PDA
View Full Version : Transmission & Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. Quaife helical diff question w/pics
  2. WTB B Series Tranny! Need ASAP. TX
  3. Recommended places to buy B series trans??
  4. WTF.. What happened to my clutch!!1 aaah help
  5. '90 Integra clutch pedal very stiff
  6. Any idea which trans/lsd this could be?
  7. NEED help fast! H22B with '95 tranny?
  8. Looking for a rebuild guide.
  9. Will a 2nd Gen. Integra OBD0 Manual Transmision work with 1996 Integra w/B20B4 OBD2
  10. for any one trying to hun this down
  11. b16 cable tranny help!
  12. Differential bearing?
  13. help with clutch and flywheel choice b18c-r
  14. b16 trans problem
  15. Part ID Please!!
  16. Clutch release arm problem..!!!
  17. 1996 Accord LX sedan manual transmission noise
  18. Transmission help H22- Cant shift
  19. D16Y8 Transmission Problem
  20. k20 type s tranny problem (pics inside)
  21. Tranny problem
  22. Drag noise in tranny, Please help
  23. Driving different stages of clutch?
  24. Launch... SQUEAK... 2nd... SQUEAK...
  25. 4 Speed 88 Civic 1.5 DX
  26. Replacing clutch and flywheel. Any advice?
  27. Anyone know the pitch/size of a b-series countershaft nut?
  28. 5th gear grinds after full rebuild.
  29. 85 civic problem
  30. crv wont go into gear...help!
  31. What is this seal? Know the part number?
  32. K20A2 turbo drivetrain
  33. Motor swap
  34. b series transmission??
  35. 2005 civic 1.7 auto shift problems
  36. Newly Developed Leak,Please help!!!
  37. whine in 4th gear 6k miles on new build
  38. Problem with my 1989 Honda Civic
  39. Input Shaftbearing noise?
  40. will obd1 p75 MT work with b18b1 AT tranny?
  41. Need some input on a clutch!
  42. h22 gear info needed
  43. 2005 Civic automatic down shifts by itself
  44. S4c LSD conversion Help
  45. vss interchangeablility...
  46. Ball Bearing failure on LSD ...... why??!!!
  47. I need some help from B16 Transmission Gurus
  48. JDM SIR Tranny LSD Broke need help
  49. Wow...there really are stupid questions!!!
  50. CTR tranny in a 97 GSR VSS problem
  51. popping out of second..whining in first..
  52. Checking Out A Used Transmission Before You Buy
  53. newbie to forum, manual trans problem
  54. help//
  55. new synchro's, now pops outta reverse
  56. Dual Cone Synchros
  57. TOO MANY REASONS Y YOU SHOULD NEVER TAKE YOUR CAR TO RACELINE
  58. suggestions for new clutch and flywheel?
  59. What's my Tranny worth?? 3rd Gear grinds @ high RPM
  60. new clutch and flywheel clutch not engaging
  61. itr countershaft vs b16 countershaft
  62. itr lsd in usdm b16 trannyo
  63. WTB: LS 5th System
  64. JDM ITR LSD into Si transmission
  65. Why input shaft bearing only makes sound in 1st, 2nd, and 3rd gears?
  66. Mainshaft - Thrust Clearance
  67. Comp Clutch stg 5 limits? do i need twin disc?
  68. Gearset & Final drive compatibility among cable D-Series transmission cases
  69. clicking lsd
  70. Exedy oe clutch or f1 stage 1?
  71. what b series lsd is this?
  72. si gears in ls trany?
  73. CLUTCH CHOICE FOR MY TURBO INTEGRA?!
  74. How many LSD
  75. obx lsd and speed sensor
  76. tranny help
  77. 5th gear problem
  78. Ebay LSD and Speed Sensor
  79. how can i tell if i have ctr or itr gears
  80. Will a dc2 dual bend shifter fit into a 92 to 95 civic
  81. Is this a short geared D series transmission?
  82. Gsr slight rebuild please help needed
  83. 99 acura cl 2.3 trany question
  84. b16 ring gear into b18c countershaft???
  85. b series pg in a d series trans
  86. 3.2 tl type s transmission ?'s
  87. Russel clutch line! help
  88. Comp Clutch pressure plate bolts
  89. what kind of b series lsd is this
  90. Another Transmission Problem
  91. Transmission wont shift into second
  92. gsr hydro trans worth buying?
  93. s80 lsd gearbox
  94. Parking in gear?
  95. clutch master cylinder empty, sucking air, bleed it?
  96. Single gear shifting issue when hot?
  97. Name that LSD!
  98. Weird rubbing/knocking noise in 1st + 2nd gear
  99. K RWD tranny
  100. Transmission/Diff Noise While Turning?
  101. Clutch Slave Cylinder Cover?
  102. Beck Arnley? Clutch
  103. 1996 acura integra auto trans weight
  104. gear swapping....again
  105. does this mean i have a LSD??
  106. Shorter Shifter Arm for 2000 coupe
  107. 95 Civic dx help
  108. 5TH GEN accord auto transmission's
  109. Transmission Swap
  110. Short Shifter bad for transmission?
  111. clutch pedal question
  112. s20 replacement
  113. Tranny Popping out of 2nd Gear
  114. AT Tranny question
  115. Transmissions gear ratios please help
  116. 95 dx Auto to Manual swap, help!
  117. twin disk question
  118. rebuilt tranny still popping out of gear!!?
  119. EK 4dr tranny sound??
  120. commuter civic tranny swap ?
  121. please help! tranny
  122. Flywheel bolts length
  123. Slipping clutch and horrible (rubbing) noise upon lifting throttle
  124. itr lsd 4.4 final drive swap with gsr final drive (gsr trans) QUESTION)
  125. shifting problem going into 3rd and down shifting
  126. NEW! Automatic Transmission fluid from HONDA
  127. Looking for Transmission service
  128. 93 EX and 92 DX transmission Questions.
