PDA
View Full Version : Transmission & Drivetrain
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. 94 EG civic auto to manual IACV
  2. Gsr lsd
  3. Blox qr clutch master cylender
  4. Check clutch master cylender pressure
  5. Transmission Swap?
  6. Mainshaft Thrust Measurement: NRH3
  7. Transmission will not shift when wheels are rolling
  8. "hair" in transmission
  9. mod that deleted the saenz thread i had about making t work with OEM final
  10. mod that deleted the saenz thread i had about making t work with OEM final
  11. B16 transmission stuck in gear
  12. Help!!!! Troble with clutch pedal losing press and dropping half way when warmed up
  13. Whine coasting in 5th after rebuild
  14. Quick gear ratio question: ys1 vs y1 transmission
  15. DOT Type R Trans serial tag # ?
  16. Action Clutch twin disc
  17. b16b trans whine
  18. t2w4 Lsd 4th gear issue
  19. Aluminum vs OEM flywheel
  20. Abs rings -where to get
  21. Albins/SpeedFactory Racing B-AWD Gear set and FWD2AWD first look
  22. Trans is grinding 1,2,and3 gear?
  23. 91 Civic Wagon RT4WD axle loose in transmission. need new spider gears in diff?
  24. Help me!!! what d series trans i ha
  25. Brand new clutch / flywheel slips bad
  26. Price difference??
  27. Short Shifter Recommendations
  28. Liberty gears
  29. Broke transmission to rear mount
  30. 2008 Civic SI - Trying to Diagnose Noisy Drivetrain
  31. Do crv trannies work w b18c
  32. Gsr transmission
  33. Cv axle angles
  34. Fifth Gen Auto Tranny
  35. 2001 Honda Prelude Auto Trans Acting Crazy
  36. Transmission? Noise - internet diagnosis :)
  37. Why would I suddenly get difficult cold shifting out of the blue?
  38. EP3 Transmission Rebuild Question
  39. 98 civic auto trans lines
  40. Clutch Upgrade??? - 2006 Honda Civic SI - Kraftwerks Application 430 HP to Wheels
  41. Redline MTL for CR-V?
  42. GSR trans
  43. Here's to hoping that I don't have to get a new tranny!!! Please help..
  44. Performance shift linkage
  45. Need some help pls!!! Trans not engaging with clutch
  46. GM SynchroMesh or GM SynchroMesh Friction Modified?
  47. Brass Reverse Synchro? NRH3
  48. Please help me identify this shift linkage.
  49. Exedy 8.8lb flywheel vs Fidanza 7.5lb flywheel
  50. Curious about how this b16 trans issue got solved. Help
  51. D series Syncrotech s40 trans missing bolt?
  52. S40 B000 transmission help!
  53. 93 Civic clutch pedal assembly
  54. Question on return action of gear change lever manual transmission
  55. GSR LSD or aftermarket for 400hp?
  56. Thoughts on aftermarket shift linkage
  57. No first gear, AT ALL
  58. Transmission
  59. B16 s4 lsd help
  60. Lost half of clutch pedel travel
  61. D series axle problems
  62. Honda transmission swap
  63. Hush Performance hydro conversion
  64. F20b
  65. '90 and '92 5 speed
  66. DC2R gear box notchy
  67. Feedback request : B16 Transmission ID verification Needed
  68. LSD B16 cable Y1-1021774
  69. Clutch Recommendations
  70. H22 Transmission, P2T4
  71. Gears not engaging while Running
  72. Oh Lawd!
  73. Comp stage4 clutch disc thickness?
  74. Hybrid Transmission 94 Del Sol --Long 5th gear
  75. How-to: Tear Down and Rebuild 2002 Honda Odyssey Transmission
  76. 02 RSX 5-SPD inputshaft stuck after split. (resolved)
  77. Bad grind in trans, disassembled to find this
  78. New Clutch?
  79. Upgrading transmission for boost
  80. Trans fluid color?
  81. grinding/ rattling noise when decelerating
  82. Honda B18 Kaaz Differential Help
  83. Honda Civic dx take off grinding noise. Please help
  84. Does it fit?
  85. S40/ s20 transmission build
  86. AT lockup Torque Converter and TCM?
  87. Honda Del Sol Grinding when accelerating!
  88. Gas pedal 1997 civic lx offcentered car reving when moving pedal from side . Throttle
  89. Adding LSD China Grip in LS transmission
  90. Removing Diff Bearings
  91. b series tranny leak from front mount
  92. HONDA RIDGLINE FWD 6 SPEED MANUAL TRANS.
  93. 2019 Honda Accord Car Jerking while Accelerating.
