New synchro tech crx si tranny vss help
Hello,
I installed my new rebuilt synchro tech trannismission and there is a hole meant for the VSS. Problem is I can't remove my unit from my old tranny.
Does anyone know the part number. I know it should just come out after its unbolted, but the bastard isn't coming out. It's the hollow cylinder shaped metal piece the cable mates with.
thank you,
-5upr3me
As you can see it got chipped after i put a flat head underneath haha.
thank you,
-5upr3me
Re: New synchro tech crx si tranny vss help
lock some vice grips on it and try to tap it out, after trying to put it in gear and moving the input shaft to wiggle it loose
it's likely just putting it in gear and turning the mainshaft will free it up
Being in gear or not has nothing to do with removing the VSS. The cable VSS's being stuck is a very common problem. You'll probably need to split the case to pry it out if you want to get it out intact.
You won't be able to order it, it has been discontinued.
The VSS reads off the plastic gear on the diff. Being in gear or not does absolutely nothing to the diff or the VSS. The VSS holder cannot spin (if you can spin it then it will be easy to remove) so rotating the mainshaft in gear will only spin the VSS itself which does absolutely nothing to free the VSS holder. They stick because its a tight interference fit on 26+ year old transmissions.
Turbo Dan
10
05-15-2008 11:25 PM
Markb16a
01-27-2006 06:54 PM
