PDA
View Full Version : Transmission & Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. Oem LSD? Aftermarket?
  2. Clutch selection
  3. Civic EK4 SiR transmission problem
  4. When do axles start breaking?
  5. ?B-series gear swap?
  6. Manual problem and i cant find a solution
  7. Direction of drive shaft rotation, S2K vs AWD B series
  8. Which way to go?
  9. speed sensor ?
  10. Gears and such for a 96 accord
  11. Is The CV Axle C-Clip Really Necessary?
  12. Popping out of second - infrequent but worrisome
  13. b16a tranny or clutch problem???
  14. 96 Civic DX Automatic won't shift into any gear HELP
  15. highway RPM?
  16. my car wont shift ):
  17. 1998 Accord 4cyl Transmission Issue HELP!!
  18. Help! Trans problems, 2 lsd broke less than a week Hydro
  19. 1994 Accord no o/D lockup?
  20. Would you trust this 02 TL transmission?
  21. Transmission Overhaul
  22. B-Series Trans Question
  23. Replacing driveshaft seal - suggest upgarded MTF?
  24. about driving a manual transmission "properly"
  25. can anybody identify this lsd
  26. Short Geared YS1 worth the rebuild?
  27. help me identify this clunk noise in gear Civic MT 97
  28. Training Videos
  29. rpm diff in same "gearing" what gives??? pics
  30. Ls cable tranny issue
  31. LS swap does not move
  32. Help with transmission problem!
  33. spray Rear main seal with brake clean?????
  34. Why does my tranny fluid keep disappearing?
  35. manual trans fluid options?
  36. Torque Converter Issue?
  37. LS Diff grinding on VSS gear
  38. Rebuilt GSR YS1: Not always going in 2nd
  39. 99 CR-V rt4wd 5spd, high pitch noise in 5th gear
  40. clutch pedal stuck to floor while driving, still in gear!
  41. YS1 Short Gear transmission; SPEEDO problem
  42. B16 trans with ctr LSD problem?
  43. Recommend Pa. Rebuilder ?
  44. worse tranny noise ever
  45. D16z6 rear main seal lip to crank gap???
  46. 2000 Integra GSR Clutch Chatter
  47. clutch problems, d series turbo
  48. High rpm lockout. HELPP!!
  49. Groan noise when i move in any gear
  50. b16 lsd no worky worky!!! need help asap
  51. Transmission Swap 2003 TL/CL
  52. questions on tranny parts from a prelude
  53. how do i remove the speedo cable adapter from tranny?
  54. B16 Hydro w/ lsd no reverse
  55. No output to axles in s4c
  56. Rebuilding a GSR hydro with upgraded parts, what should be addressed?
  57. question
  58. B16b S4C Transmission Whine/Whistle Noise On Acceleration
  59. Is this fixable
  60. Are D diff and spider gears same as B?
  61. Integra B Series Gear Selector Position
  62. swap trans case bell housing?
  63. 95 ls 5speed problems? ???
  64. K Series and B series Flywheel Bolts
  65. Need some advice on what to do with my waffling clutch in my 96' B18c type R!
  66. m2b4 differential speedo gear
  67. 93 Del sol with gsr swap and LS trans help
  68. Shifter wiggles around...
  69. wont go into gear on the 2-3 upshift
  70. 97 interga LS auto Transmission Issues... need advice asap!
  71. question about act xtreme pressure plate
  72. 2nd Gear Issues
  73. Transmission Swap?
  74. Input Shaft Bearing Stuck on Shaft
  75. 06 SI CLUTCH!! HELP...please.
  76. JDM GSR lsd part info???
  77. wtf is this part
  78. Possible transmission problem
  79. Stumped. Bseries trans - random lockouts/popouts
  80. Throwout Bearing or Input Shaft Bearing?
  81. accord transmission reassembly
  82. Howl/Whine type noise 07 Element SC
  83. Clutch thumping??
  84. 2001 Honda CRV Code p0740
  85. P20/A000 Repair (ISB replacement)
  86. Serious tranny problem
  87. Crx b18b1 and s1 tranny halfshaft help
  88. 2000 Civic Auto
  89. LSd and clutch problem
  90. want to convert H22
  91. Help! Gold tag ys1 having its way with me!
  92. 07 Civic Si K20Z3 2nd Gear
  93. Short Clutch Release and Vibrations Constantly! HELP!
  94. F22 H22 Linkage Cables?
  95. Would mixed set of hypoid gears cause this?
  96. new short shifter???
  97. gsr tranny crack
  98. F20b swap in 91 Honda Accord CB7
  99. Honda auto's
  100. clutch stays engaged all the time
  101. Cable trans in nuetral but stuck in gear?
  102. B series transmissson
  103. Possible Clutch Issue? 92 Civic D15B7 Help!
  104. Carbon Syncros
  105. 220,000 miles on a stock em1 engine!!!!
  106. Transmission Stopper Plate Alignment for B-Series and H-Series Transmissions
  107. auto transmission power limits
  108. Synchro Hub Direction
  109. Type r 4.7 LSD
  110. Manual transmission fluid change question
  111. what trans for a b20b
  112. Brand New Clutch: Slipping? Glazed? Hot Spots?
  113. Shifting a tranny before closing it?
  114. Flywheel Install problem
  115. Holy crap! Axle wont come out!
  116. How to Convert from Taper to Ball Bearings on Hydro GSR and Type R Transmissions
  117. Custom 5th Gearset for H/F Trans?
  118. B18C1 Tranny Bolt Hole
  119. Best transmission fluid?
  120. "Clunking" when steering quickly.