  94. Honda Crossroad Transmission
  95. 2011 Accord Transmission HELP!
  96. Ls trans rebuild to lsd with carbon syncros
  97. Clutch won't engage
  98. Tranny noise
  99. Tranny rare noise
  100. Best manual transmission fluid for track day
  101. M/T Loss of 5 the gear. Please debunk, or confirm...
  102. Problems after replacement CVT by MT
  103. New Clutch - Goes into gear but won't move
  104. Advise on a fishy "gsr" transmission. Need a guru
  105. GSR tranny Final drive question
  106. Final drive gear is too big to fit the countershaft bearing retainer.
  107. Issue closing bellhousing after changing final drive
  108. S1 Cable 5 speed manual transmission
  109. ‘04 TSX Trans Clunking
  110. Help me inspect the dog teeth on this gear
  111. Signs of a failing LSD? Car Unstable at Speed..
  112. AWD transmission conversion
  113. Stage 2 Clutch too thick?
  114. 86-89 Teg LSD?
  115. Car wont go into D4
  116. Clunking from cv’s
  117. question regarding integra ls automatic
  118. Axle Vibration?
  119. Clunking When Shifting
  120. YS1 Rebuild help
  121. Neutral Safety switch? Mind boggled
  122. USDM LSD
  123. Transmission boss
  124. Is clutchnet dead?
  125. Drag Cartel is now producing billet b series t-case's
  126. s40 shift fork orientation and bench shifting
  127. Final drive in 1997 acura integra type r?
  128. Need help with 1989 prelude SI clutch
  129. Gsr Shifter
  130. 2nd gear problem in my k20a2 dc5r
  131. 2002 civic LX Automatic with p0704 code
  132. Shot Peening or Cryogenic Treatment?
  133. MFactory D16 RT4WD helical LSD
  134. Can an external trans cooler work "too good"?
  135. Pilot 2019 AWD touring
  136. D17a1 transmission problems
  137. d15b shift solinoid location?
  138. Scratched mating surface on transmission casing
  139. BMXA Rebuild - reverse gear hub distance
  140. 2nd gear lockout issue *TRANSMISSION EXPERTS*
  141. Strange Transmission Issue
  142. '00 accord f23a bad tans
  143. b16a Y1 transmission quick question from the expert
  144. B16 Trans. 3rd Gear Grind: Synchro, Gear, Sleeve, etc. Inspection - What To Look For?
  145. Cracked head between collant passages, fixable?
  146. tranny interchange
  147. Stuck and dont know
  148. New User - Interested in Opinions
  149. HELP: Y21 Transmission noise in any gear.
  150. Gears from 2005 in a 2010.
  151. GSR Tranny questions
  152. JDM ITR transmission clutch housing
  153. Trans detent springs
  154. D tranny gear swaps
  155. Got boned buying an LS transmission, weighing option, need advice.
  156. Please help
  157. LS 4th and 5th gear swap into GSR transmission
  158. Whirl noise under accel in rebuilt S80 Tranny
  159. B18B1/B16 Spoon LSD Question
  160. transmission leak (unkown where at)
