- CAR WONT GO INTO 5th or REVERSE
- 06 rsx 5spd trans issue
- need help /w h22 trans or drivetrain!!clunking noise.
- YS1 and Y80
- HELP! How can i tell these two transmissions apart?!!?
- Transmission shop Nor Cal
- Transmission blows.
- LSD in H-series transmission
- URGENT HELP NEEDED: Clutch problem
- Resurface flywheel? (pics)
- Broken Differential ??
- d16 transmission help!
- comp. clutch stage 5 kit, tranny cant get into gears @ high rpm
- S2000 clutch master clyinder in EK9
- Lost 3rd gear on my hydro GSR tranny
- Creaking noise??
- GSR LSD problem? Binding grinding popping when turning
- Where to buy single synchro ring for B16?
- counter shaft bearing
- Replacement LSDs for autos
- ys1 gear ratio
- Short Throw Shifter - Prelude
- Need a Clutch Recommendation
- final drive?
- Grinding noise when clutch pedal released any gear + neutral
- Quick history on Honda Automatic Transmissions
- Making a Short Throw Shifter
- which tranny for a 90 hatch...gsr..l8er to boost
- 2nd gear problem
- How to remove D15 differential from gearbox?
- Lateral slop INSIDE tranny
- 4th gear issue
- Mixing and matching B and D series gears
- stumped on transmission issue.
- competition twin disk problems
- Aftermarket LSD VSS gears
- 00 LS Case on 00 ITR JDM Bellhouse
- tranny place info.
- AT box Turbo questions
- Thumbs down for Competition Clutch, never willl buy again!
- 1999 Odyssey Tranny shifting delays
- Need Help b16 tranny question......
- Which CV joints?
- syncro identification
- transmission noise! good tranny??
- Rough/Hard clutch pedal
- need opinion on clutch and flywheel (limited funds)
- stoopid ? short throw hurt trans?
- type R tranny question..
- Help!!Clutch Master cylinder EG6
- speed sensor problems
- B16 tranny rebuild question
- Are the D and B VSS interchangeable?
- Is my clutch worn/damaged, or my tranny fluid low/spent?
- clutch kit
- whine/grind video, ISB? plz help
- b16 w/lsd vs. ITR
- Differential gone?
- spec clutch ?
- tranny feels hung in gear...
- cable 5th gear in hydro tranny?
- Gsr Transmission Problem that doesnt make sense...
- NEED HELP with a slave cylinder problem possibly???? H22 swap and the slave wont fit
- final drive VS close gear ratio
- hydro B16 trans w 3.307 1st?
- Not going into gears when car is turned on GSR trans
- odd feel in the shifter.
- Replacement gears for y1 transmission
- LSblock GSR trans. Why wont halfshaft fit?!
- Quaife QDF1U bolts
- f1 clutch kit stage 1 2 or 3 any good ???
- Blown tranny?
- about to do my first honda clutch, few ?'s
- ITR Trans question - Will this trans fit
- single bend or duel bend?
- 92-95 Si transmission issue
- need HELP. asap. 2nd 4th reverse gone. well sometimes
- liberty..where to get
- Exedy stage 2 Clutch & flywheel question
- How can i take the grinding of my third gear?
- EG auto tranny in EF
- Wear on D-series '96 - '00 Steel Forks
- Weird Transmission problem-GSR
- cable to hydro
- Checking automatic trans fluid - more or less?
- lightweight flywheel
- 86 crx si shift lever torque rod Question
- About 99 civic EX coupe clutch~please help`~
- What diff is this?
- Type R tranny Vs Gsr Tranny
- BG Syncro Shift II
- B&M DUAL BEND SHORT SHIFTER...FUNKY QUESTION...
- trans argument
- Turbo H22, with M2A4 trans Question
- fix hx tranny or get ex?......tranny noise in hx
- What clutch to run with high hp d16 boosted and built
- TRANSMISSION PROBLEMS?
- ???? about what clutch
- when replacing a clutch what else do i replace
- motul ff2 suppliers ?
- Engine Over Rev Problem
- Transmission issues
- Possible ISB Problem
- s4C ek9 ctr transmission value ?
- Stage 3 Clutch
- cv axles
- I Need a k20z3 tranny rebuilt asap in socal
- dropping the trans
- 1998 Accord V6 Transmission Flush
- Cable clutch setup
- does anyone know of a company that makes an f2d kit?
- B16 tranny cable help with pic inside
- mfactory FD and lsd problem
- axle and Wheel bearing problem. 04 TL
- Strange Transmission issue with B18B swapped civic
- Converting CRV Rear Diff from real-time to "full-time"
- carbon syncros vs stock (brass?) syncros for gsr s80
- What is the dog ring setup to go with
- clutch for first gen b16a w/ hydro trans?
- which transmission is this?
- Differences...S80
- Broke something..... help please
- b18b Tranny Help
- f20 to d series tranny?
- what tranny?!?
- NEED TO KNOW IF MY TRANSMISSION IS OUT! NEED HELP ASAP
- NEED HELP ASAP!!!!! Clutch issue? Mounts?
