PDA
View Full Version : Transmission & Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31
  1. b16 tranny question
  2. clutch problem
  3. mini van Odessy transmission oil change (automatic)
  4. manual transmission fluid change help
  5. h22 final drive
  6. Competition clutch
  7. spoon diff question
  8. Transmission problem!
  9. is a oem gsr lsd decent
  10. anyone down for some tranny work? socal/anaheim, santa ana. i need an ls 5th gear swap
  11. Broken Clutch?
  12. clutch pressure problems????
  13. YS1 with S1 gears and LSD possible?
  14. B16 tranny rebuild
  15. Cable Y1 Diff. Questions!!
  16. Transmission or clutch problem??
  17. are clutch alignment tools universal
  18. Help, How to undo bung/bolt with countershaft clip under it?
  19. LSD Question
  20. Wierd feeling in shifter
  21. Need Help Transmission Problem
  22. will a 90 b-series trans correctly house 92-93 axelshafts
  23. New clutch making noise
  24. hydro/ cable tranny
  25. JDM S1 TRANNY phantom grip lsd part #
  26. B16 Cable into B18B Hydro ???
  27. clutch release questions
  28. Do I have the wrong Clutch/PP? Quick D16y8 Question....
  29. New clutch making noise
  30. Transmission wont go into gear? 2nd/4th!
  31. Time for tranny work
  32. Stock gsr pressure plate with act 4 puck ? Any good ?
  33. Erratic Speedo in 4th gear only
  34. No Reverse after LSD install, Need help in solving this problem
  35. transmission upkeep?
  36. Highter rpm stall converter for automatic transmission
  37. is it really cheaper to replace transmission the replace a differential bearing
  38. b series tranny identify how
  39. How to tell if S4C transmission is from CTR or SI ?
  40. ACT streetlite need to be resurfaced ?
  41. ok need some axle help..should be real quick to answer
  42. Where to find DC5 Type-R tranny?
  43. ?transmission rebuild service southeast usa?
  44. Ball Bearing? Basic Transmission Questions.
  45. AT shift linkage broken, stuck in park, how do I unlock the wheels?
  46. worn dog teeth, but decent synchros, and loose, vibrating noise when highway cruising
  47. add your 2 cents... ACT or Comp. Clutch
  48. H2A8, Honda Manual Transmission
  49. where to buy transmission rebuild kits?
  50. Rock Crawler drivetrain help.
  51. Different Brands of LSDs?
  52. GSR Tranny giving me sh!t!!
  53. whos interested in a Dog Box for H series PPG
  54. Possible transmission problem?
  55. OBX LSD + FAST CAR = Broken
  56. downshifting into 2nd problem
  57. cable to hydro gear swap?
  58. How many quarts for B-tranny?
  59. F23 with H22a transmission? Gearing questions
  60. will a LS Transmission do the job?
  61. D16 to B16 harness transmission sensor question
  62. NEED HELP !!!!!!!!!!!
  63. 5th Gen Civic Shift Box into 6th Gen Civic, possible?
  64. converting 4wd to rwd is it possible
  65. clutch wont bleed.....
  66. clutch slave cylinder thread size
  67. wtf bent the shit out of my clutch release fork
  68. Mainshaft Thrust Clearance
  69. Fly wheel bolts?
  70. stock b16 tranny with ctr lsd clunks??
  71. intermidiate half shaft
  72. Replacing Manual Transmission cable on 1991 Honda Civic
  73. ys1 tranny id?
  74. Tore my B16 tranny apart and found this..... :(
  75. 91 Acura Legend- the classic D4 flashing problme: suspecting it may be worse than i thought...
  76. Using a Ford MT75 on a B-Series engine - Can a Ford drivetrain be spun backwards
  77. Speedo Gear??
  78. clutch??