  121. D series 5 speed specs
  122. Spark plug gap?
  123. Auto trans HP???
  124. flywheel question manual to auto
  125. Need a hand, changing clutch
  126. Transmission case question
  127. Manual Transmission oil leak
  128. Transmission swap.. kinda
  129. clutch isnt working
  130. Auto to Manual Conversion Questions
  131. 2000 odyssey po720 and po740 codes...need advice
  132. 90 Accord "S" light staying on in drive
  133. help with clutch
  134. Quick Question: GSR&LS FD+CounterS.
  135. kaaz question...
  136. ISB or TO bearing
  137. Wavetrac question!
  138. Shifting Issue
  139. good realiable aftermarket parts???
  140. YSK-1 Tranny Issues.
  141. Leaking transmission fluid at seal
  142. still grinding 3rd and litt into 4th s1 tranny
  143. help. Want to convert h patten to streight shift not whole conversion just pattern
  144. Changing my LSD Trans
  145. need to know what trannsmission i have?
  146. 1992 Civic Auto - Overdrive torque converter lockup problems
  147. 2003 pilot 186,000kms codes P1750 P0730
  148. 91 honda accord with blinking S light
  149. auto to manual swap for 92-95 civic
  150. 98 Accord Transmission Issues
  151. Transmission shift solenoid
  152. 5th gear hub and sleeve ques. for the RSX 5 speed
  153. blown clutch
  154. transmission wont go in reverse all the way
  155. Tranny not fully disengaging in neutral?
  156. Differences between S4C transmission and the Y21 transmission?
  157. Someone school me on clutches!
  158. Type R swap tranny weirdness
  159. B-series Hydro 14 teeth pinion/countershaft help.
  160. Shifting issues?! HELP!
  161. Honda ATF
  162. Checking an ITR Differential
  163. Test drove civic, reverse was hard to find
  164. H/F transmission questions.
  165. Foolish to rebuild a working manual Transmission?
  166. 98 crv transmission question
  167. Transmission Compatibility
  168. Need to know bolt sizes, help please
  169. where to get quality transmission in Albuquerque, NM
  170. Checking an ITR Differential
  171. Question on Pressure Plate
  172. xtd ebay clutch?
  173. help? transmission blown?
  174. '90 civic automatic to manual b16
  175. Rebuilding a 96 2.2 auto trans
  176. Need HELP Cable tranny wont go into 3rd4th gear after fluid was replaced
  177. Will an '88 - '91 D-series cable LSD fit '92 - '00 D-series hydro trans?
  178. 04 accord k24 trans lsd
  179. Tranny Knock
  180. ctr trans oil getting dirty really fast!
  181. NEED experienced professional 4th gen knowhow!
  182. 2000 Civic Transmission grenaded self
  183. 97 civic lx trans
  184. 03 rsx 2nd and 4th gear problem
  185. H22 m2s4 clutch housing cracked, repair options?
  186. H22 tranny options.
  187. 3 tranny plugs. Which is the fill and which is the drain plug?
  188. obd1 hydraulic trans swap in ef, speedo?
  189. 94 accord conversion auto tranny to manual tranny
  190. B series Transmission Identification help
  191. YS1 Transmission Questions... Help
  192. B20v cable to hydro tranny help!
  193. Honda Accord 2003 (Transmission Issue)
  194. D16 Twin Disc Clutch options?
  195. Turbo D16 drag transmission build... Opinions please.
  196. Transmission swap
  197. 04 Civic Auto Transmission normal or a problem? Someone please advise.
  198. integra making horrible whining noise , when clutch is releasing!!!
  199. Transmission stuck in a gear? Help
  200. B16 trans with 4.266 final drive
  201. Can't close transmission case
  202. B series VSS gear in the Transmission?
  203. Could a transmission cause the axle not to turn?
  204. 10w30 motor oil sub for MTF mileage?
  205. Can I use a SPEC clutch disc with my ACT pressure plate?
  206. Transmission slipping?
  207. Honda Jazz - P0801 Code - Reverse Inhibitor Circuit Malfunction
  208. Integra on jack stands, no load, making horrible noise and shaking the motor/tranny.
  209. Recommended transmission overhaul/rebuild components?
  210. 2005 Civic SE Magnetic Drain Plug?
  211. Itr transmission problem need help!
  212. Transmission grinding after fluid change.
  213. gearspeed carbon synchos - no 5-r synchro?
  214. 98 manual civic making strange noise (youtube video included)
  215. Transmission HELP
  216. PLEASE HELP garage have done me over, need some advise
  217. Ebay clutch sets
  218. Competition Twin Disk Clutch
  219. 1997 civic vti hatch tranny conversion
  220. What could cause noise with increased revs?
  221. Transmission issues
  222. lsd differential clearence problems
  223. B16b clutch
  224. Shop recommendations in DFW
  225. Need help finding bolts..
  226. Won't go into gear.
  227. which b series clutch
  228. 2004 Accord starting to grind going into 3rd gear
  229. BAXA housing update?
  230. What is the Spline Around the Mainshaft? Should it Spin?
  231. Can't find gears
  232. Awd ratio ?
  233. clunking sound when making a slow turn.
  234. ls synchros fit b16?
  235. Can't shift and clutch goes to the floor
  236. D16 transmission whining in 5th
  237. Help GSR only grinds at high rev
  238. Replacing an S20 with an S8G transmission
  239. LSD problem
  240. XTD 4 Puck Question
  241. 97 Accord auto trans problems
  242. input shaft bearing need replacement, need Mechanic in North GA
  243. Shorter clutch pedal stroke?
  244. single syncro is it possible to buy??
  245. Transmission repair manual?
  246. What is the warranty period for wheel bearings for 2010 honda accord?
  247. D series trans swap help
  248. Is honda MTF still good/safe
  249. Will a LS final dr ring gear from a 90-93 fit a 94-01 LS diff?
  250. Shift linkage help
