
  83. 5th gen - cross joint drive
  84. HELP! D16Z6 Transmission Torque Spec
  85. main shaft help
  86. Car won't shift?
  87. s4c gearbox
  88. short throw shifter
  89. Help looking for transmissions on B18 civic
  90. Soft clutch and sqeaky noise from tranny
  91. Advice on gear condition
  92. craigslist horror story
  93. Help with friction point moving higher
  94. Can I drive my 02 Civic with no reverse???
  95. Is H-B really my only option?
  96. B16 with type r lsd
  97. New B Series PPG Gear Set, Whats the Break In Process if any???
  98. Unknown axel
  99. H/F series custom 1st & 2nd
  100. have a dilema.........
  101. Damaged ring gear
  102. possible slipping clutch?
  103. D16Y7 Clutch Release Bearing (part number)
  104. Bedding In a CC Twin Plate clutch
  105. Main shaft speed sensor
  106. act clutch grinding in 3rd
  107. Spoon LSd problem
  108. Itr case cracked, need donor case, what options do I have?
  109. Identifying s4c LSD without removing anything
  110. Trans differences
  111. How to tell difference between 4.266 and 4.40 countershaft
  112. Difference between hydro b16 and gsr 5th main gears
  113. Flywheel weight?..
  114. need help with clutch
  115. Half shaft problems
  116. what would cause a needle bearing to come out of its bore?
  117. D16 Si L3 Transmission
  118. which trans is better for turbo
  119. auto B16 and auto B20 tranny
  120. CT-R Trans - "Clunking / Knocking" around turns
  121. possible clutch release bearing issue
  122. K20A and R20A transmissions
  123. Tranny shifts 1-2 and R fine. 3rd - 5th not so fine after rebuild.
  124. 97 gsr transmission question
  125. General Question
  126. 96 civic auto transmission problem
  127. b16 trans need taller 5th gear
  128. Tranny Stud too short
  129. Trans/ Clutch acting up. Please help
  130. I need a new clutch, What do you think of this?
  131. stupid axles!!
  132. BREAKING TRANNY
  133. K24 Transmission question
  134. Z6 trans problem! help!?
  135. b16A transmission vs GSR transmission
  136. recommend a good street clutch for my setup please
  137. s1 cable internals in y80 hydro case
  138. welding the differential pin in place?
  139. Transmission issue
  140. Cleaning transmission internals
  141. Too much hp for tranny??
  142. clutch pedal gets soft !!! need help
  143. pulled a money shift now tranny whines why?
  144. How long will Honda ATF last until it wears out?
  145. Stage 1 - Honda Prelude
  146. Axle Seal
  147. Transmission Question
  148. b series tranny problem
  149. 05 Civic Hybrid CVT Won't move in any gear
  150. Trying to figure out what kind of transmission i have.
  151. Accord or Prelude trans for autocross?
  152. 5 speed to 6 speed conversion...
  153. d16y8. brake pedal stiff, won't go past 40.
  154. 96 Civic throwing tranny codes
  155. maybe clutch or slave problem
  156. Axle question?!
  157. Car goes into gear, won't move when clutch is let out... :(
  158. Interchangable transmission parts?
  159. Spoon b18 lsd help!! Urgent!
  160. need advice with my 97 accord
  161. auto to manual conversion
  162. replacing cv axels 99 prelude
  163. differential bolt patter measurements
  164. exedy twin disc replacement plates
  165. Auto to manual problems.HELP!?
  166. A more fun Automatic
  167. honda accord 94, wont engage gears
  168. B16 transmission reverse problem
  169. Let me explain my slipping...
  170. y1 lsd with broken input shaft
  171. D-series S40 Transmission failure pics and explanations
  172. How to change shift points on Honda automatics?
  173. ls tranny 4.40 final (how to I.D?)
  174. D series cable/hydro interchangeability
  175. recomended clutch
  176. 93 Del Sol problem: trans, clutch or something else?
  177. Practical HP limit for OEM viscous GS-R LSD?
  178. compatability of hseries gears and b series gears
  179. LSD Gsr tranny question ?? Please help
  180. need some help, losing my touch.....
  181. Obd0 tranny in EG Speed sensor???????
  182. MFactory or Quaife LSD
  183. transmission experts and gurus its time to rack your brain.
  184. K series transmission HP limit?
  185. Help with ACT Clutch
  186. swapping a ys1 tranny outof a 92 & putting in the 5speed outof a 90..HELP!!!
  187. Car goes into gear, doesnt move..need some help guys!
  188. Now I have 3 Y1 cable transmissions....
  189. b18 swap what half-shafts to use?
  190. axle stuck on right side of m2a4 h22 transmission
  191. 2000 EX P1768-Tried Helm FlowCharts-Now What?
  192. Limited slip diff + boost, which transmission is best?
  193. '05 EXv6 Transmission slipping?
  194. Confused? Help LS Trans
  195. Axle does not look fully seated. (PIC inside)
  196. Honda CRV - Seems to be stuck in DRIVE and car won't start up
  197. 2002 JDM Honda Accord CL7 Euro R
  198. Trans Problem S20 Transmision
  199. To rebuild or not to rebuild?? GSR
  200. unsprung clutches and daily driving
  201. s80 type r lsd trans not going in reverse
  202. Noisy s40 transaxle: Replace, rebuild, none of the above?
  203. b16 axle seal leak , could it be something else? (pics / video inside)
  204. ATF change with return line
  205. B17a1 ys1 trans problem help
  206. Forged straightcut Syncroed gearset for H/F series tranny group buy
  207. 01J stamped LSD diff. help ID
  208. Quaife LSD?
  209. clunking noise when moving
  210. Loud knocking clunking crunching noises inside trans
  211. D series trans problem!
  212. Replacing Manual Transmission shift cable on '91 Honda Civic
  213. VSS problem, built b20. Urgent =(
  214. Good tutorial, links, sites for learning transmission stuff
  215. Transmission gearing
  216. bolt on transmission is stuck
  217. Lsd Noise?
  218. S20 vs. S40
  219. s40 cleanup and inspection help
  220. Squeak-idddy sound...
  221. Popping noise when switching gears, help!!!
  222. hydraulic ls trans differential question
  223. Changing ATF and the engine running
  224. P0700 & P0715 Codes...
  225. Will oem b16 LSD fit a b18 90-93 integra tranny?
  226. Clutch completely changed feel...
  227. Clutch options for 2005 honda Civic EM2
  228. 6 speed b series?
  229. Exedy twin disc?
  230. Complete clutch swap, new slave, all bled, no PEDAL!!
  231. Mtf change,
  232. b20z into ek. Can i use the crv halfshaft!!!!!?????
  233. h2b guys chime in here please
  234. LSD shim selection
  235. can't get into gear while car is running
  236. cable b16a internals in a cable s1?
  237. J-type 6 speed conversion!
  238. Car jumps & hood shakes when shifting and idling
  239. how i installed an lsd in a crv awd transmission...
  240. Axel pops out in bumps and left turns?
  241. 5th gear grind?
  242. removing bearings from inside bell housing case in S1 trans?
  243. lsd not catching traction.
  244. ACT clutch stuck in gear at High RPM
  245. can u swap obd2/obd1 auto tranny 93 integra
  246. CC Stage 2 clutch Hard time getting in gear at HIGH RPMS
  247. lsd help!
  248. RATTELING(sp) NOISE
  249. Help...How to take off speedo gear b16 hydro tranny
  250. Help me identify this LSD
