PDA
View Full Version : Transmission & Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. Disappointed with Raxles
  2. 89 b16 lsd & diff into 93 ys1 case?
  3. Rebuilt BAXA question
  4. Cracked Tranny case?
  5. 2001 Honda Accord V6 trans fluid leak
  6. gsr tranny issue..
  7. innovative mounts hydro to cable conversion kit wright up
  8. 2002 Accord V6 auto swap manual!?
  9. Please help. I don't know what's going on??
  10. How to recognize Mfactory LSD
  11. Here's my input shaft diameter, what clutch do I need?
  12. 92 vx trans fluid
  13. Need help/input with a very strange issue..
  14. Need a manual tranny for D16y7
  15. Which ACT clutch kit for h23a vtec?
  16. Can you swap an LS 5th gear into a B16 S4C ?
  17. 97 civic 5 spd tranny won't work? Swap or fix?
  18. aamco tranny parts?
  19. how do i tell what tranny i have?
  20. need clutch advice
  21. does a Mfactory B18LSD fit in a B16 with a ITR FD ?
  22. B18 Linkage question..
  23. shifter bushings
  24. 99 accord wont shift into reverse. all other gears work.
  25. She won't move... is my tranny done?
  26. What clutch should I get gsr turbo
  27. tranny rebuild
  28. squishy clutch cold weather.
  29. B-series trans wont shift into reverse.
  30. Help with shifting
  31. Are clutch disks interchangeable?
  32. Stock z6 trans will not go into gear
  33. cv joints in a b18 swap
  34. h22 shifter and cables work on kseries?
  35. Passenger CV axle
  36. Gear grinding problems!
  37. 1999 Honda Accord LX stuck in first gear
  38. Honda Logo 1.3 GA3 - N/S Drive Shaft Seal Leak - Help?!
  39. 1/8" gap between axle housing and tranny housing
  40. quick LSD question
  41. LSD for UKDM Y2 Transmission
  42. Car jolts while in first gear!!!
  43. Clutch Life (EG9 OWNERS ONLY!)
  44. what clutch for b20
  45. H22 H23 F1 Racing Clutch and 11.5 Flywheel
  46. s4c ctr trans issue
  47. 90 acura int GS Shifting trouble 1st and reverse so far.
  48. B20 tranny ratios?
  49. 1997 Civic Clutch Pedal issues
  50. Main shaft sticking out too far?
  51. So what all did I break?
  52. what are gates in a manual transmission?
  53. 02 Civic Auto Transmission slips
  54. Bbk ssi intake questions
  55. Broken Tranny Bolt stuck in engin. Help!
  56. 1995 passport 4x4 axle help!
  57. LS trans with 3-4 gear from a b16 trans.
  58. B series tranny question
  59. 00 SI tranny problems
  60. Do these gears+ look OK?
  61. LSD Tranny
  62. s2000 transmission
  63. 3-4th grind? :S
  64. After a manual trans swap, shifter does not work properly
  65. MPH Gauge Help
  66. B18B1 NEED A TRANNY TO PUT WITH IT
  67. Cable to Hydraulic Tranmission
  68. Auto d eg to manual d eg
  69. Reverse gear issues
  70. Putting an s40 back together
  71. 99 Accord 140k: Tranny rebuilt, wait for it to die or buy a new car?
  72. "Whirring" in first gear and reverse
  73. Clicking or gear spinning sound while rolling?
  74. need new clutch!
  75. auto d to manual b issues
  76. B Series Flywheel
  77. Where to buy some differential bearings for a BAXA?
  78. Differential Problem quick ?
  79. K series 5->6 speed conversion problem?
  80. EM2 Transmission Options
  81. S4C B16 Tranny Rebuild
  82. Which can be a good make for a CV boot
  83. Automatic Transmission Repair or Replace
  84. choosing a transmission
  85. b16 trans pops out in 5th
  86. Axle/Transmission question
  87. s2k turbo tranny
  88. Synchrotech New Product: K Series 1-2 Sleeve
  89. Clutchless shifting
  90. 96 civic dx hatch f20b swap
  91. B16a tranny whining noise
  92. CV Axle 94-01 integra B18b
  93. How to clean schrapnel from auto trans
  94. Honda 1976Civic CVCC Clutch Replacement
  95. 2nd gear clutch chatter. UGHHHH
  96. automatic to 5 speed
  97. Rebuilding S40 transmission, should I buy a used one for parts?
  98. trans swap
  99. input shaft bearing noise?
  100. skunk2 shifter?
  101. input shaft bearing noise?
  102. cable dohc tranny
  103. Gsr trans, locked in gear with shifter movable.
  104. Ys1 Trans wont grab any gear?
  105. Clutch not disengaging? Bad shift linkage?
  106. JB Welded bell housing
  107. casing not closing (pics)
  108. What's better a itr 96-97 tranny vs 98+ itr tranny vs gsr lsd?
  109. What's better a itr 96-97 tranny vs 98+ itr tranny vs gsr lsd?
  110. Re shimming GSR transmission mainshaft after changing to ls outer casing?
  111. Tranny shift link
  112. Converting Gsr Differential bearings from tapered to roller/type r style (Need help)
  113. 94 accord ATF Change
  114. need help with tranny
  115. HONDA CRV year 2000 model Petrol, Manual
  116. Help identifying transmission problems
  117. Using a Smaller Trans Spline with a bigger Clutch Spline hole
  118. B16 Trans Mounting bolts
  119. clutch / transmission
  120. HELP WITH 98 CIVIC AUTOMATIC TRANSMISSION
  121. 2006 Accord jerky at 40-50 mph
  122. S80 trans build help
  123. I need help identifying transmission issue.
  124. Transmission slop troubleshooting help
  125. TRANNY REBUILD - what gears to use
  126. HELP!! Y8 question
  127. Trans Question
  128. 98 civic ex automatic/electrical problem
  129. 1997 passport trans issues
  130. axle problem
  131. help with T2T4 trans mated to a F20B
  132. saenz k-series sequential dog engagement conversion...