- help with a mini me swap!
- Dropping a Tranny??
- b16a transmission with lsd price?
- transmission leaking fluid
- tranny adice needed
- Need advice on what LSD to go with??????
- Lightenend flywhel and unsprung heavy duty clutch
- weird problem with ACT clutch
- bearing stuck in 1996 gsr (s80) transmission!!!
- 1st and 2nd Gear hard to go into???
- Identifying B-Series Tranny. Cable/Hydro??
- physical look LSD and no LSD gearbox
- I need to know if this is normal.
- removing reverse synchro ring
- slave cylinder, pressure plate or isb? Need experienced help
- tranny cases
- Loose shifter even in gear...?!?
- ClutchNet
- intermediate shaft
- 95 civic ex engine will accelerate but vehicle speed slowly accelerates
- Ever put a hydro gsr ring gear in a hydro ls?
- O/T Avalanche Tranny flushed serviced !
- which trans do i have?
- difference in clutch
- Clutch won't disengage
- tranny problem, please help.
- anyone know where i can get an ITR 4.78 14 tooth countershaft?
- Need Help On Swapping to Stick.
- 4th gear out, 3rd gear now on the verge
- want to swap to manual
- WTB: 6 puck pressure plate for b18
- transmission problem?
- Grinding/Scraping noise when CC twin clutch is pushed in?
- 90 - 93 accord tranny problem.... please help (auto)
- 3rd gear grind itr tranny
- Differences between Hydro and Cable clutches
- crx auto tranny issues
- Tricks to getting snap ring on trans.
- tranny stuck in gear
- Tearing down a tranny, is that a LSD!?
- dss 3.9(stage 5) boots
- Full-face vs. 6-Puck
- LS Tranny/Clutch Help.. Possibly throw-out bearing? or plate?_
- h22 eg /w innovative mounts. What Axles?
- What are my differential options?
- ITR tranny with viscous LSD
- Shifter bearing/bushing diameter?
- Hydro PP with cable clutch?
- 92 GSR tranny hard to get into 2nd gear!!
- Where do you put the transmission fluid?
- Transmission problems
- how can u tell its LSD?
- Re-greasing the intermediate shaft?
- Shifter not returning to Neutral??
- Tranny probs
- Can you identify this clutch type LSD?
- Type R 5th gear into b16 cable
- b16a with OBX Lsd what transmission oil to use ?
- What grease to use on the clutch shaft?
- Gearbox problem..Ctr EP3
- tranny case wont close
- B16 tranny shifting problems, I need a clue
- Y1 hub and sleeve kit
- Clutch line no pressure !!! please help
- clutch + flywheel decision
- release bearing troubles?
- Clutch/Trans diagnosis...please look
- Years/models with defective auto trannies?
- Trans+clutch housing weight
- Trans/clutch case and mainshaft and countershaft weight
- D series Trans question
- Competition Clutch customer service RULES!
- ring gears?
- Help!!!!1998 Acura CL traansmission help
- b16 tranny whining
- Clutch slave cylinder issues
- just bought a civic with tranny noise,trying to get an idea what it is
- 88 trans in 97 civic?
- Inner Tranny splines Passenger side, normal sound? *Video* Please help!
- Bad Noise in tranny with *Video/Sound* Please help.
- Too Many Clutches, which one?
- S20 / S40 Hybrid - Can't get housing together
- Type R LSD how much HP
- Y2-1006242 box, anybody know some details about it?
- 01 Accord LX-V6, dead tranny, worth fixing myself?
- exedy clutches on Ebay?
- b series trans/clutch problem help!!!
- Clutch issues, slips into 4th, lol
- Spec clutch
- D4 flashes HELP!!!
- which 5th gear
- question about pressure plate and flywheel
- using a b18 cable trans in a 95 civic
- Trans code p0720 help, please.
- Replacement of CV boot via outer joint - A guide and some tips
- Too many miles for auto fuild change?
- Phantom Grip question
- Tranny or clutch, can't shift into 5th
- Whats the best way to get dirt out of a manual transmission?
- grinds when shifting.
- Best way to overhaul bad transmission? Rebuild?
- competition clutch kit 8022-1620 (6-puk) authentic?
- vibration when on load..
- tranny casing
- i have a ? about the c-clip
- Remove CV boot via outer joint?
- witch tranny is good for turbo?
- Anyone know where I can purchase a new disc 4 this?
- Affordable LSD options
- 92/95 ex/si tranny bearing sizes
- tranmisson fluid help!
- My clutch is brokeded. Help wanted.
- CV Joint Snap Ring Problem
- NEED INFO!!! ratio rt4wd s22 hydro tranny
- 96 civic DX Tansmission still leaking after replacing output seal
- Which manual transmission fluid would you recommend?
- HELP B16a CABLE TRANSMISSION CLUTCH REPLACEMENT???
- Help Diagnosing an Transmission Issue
- Aftermarket Synchro Springs
- Garage Transmission Swap
- Help Diagnosing Drivetrain Failure
- why is a brand new clutch slipping
