- auto tranny shift problems
- Rebuilt trans making noise
- Teal/Light Blue Tranny fluid, what is it?
- axles wont seat all the way into transmission
- Stripped a ring gear bolt
- Jdm Type r gearbox problems
- Where to get a braided clutch line
- 2006 Civic ATF change
- Any G-Force Dog Box users?
- uneven clutch wear
- Tranny Housing Gasket
- vibration under acceleration....tranny?
- Pop outs Need help with Tranny problem...
- Clutch disc and Pressure plate relationships
- Type r Trans
- Best gearing for 1320 in ITR tranny?
- anyone know dseriers transsmission numbers
- Got my tranny together last night and installed today, still got a problem
- Skunk2 Short Throw Shifter
- Problem installing Skunk2 Dual Bend Short Shifter, Washers not fitting in bearing
- 98 civic DX coupe loud noise??
- torque specs
- 2004 Accord Cpe V6 auto tranny swap options?
- Trans redone, grinds going into 5th
- Honda Stepwagon Auto Transmission
- 93 civic transmission problem?
- question about 2007 si transmision
- looking for manual tranmission
- shift linkage replacement
- choosing clutch....
- Gear X final drive?
- Can I eliminate "vss" needs?
- B16A Tranny Trouble
- List reputable and non-reputable individuals and companies to buy trannys from
- oem tranny parts help ...
- tranny case ring
- Clutch not performing corectly
- catastrophic clutch failure
- Transmission dowel pins required?
- Need help on axle popping out
- Identify 2.105 2nd gear
- Speedo not working?
- what caused my gsr tranny's countershaft's teeth to break?
- I need some opinions [weird noises]
- Flywheel Queastion.
- clutch trouble
- how to break in a new clutch
- Need Help B16 Transmission
- JDM H22A Automatic, No Overdrive
- cable and hydro tranny question
- Hard to shift when the trans is hot
- 3RD GEAR PROBLEM
- True Life: Nite*Grind Transmissions ( what I do on the reg. )
- What should be considered when replacing Input Shaft Bearing?
- Starters
- ys1 gears into a hydro case
- da tranny into dc2 questions
- 2003 V6 accord auto tranny problems J30A4
- Any transmission guys?
- gear interchangability (if thats a word)
- Tranny Trouble
- b18b1 clutch won't disengage
- Help! Identify this LSD!!!! (Picture inside)
- boost ls, new cluch and flywheels questions
- torque specs for 4.40 final drive?
- GSR trannys??
- no engagement/what did i do wrong
- finding/ordering b16 ys1 dipstick? and using synromesh?
- RWD Honda V6 Transmission
- BAD CLUTCH!????
- GSR trans issue new clutch....LOST
- need help asap trans d series just put in no worky
- b16 trans install problem
- Tranny: rotation grinding sound at 4 500 rpm
- A/T : B-series kickdown cable ?
- What should I do?
- Positraction
- H22a tranny
- Rebuildin transmission
- L3/s20 internals?
- b16j1 case wont open all of the way...
- Trouble going into 2nd, 3rd and sometimes 4th
- gsr popping out of 4th after cuff install.
- 5 speed 99 honda odyssey
- H22 trans help.
- does honda still sell cable trans parts??
- Need help removing stripped Fill bolt on D16z6 5-speed Tranny
- gears are grinding ..HELP!!!!!!!!
- Whats a good tranny fluid for a D16z6 5-speed?
- integra trans question(s)
- Any suggestions for input shaft bearing and throw out bearing problems...
- transmission bogs down in reverse
- transmission kicking out of reverse
- Stubborn 4th gear- Synchros?
- Question about adding 4.9 Final Drive in ~ 180Whp Gsr
- Tranny Issue: Attention HondaBull and ALL tranny gurus
- can lsd cause clunking?
- car still wont go into gear, replaced numerous parts
- 1990-93 Accord Tranny question
- 40mm ZC LSD into S20 35mm D15B tranny?
- Whats are some good clutches for 90 dollars d16z6 si/ex tranny b000
- Chewed up diff on non lsd b16 j1 cable
- Clutch chatter, please help!
- intermediate shaft + axles length
- b16a rebuilt trans pops out of 1st
- Will my gsr hydro tranny work in my 90 integra ls?
- clutch fitiment issue.
- intermediate shaft on LS Transmission
- Are spec clutch and flywheel any good?
- Help me diagnose my Tranny PROBLEM!
- quartermaster 5.5 inch tripple clutch
- ANY LSD for the ZC L3 trans?
- Will MP1A replace APX4 application?
- 91 accord ex APX4 tranny shifts rough
- Cryogenic Treatment on Axles?
- auto to manual reverse lights dnt work ek coupe
- Which twin disc do you prefer?
- clutch problems
- ls gearset on gsr shafts?
- lsd swap question...
- 99 civic ex trans howls both when at idle and in motion
- Cable Diff in a Hydraulic Trans.
