- Won't go into Reverse
- Hard time shifting
- Transmission Problem with 2001 Honda Odyssey
- Help Identifying this lsd??
- 95 integra, b18a1 motor
- h2a5
- f20b sir-t tranny identification
- 89 crx-b18b.ls cable trans,can put it into gear unless its off
- What clutch to use for Gsr tranny on stock LS engine?
- Itr helical would it fit
- JDM EF9 help
- torque mount
- Shifting without using the clutch
- Cable trans. help,Clutch woes after reinstall
- M2B4 LSD internals mix with USDM 5th gen tranny
- Transmission for a 95 civic ex
- Hot Tranny!
- Honda Civic 5SPD MT 2002 EX Leaking oil
- 98 Civic Auto trans concern
- YS1 on B16A1 with Y2 stock
- OBX Warranty Registration Card for LSD
- H22 trans, shifter cables/bushings???? where to buy
- Let me tell you about Synchrotech Transmissions customer service...
- competition clutch issue
- B16aSiRII w/ LS-TRANS? WHY?!?!
- BMW Transmission problem Need honda guru's help!
- why 'No' to power flush ?
- Competition Clutch Super Single
- 98 Civic Automatic Transmission just loses all gears out of no where!
- B16 cable LSD
- NEED HELP!! Axle keeps popping out
- Are these still usable?
- need a "how to" on throttle valve cable adjustment
- Dave:
- need clutch advice for my awd converted hatch
- Can I use a B18A1 from an automatic in a 5 speed?
- help ..worried
- Would it be ok if...
- auto trans problem
- Settings for FN2 gearbox
- Why Honda uses MTF instead Valvuline
- help with transmission stuck in gear
- 89 Accord Auto Transmission
- Clutch cable?
- ys1 cable trans wont go into gear.
- 4.05 Final drive ratio for K20A2
- CVT Trans Problems
- 99 civic shifter issues
- Doing a rebuild on D series transmission, is needle bearing required to replace?
- lude cv into civic hub???
- wait!! another LSD question!?
- Clutch wont engage!
- Please HELP! Clutch broke...
- jdm lsd
- 98 gsr tranny noise
- whats a good clutch? need opinions on a good clutch for '98 2dr civic d16 sohc vtec
- Need Itr lsd housing.. or conplete burnt up lsd
- Final Drive 4.400, 4.785 or 4.928?
- Cable B series ratio help. Is my math incorrect?
- 90 Civic SI Tranny Problem
- Automatic Transmission Failing
- YS1 cable trans
- B18 Tranny Problems
- Ef automatic trans issues *help*
- honda civic d15b non v clutch chatter???? help
- Quick question! b18 LSD.
- OEM D15B Vtec LSD, How bad are they?
- S2000 InLine Pro Needs Clutch
- Grind when letting off clutch?
- gear ratio help! gsr/ b16
- clutch return/assist spring?
- Putting Z3 guts in an A2 case
- Clutch master not enough travel, adjustment is way out
- Gearbox crunch (after rebuild)
- 98 Accord V6 reman tran in 12/07 iffy?
- s4c b16 internals in a y80 trans case
- I need help figuring out what lsd this is
- front end 5 lug conversion ?
- GSR transmission problems
- 2000 Accord Tranny
- lose differential bearing?
- Honda delsol D16Z6 bad transmission HELP!
- JDM ITR transmission??
- 2001 civic D17A2 manual trans problem
- Synchronizer wear rate with dragging clutch
- Clutch problems!! Help
- Loss of pressure in clutch pedal
- Auto '99 civic Squeaking only in gear
- shifting not smooth at all....
- I need dog box/str8 cuts
- odd differential request
- new competition clutch problem??
- I found where to get GM synchromesh - FRICTION MODIFIED! tansmission fluid!
- Clutch for 260whp/225wtq turbo Prelude
- Clutch?
- 2001 honda civic slipping
- ls trans options.
- Fearless Noob--Trans sealing question
- Will this break my transmission?
- fixing a 3rd gear grind in a gsr trans, pics included
- H-Pattren to Sequential Shifter
- Transmission rebuild kit with KONI and NACHI bearings??
- Fixing a 5th gear issue on a D16y8 - tranny porn!
- Inline four syncros anyone use them?
- B16 Tranny Question
- 97 integra hard downshift
- 97-01 CRV FRONT 5 LUG HUBS ON EK SEDAN
- Way to figure out my speed?
- E7F to E5F conversion??????
- Anyone ever use the XTD flywheels with Exedy stage 1 clutch ??
- D16Z6 CLUTCH REPLACEMENT HELP WITH SELECTION
- Difference between GSR/ITR and B16/LS differential bearings
- Clutch options & Tranny fluid/Oil
- Questions regarding Transmission, PCM, and Fuel regulator
- D16z6 auto tranny problems
- just blew up my second clutch slave cylinder in 4 months
- Help with trany options.
- Manual conversion
- Driveshaft Shop's Holiday Schedule
- 01 civic manual trans problem
- Throw Out Bearing Fork?
- D16 clutch install ! Flywheel resurface??? Yeh or nah?
- EK gear ratios?
- What gearbox can handle 700whp k24 turbo?
- what to look for?
- A little Info From Driveshaft Shop
- Too much ATF
- 2000 accord transmission is frustrating
- Need a DIY for removal of s40 tranny!