  161. car wont move after i changed alternator out
  162. No oil in transmission after cleaning, will it rust?
  163. What causes shudder in the automatic transmission when slowly accelerating in D ?
  164. Can someone tell me where I can get transmission rebuild kit?
  165. Need help with diagnostic please
  166. transmission goes into gear
  167. 1992 Accord w/ F22B1 Smoking Manual Transmission
  168. 93 Del Sol auto with shifting issues
  169. Can fit a 2004-06 Acura TL transmission to Honda Odyssey 05-06???
  170. Transmition housing
  171. Ep3 5 speed final drive swap
  172. Ep3 5 speed final drive swap
  173. No CVT transmission on L serves engine
  174. Need Help Picking Transmission!!!!
  175. Bseries KTUNED slave, leaks
  176. Bwr limited edition spark plug cover info
  177. V.s.s. gear shaft not sitting flush on transmission
  178. sticky clutch
  179. Honda Element Axle replacement
  180. HELP!! CLUTCH ISSUES.
  181. Mechanic did a transmission flush on my Honda Element and now he's found "fibers"
  182. chasing tens, potentially a dumb question...
  183. Diff. and counter shaft noise after rebuild
  184. transmission sensor fault, accord 2013 v6 coupe
  185. b16 hard to spin 1st gear after rebuild
  186. Help Identifying CV Axle Type
  187. Is there a way to lighten steering on electric pwr steering in 2018 Civic?
  188. Clutch engagement point keeps changing.
  189. F22B3 Engine Compatibility with Px4B-1319548 Transmission
  190. input shaft bearing noise after changing tranny fluid
  191. 7th Gen Accord 5M K24A8 Tranny Rebuild
  192. 5th gear cuff bearing size question
  193. 09 pilot - ex-l - transmission problem
  194. Transmission friction damper.
  195. S4C Counter Shaft with LS Ring Gear?
  196. F22A1 to F22A4 transmission swap
  197. s4c into s80
  198. 2005 Accord transmission oil change
  199. p2a8 - is there a longer gear trans?
  200. My integra keeps breaking axles
  201. Quaife LSD disassembly
  202. Transmition whine when accelarating
  203. Hasport axle issues
  204. manual tranny locking me out of 4th and 5th gear
  205. 1991 Honda CRX manual tansmission oil?
  206. Da9 with s4c transmission issues (About to burn the MF)
  207. Shifter arm is falling through bracket and hitting exhaust?
  208. Spoon sports
  209. Transmission Grind In 5th
  210. P2T4 origin and info
  211. Locking in Gear.
  212. Do bad CV axles creak?
  213. Urea Grease, brake assembly lube.
  214. What transmission is this? (89 CRX?)
  215. Gear Shifting problem Honda Vario 2005
  216. 1995 Acura integra B18C inboard joint to intermediate shaft spacing help.
  217. Reassembly: D16 s20 trans countershaft too short?
  218. Help !!! Atf fluid leaking/drips
  219. Help pics inside
  220. What trans do I have and does it have lsd
  221. Violent jerk when in any gear
  222. Troubleshooting: "Clicking" clutch pedal
  223. Action Clutch 2MS Shudder/Bucking When Slipping
  224. Raxles vs. DSS vs. Insane Shafts
  225. Clutch super hard, cant push to ground
  226. 2000 honda CRV torque converter and flex plate
  227. b series drive shaft compatability
  228. H23a help me
  229. Has anyone had problems with Competition Clutch twin disc grinding bell housing?
  230. Running Maxlife ATF?
  231. 90 Civic SI ISB changed, but! *With Pics*
  232. Troubleshooting: 92 Accord - Clutch has been replaced. Accord now shuts down
  233. GSR shift rod question
  234. I need synchro order
  235. 2007 TSX cross bred with a 2006 CR-V Manual Transmission
  236. B Series Final Drive Gear Teeth
  237. Zc hydro swap.
  238. Pulling to the left during acceleration and deceleration ?
  239. 00 honda accord v6 transmission problem
  240. Cruise Control 2012 Civic
  241. Which clutch am I going to need for a hydro GSR going on my B16 CRX?
  242. Bad Axel Joint?
  243. HELP H/F series trans which is best for cruising?
  244. 94 accord lx to 95 Integra automatic trans
  245. Transmisión D16Y7
  246. Ep3 clutch case question
  247. 01-05 civic rocker arm clutch engagment not correct
  248. Auto trans goes into gear then false neutral. Idle surge
  249. School me on twin disc.
  250. GSR on D16Z6