- 98 Type R Final Drive substitutes
- What clutch can I get with a 350 dollar budget and I am trying make 400hp with it
- Gear-X 4.9 question
- What tranny is better for a 400whp plus d16z6 ex or dx tranny
- 1990 Accord Trans Problem
- Trans wont go into all gears
- Hydro to cable conversion won't go in gear now?
- options getting 3rd not to grind
- 98 integra tranny flush, quick question.
- Intermediate shaft seperated
- need help is this the tranmission problem?
- Teeth number in S4C/Y21 and S80 transmission
- clutch pedal feel - plate or disc responsible ?
- delete this
- twin engagement problems
- flywheel question weight questing
- what clutch setup and whats my problem?
- sh trans f22 hybrid
- top of mainshaft bearing not seated
- tranny probs
- Was grinding/popping out of fourth, now won't go in at all
- How to identify the difference between KAAZ & Quaife lsd on YS1 TRANNY *HELP*
- Hub Assembly Question
- which RSX short shifter is better?
- Searching for a LSD.
- Wheel Hub Assembly Question
- 400Whp/300Wtq tranny options
- Clutch problems
- Weird clutch engagement problem
- Having tough time getting out of gear with 6puck
- anybody used street imports drive shaft?
- Clutchmasters Stage 5 FX500 Sintered Iron
- used tranny bad signs?
- b16 lsd in s1 tranny
- Will gsr gears fit in my B16 tranny
- 1990 LS gears in my 1993 GSR gearbox
- 4wd
- Anyway to use my Quaife LSD from b16 in a GSR?
- I love it when this happens...pics included
- My OBX lsd Review/short and sweet///pictures added
- Shim clearance ??
- Help with my H-F series tranny!!!
- 4.9 FD in D15 non vtec?Is it a good start?
- EXEDY ceramatallic stage 2 or Competition stage 5
- Removing the Transmission
- K20A2 trany with ATS dif..what Oil?
- Difficult to shift into 3rd and 4th
- B Series LSD Compatability
- shifter moves while in gear?
- Where can I get LSD for SOHC?
- Shelf life of Honda MTF?
- Locked out of reverse?
- backwards making noise
- Help, Axel Leak
- Need to change my clutch on my d16...need help.
- diff or diff bearings???
- ITR LSD trans question! please help
- innovative cable trans in hydro car info
- locked out of 1st 2nd and reverse
- Anyone swap a y8 trans onto a d16y7?
- What variables can cause excessive tranny problems?
- 06 civic si 6speed swap to base model 04 rsx
- Acura Integra Transmission Compatibility
- My ITR trans grinds 2nd gear, what i need to do to fix it?
- Are these parts interchangable?
- cable to hydro conversion
- Second gear hard to shift at high RPMs
- GSR tranny problem..pleasee hellp!!!
- need help with trans swap
- ABS Axles
- AT trasmission problems. 92 civic DX
- Grinding but unsure what it is...
- Keep breaking 3rd gear shift fork
- 1998 accord 2.3 ulev transmission swap problems, please help!
- Need Help!!!
- Close ratio gears for B-cable tranny
- Trans not right need a little help
- speed sensor help needed****************
- Help me identify if I just bought a real "CTR" tranny
- B-series trans casing ?
- Spider Gears In ITR LSD
- clutch splines stripped????
- HELP! TRANNY LEAK NEED HONDA VETERANS ON THIS
- first gear & reverse grinding
- What are the symptoms of a worn out pressureplate/throw-out bearing?
- WTB**Gsr trans
- Clutch housing needle bearing
- Sticky second gear
- identifying lsd
- Shifting from 2nd to 1st
- Transmission question and shop recommedation
- Just need ideas as what could it be!!! NO gear
- GSR TRANNY GRINDS IN FORTH
- Clutch Failed on me...Help Please
- Transmission won't go into 4th,5th or reverse
- Integra Transmission Problems
- OBX+gsr tranny=help
- Dx auto to Ex auto tranny ?
- Tranny gurus needed..stock diff broken.debris everywhere.scored case. I NEEDYOURHELP
- wtb: looking for a bseries tranny/clutch housing
- 92 cable GSR tranny fluid
- Can someone briefly explain to me the difference here...B&M Short Throw
- best tranny fluid for high hp build.
- cable gear set in a hydro tranny??
- Short shifter
- Help! Troube with my Tranny on my DA
- where to get D series rt4wd tranny parts...? at what price?
- Flywheel dowel pins removal!
- d-series reverse gear/syncro into b-series tranny?
- Y21 Trans
- Flywheel Quality?
- GSR gear set in a LS transmission???
- B18C 3rd and 4th syncros the same?
- TRansmission only messing up when trying to down shift into 3rd...need HELP!!!!
- GSR hydro case fits on b16 hydro trans?
- flywheel help
- 92 acura integra What linkage is good
- Major problem - diff or axle or bushings?
- How to center steering rack?
- Leaky Y1 tranny....question on replacing linkage oil seal...
- oem 4.4 fd value?
- HX Auto transmission ?s
- Auto to Standard Help.
- loose clutch pedal/ cannot shift into gear
- ? on building h22 trany
- Clutchmasters Flywheel Friction Replacement
- 96 prelude tranny problem