  133. Short shifter durability in harsh climates?
  134. p0700 code on 98 el
  135. 08 accord cold start rattle
  136. thow out bearing
  137. Teggy auto shift lock issue
  138. 2000 civic(auto) bangs into gear,"d" light blinking,no acceleration,erratic idle
  139. Gsr trans trans in 5th shifter moves through gears. Help?
  140. my peddle is so hard
  141. 96 accord p0753 cant even reset it...??? code troubles,can anybody help?
  142. transmission issues
  143. replaced input shaft bearing in ys1, now shifteris hard to move side to side...
  144. Sticky Clutch Pedal.. HELP PLS!!!
  145. transmission
  146. Does LSD Come in cable
  147. Jerk from P to D after sitting for awhile
  148. clutch help
  149. Any ideas about this LSD...
  150. Auto Transmission Whine from Reverse? Please help
  151. trans issue...?
  152. 88 Honda Accord, clutch or transmission
  153. I need help with the Material Properties of a B series Transmission
  154. GSR Trans... just swapped ITR diff... car does not move
  155. What clutch is better or is best for n/a motor b series
  156. would this work B16/gsr lsd transmission
  157. lsd stuck in full time positive
  158. transmission help. gsr
  159. Transmission Fluid
  160. Help identifying VSS's
  161. trans/ecoboost vibration
  162. gsr tranny clutch problem help
  163. d16z6 trans leak!
  164. d16 tranny question
  165. trans case has stress cracks?
  166. 96 accord code p0720 tried everything! hellppp...!!!
  167. 94 civic ex tranny problems?
  168. d16y7 manual transmission problems !!
  169. How to replace the cv shaft seal on a 1998 Honda civic ex?
  170. j1 or s1 4.4 fd in my y1 tranny???
  171. ls tranny stuck in 2nd gear help!!!!!!!!
  172. D-series L3 and P20 final gears
  173. Transmission bearing on it's way out?
  174. Transmission bearing on it's way out? 99 civic ex
  175. Lsd/axle question--- not tech
  176. Race Transmission Recipes.
  177. 1990 honda civic dx transmission leak?
  178. Input shaft won't slide into place (gear gap)
  179. B18C5 Clutch Slave
  180. Clutchmasters FX500 Mix/Match w/ other mfr discs?
  181. clutch or syncro problem???
  182. 94 civic clutch pedal issue
  183. Noise from Engine Compartment
  184. Roaring Noise While Moving
  185. 1991 Accord "S" light flashing
  186. trans problems after rebuild,gurus chime in
  187. LSD Speed sensor with plates clutch differ?
  188. CL1 Euro r torneo vibration..Help..
  189. 96 civic clutch
  190. clutch disc questions
  191. Limited slip conversion
  192. all b series cases the same? or swappable?
  193. 98 civic gear selector help!!
  194. Need help! ASAP!!!
  195. Fit and Civic trans compatibility?
  196. idk clucth or tranny?
  197. good clutch for D16A6
  198. s40 bad diff bearings ?
  199. 1999 accord wont go into reverse.
  200. Type r trans eating 5th gears
  201. ls cable transmission clutch fork wont come out
  202. Automatic Transmission on 2004 Honda Accord
  203. 89 civic auto trans selector moves but stays in gear
  204. 96 civic with swap tranny\axel alignment issues
  205. Accord Vibration
  206. HELP leaking tranny fluid!
  207. Synchro spring...what is its Mechanical Function?
  208. Rebuilding tranny need help!!!
  209. 1996 civic cx hatch
  210. A BIG thumbs down to ACT...
  211. shift linkage loose in gear
  212. 96 civic engine swap for a f22 b2
  213. Cable-Hyrdo Trans Help
  214. 2000 Integ. LS Trans. Slipping???
  215. **SEMA SHOW 2012**
  216. what are the consequences of driving on a bad throwout bearing?
  217. B16 or ls tranny
  218. i need help please.
  219. Help identifying motor and trans
  220. 91 integra automatic issues
  221. need help ASAP
  222. leaking tranny from shifter
  223. need transmission help asap!!!
  224. close gear for a sohc d15b
  225. gsr tranny
  226. Cusco LSD
  227. gsr tranny vs. b16 tranny
  228. 95 gsr trans rebuild and adding LSD
  229. Gsr Tranny Help! Hard to shift into gears!
  230. manual transmission oil
  231. b series exedy twin disk clutch what TOB to use?
  232. Tran help! What years will fit my 99 Automatic?
  233. LSD Question-Problem
  234. tranny, flywheel? pls help
  235. HT opinion
  236. auto tranny stuck on first
  237. Transmission problem!!
  238. BAXA OR MAXA automatic
  239. Differential bolt question
  240. 96 Accord AT problem
  241. Acura 6MT helical 1.5 LSD a drop-in for Honda Accord 6MT with 89C7 tranny?
  242. Hydro B-Series Clutch, Pressure Plate or Flywheel Issue
  243. 2000 odyssey OD light blinking
  244. swapping b16 gears into a gsr trans
  245. clutch noise?
  246. Tech Tip - B series Final Drive Identification
  247. clutch problem!!
  248. Swapped B16a Tranny id?
  249. y8 trans, rail detents causing no/hard shift
  250. Clutch not fully disengaging..