- B16 (S4C) *pops* out of second but only some time and randomly.
- wats the difference between gsr tranny and ls tranny and wich one is beter for racing
- D15B7/D16Z6 Head (Mini Me Swap)
- Need help asap!! 4.40 fd on ls tranny
- 2000 gsr tranny high pitch whine
- ls tranny help!
- 2000 civic ex
- L3 cable LSD transmission. can i switch bellhousing to make hydro?
- 6 speed tranny?
- AC Compettiton Super Single? Your thoughts...
- Car killing cold misery, cabin fever homicidal rage, and that's on the good days
- Replacing Input Shaft Bearing
- H22 swap axle problem
- 2nd gear doesnt go in and sometimes grind?
- 1987 CRX HF transmission swap problems
- anyone know the torque capacity specs on OEM exedy clutch?
- Intermediate Shaft ?'s
- car wont shift into gears stick
- Feedback on reman Advance Auto Starter
- Wheel hop after changing out a strut.
- Changed manual tranny fluid, concerned I didn't put enough in
- Honda MTF-III Ultra
- gsr trans itr lsd trans problem
- Replacing a torn axel boot questions!
- b16 tranny w/ damaged thread
- Weird transmission problems (B Series)
- checking tranny outside of car ??
- Cable 5th Gear Swap Y1/S1/YS1
- X2M5 Countershaft disassembly Diagram Please help with pics!
- My clutch is messing with me...
- S80 hydro guts in YS1 case with Mfactory helical lsd?
- Technical Manual on 2001 Accord Automatic?
- Slow Shift Back to First on 2001 Accord Automatic
- Clutch and flywheel question
- Any one use Uncle Scotty's Cocktail in their car?
- need tranny info
- Shady Tree Mechanic with d16y8 Tranny Problems help troubleshoot!?
- 2001 honda civic 1.7 transmission swap
- Diving into my transmission
- Civic Manual Transmission help. which to buy?
- CLutch Issue
- S80 to AWD CR-V tranny
- TRANS INTERCHANGE ????
- Ls tranny???
- my car wont go into gear!
- 98 civic 5-speed pops out of second. Fix?
- The best clutch for the best price
- GSR trans tear down what is this??????
- Help identyfiing this B Series LSD OEM or Aftermarket?
- s1 cable and itr hydro internals swap
- lots of play in clutch fork??
- Ls trans build gear question
- replacing clutch/flywheel what seals do i need? 95 integra ls
- Clunking when pushing in clutch to shift
- Honda MTF and Mobilfluid 242
- Problem with Acceleration
- EM2 AUTO Tranny issue, need insight.
- What fluid should i use?
- 1st gear popout 2nd grinds nasty
- H22 Clutch ~300WHP
- Stumped
- del Sol B16A tranny, with 90 DA LS axles in a 90 ED6, axle seals? lol
- ATS & Across Single Carbon Clutch Warm Up Procedure?
- Change Final Drive Ratio?
- b16 1st thru 4th with ls 5th
- B20 tranny and ls engine a good matchup
- Transmission does not shift.
- Hydro & Cable LS tranny gear swapping??
- What type of trans oil is everybody using?
- GSP Axles
- strange sound when clutch is releasing
- No tension in clutch
- Problems with my clucth.....PLEASE HELP...
- new clutch high rpm shift problems
- Has anyone else ever sheared off an axle spline?
- Problem with transmission or clutch!
- auto transmission problem cannot pass smog
- Gearbox question
- What is this ? - LSD
- 90 civic hb passenger side aXEL doesnt fit .. help !!
- Need opinions on switching gears/final drive
- DSS 2.9s
- What is this Plug?
- too much transmission loss.....why ?
- strange muted clicking noise?
- How can i tell what gear box in my EG ??
- J1 tranny troubleshoot
- 1997 Honda Civic : symptoms of worn clutch?
- Rebuilding Axles, Got A Question!?!? Pictures Inside
- transmission bearing
- Clutchmasters
- clutch pedal strait to the floor
- Axles
- S1 trans no 5th gear !
- 92 Civic Wont shift!
- Transmission/clutch noise as increase in gear help
- 90 accourd clutch fork
- clutch pedal problem?
- What cables are compatable
- H22 tranny problem help plz
- sleeve hub question
- Servicing 98 Civic LX auto trans
- b16 swap cable tranny into eg ???
- gsr trans problem..please help asap
- Car won't go in gear when on, new clutch CMC and CSC
- *******AXLE NUT SNAPPED OFF??********
- GSR SHIFT FORKS!!!!!ADVICE
- Hydro clutch gets stiff very quickly
- does the jdm itr 4.7 share the 5th gear from the gsr
- Stuck in Park
- B16 ring gear on GSR?
- NOT GOING INTO GEAR @ HIGH RPM AND SHIFTS FINE @ LOWER RPM!!!
- richmond spool question reliable??
- 2001 Honda Accord EX Tranny Issue
- Honda Civic Hybrid: Transmission Problems: Won't honour extended warranty
- Bleeding a Clutch on Cable trans
- Easy to replace a Pressure Control Solenoid?
- Serious Hydro Clutch Issue
- Someone help pleasee. Clutch
- drive shaft shop or gator axles
- Clutch/ Pressure plate
