Gsr clutch/Trans HELP!!!
I have a ek with a Gsr motor and trans, I had to replace the clutch so I just picked up a whole kit. Clutch, flywheel, pressure plate, pilot and throw out bearing. Also had the main shaft bearing inside the housing changed as it was needed. So here are my symptoms after putting everything back together and torquing down to specs...1) hard to shift into any gear, I gotta slam it in. 2) it's almost as if the clutch doesn't disengage, with out the pedal pressed if I move the shifter towards a gear the axels start to spin. Although I can feel it not fully in gear. 3) I can't shift into reverse, I just get a loud grinding noise. 4) when the car is off it feels like it shifts fine into all the gears including reverse.... I bled the the master cylinder, checked the slave, re tightened down the shift linkage.
any help is appreciated, thanks guys
-Marc
-Marc
jdm_phunk
02-27-2011 05:17 PM