  129. gsr sincronics into b16
  130. Quick Question: ATS 4.9 FD Countershaft
  131. Need a Tranny, Will This Work?
  132. 600whp with a b16 trans
  133. Gearbox Identification Help Required
  134. Honda ATF DW-1
  135. Goes into gear, speedo and tach work but car doesn't move?
  136. Clutch options
  137. Civic clutch opinions, competition clutch??
  138. Cable to Hydro Transmission
  139. Comp twin disk help please
  140. what clutch should i get? 1990 DA with B18b
  141. 96 GSR will not engage gears Help!
  142. Upper Transmission Mount Studs
  143. Tranny, Vibration or ?
  144. FINAL DRIVE SWAP
  145. new clutch disk/plate problem
  146. Swapping gears help
  147. clutch master cylinder/slave cylinder question..
  148. B16 or GSR Tranny/ Hydro or Cable
  149. CC twin disc clutch with tilton release bearing.
  150. Tranny Guru's, need help. question regarding housing swap...
  151. What gears do i need???
  152. oem lsd rebuild
  153. Tranny feels sticky and doesnt go into gear sometimes
  154. H22 Diff Speedometer Gear Help
  155. What material is honda gears made of
  156. HELP IDENTIFY LSD PLEASE...
  157. VIBRATION AT CRUISE AND FREE REV
  158. Ex d series tranny problems :(
  159. honda tranny id # sl3-5074-256
  160. diff bearings
  161. Transmission knocking on acceleration
  162. AC COMPETITION TWIN DISK ISSUE
  163. 96-00 Civic Autos. FEEDBACK PLEASE
  164. Help, gsr hydro tranny problems.
  165. Clutch or transmission problem HELP PLEASE!?!?!
  166. 3.307 1st gear / 4.785 final drive
  167. integra CMC swap. in need of thread size
  168. j1 Transmission, possible LSD! need opinion
  169. best route for b18b1 transmission
  170. H2B NOT GOING INTO GEAR !!
  171. GSR Trans noise: HELP!!
  172. please read this before you PM or email me.
  173. d16y7 tranny swap
  174. tranny swap
  175. 01 Accord Auto transmission problems
  176. will a 98 acura tl transmission fit a 2000 acura tl?
  177. Need help with integra 94 tranny (1st and R)please help
  178. 89 crx vacuum reving
  179. D series transmission
  180. Too Much Fluid in Clutch Reservoir
  181. Mfactory LS 4.785 final drive
  182. nub question (4th but no 3rd)
  183. sohc tranny questions
  184. S40 (d16y8): Clutch Won't Build Pressure?
  185. Clutch?? Slave?? Master Cyl?? Cant figure this out NEED HELP PLEASE
  186. converting auto to manual?
  187. Clutch/trans question
  188. Does my clutch need replacement?
  189. Possibly a clutch problem, wont pull.
  190. Clutch for my 94 Integra
  191. Can't shift gear when trans cold????????????
  192. remanufactured axle wont suck up to hub/knuckle
  193. How to Meaure Bearing Preload?
  194. 97 civic dx HELP rattling noise!!!!!!
  195. case swap q's
  196. Assuming my axle is going bad...
  197. ITR lsd into gsr tranny
  198. exedy stage 1 or comp clutch stage 2 for gsr
  199. Automatic to Stick ?
  200. Can't shift into gear
  201. MB6 Gearbox mount same as EG6?
  202. 87 accord dropped 5th and now losing power
  203. B Series Tranny Problem
  204. Transmission for B16A?
  205. ordering clutch and flywheel for crx need help
  206. Need Help With B18A1 Tranny case install
  207. Bleeding a 90 Accord
  208. LS 5th gear in b16 transmission
  209. gsr tranny vs b16 tranny question
  210. Cable trans into EG
  211. 97 honda civic dx tranny help!! ):
  212. Looking at buying 01-02 Honda Accord V6 EX-L Coupe...
  213. no 3rd gear
  214. l3 - 1175293 trannsmission help?
  215. How important is it to have matching final drive and ring gear.
  216. j1 b16a or gsr with ls 5th
  217. SH!FT's suggestion thread
  218. 88 a6 with a 94 z6 trans
  219. Clutch Q
  220. mobil 1 grease
  221. b16 w/ lsd or gsr tranny
  222. Input Shaft Outer Race Stuck!! Pics inside!
  223. Clutch Set Upgrade
  224. TRANNY OIL - overfill question
  225. my tranny dont wanna go into gear 97 accord
  226. kazz lsd still chatters
  227. cable bell housing on hydro case?
  228. Straight cut gears
  229. 4.7 FD in a gsr tranny
  230. Input shaft wont spin once case is sealed
  231. One-piece clutch MC and reservoir?
  232. ring gear bolt torque?
  233. Grinding in Cold?!
  234. Need help on how to do a LS 5th gear into a gsr trans..?
  235. Cable trans/hydro parts?
  236. ebay clutch's.(f1,xtd,xtr) any good?
  237. clutch for spring
  238. trying to fuigure out what clutch i have
  239. 04' Accord V6 Tranny problems + codes
  240. Do USDM Prelude/Accord internals fit into M2B4 transmissions? Failure pics inside
  241. tranny compatibility
  242. Tranny gears all mixed up?
  243. P/s on Non-P/s on Ek
  244. M Factory Gears 3-4-5
  245. Clutch/Flywheel or transmission problem?
  246. i need help with my diff
  247. help needed !!!!!!
  248. H/F Series Transmission Internals
  249. "cricket chirping sound. Please help.
  250. Need help ASAP