  79. need some help tranny is screwed
  80. NEED HELP!!!!! 02 civic ex coupe
  81. B16 mainshaft bearing part #?? HELP!!!
  82. Exedy or daikin clutchs ane good
  83. Where to buy OEM B-Series Gears?
  84. Really annoying tranny problem, need help explaining to tech
  85. Tranny goes into Reverse gear and works for only a couple of seconds and then stops, HELP!!
  86. Tranny rebuild parts, where do you all recommend?
  87. lsd trans...
  88. D15 wouldn't go into reverse, replaced tranny and same problem!
  89. 97 type R trans grinds out of no where. read further.
  90. problems turning/klunking noise after burnout and down track
  91. Where to get h22 axles?
  92. Need HELP BAD!!!!!!!!!!!
  93. stage 4 competion clutch problem need help buts fast
  94. ITR LSD into LS gearbox
  95. valvoline syn-power? or no?
  96. Throw out bearing
  97. Weird issue
  98. What weight oil - '97 5-speed Civic?
  99. cable clutch problem help
  100. What trans do I have and what axles do I need
  101. Need help fast tranny
  102. 4.78 Final drive affect numbers on the dyno??
  103. Need help with B series cable GSR tranny
  104. Tranny Issues will not go into gear all of a sudden..
  105. help with rebuilding my y1
  106. where can i buy a c's shift lever?
  107. H22A M2B4 LSD unit - will it fit in a USDM H22 Tranny?
  108. short gears for b16 transmission
  109. y1 trans blew up??
  110. ls automatic to gsr hydro swap
  111. shifter
  112. 93 del sol wont shift , i hope this is a known problem
  113. vote? which is a better clutch?
  114. ls/gsr gear box question
  115. F23 trans bolt to F22 engine?
  116. K20 lsd
  117. Main seal leak?
  118. What US parts for a JDM Y21?
  119. 95 civic auto to manual???
  120. gsr tranny problem
  121. Will 97 Civic HX axles fit Si cable trans
  122. Possible Clutch/Pressure plate issues?
  123. Tranny Problem
  124. Missing / grinding 4
  125. Is there anywhere you can get the synchro spring (wire ring) separately??
  126. 98 spec?
  127. Transmission locking up?
  128. i needz some answerz
  129. axle help
  130. lsd making my car jerk?????
  131. Automatic 02 LX Questions Please read
  132. Part 2: MFactory LSD review
  133. clutch problems
  134. List of axles specs (length's)...yes searchd
  135. How much power can OEM ys1 LSD handle?
  136. This better work or im BURNING my car!!
  137. varying axles..
  138. Final drive question
  139. Transmisson won't shift!!!!!
  140. Swapped transmission internals, Ls->gsr. gears are binding.
  141. gm performance 4t65 ?
  142. Question about my transmission/Clutch
  143. '92-'95 CX/VX 5-speed into '94-'95 EX?
  144. type-R lsd and b16 4.40 final drive gear ???
  145. Centerforce Dual Friction?
  146. Are gsr gearboxes the same as jdm vtir? (for obx lsd)
  147. *LS Transmission Questions*
  148. Help to shim diff, the clutch housing
  149. gotta quick question
  150. jdm lsd into y80 gsr trans
  151. XTD clutch ?'s
  152. Quick question about transmission/clutch
  153. Drive Shaft Shop 5.9s... i want a tranny that will break those first
  154. A1 Transmission i'm stumped
  155. 98 prelude trans swap?
  156. Not really good with gearing so, I have a few questions
  157. T1R final drive
  158. how many quarts of honda MTF do i need?
  159. 02 Honda Civic Auto Tranny Removal
  160. pops out of 2nd gear in low revs/issues with reverse
  161. LS 5th gear in SIR tranny?
  162. CD5 v6 5speed swap
  163. MY K20A3 GRINDS INTO THIRD AND SLIPS OUTTA THIRD :(
  164. Whats more cost effective??
  165. noob question about transmission set ups...sorry.
  166. Bad output shaft bearing??
  167. b16 tranny mates
  168. transmission problem
  169. 00 si b16a2 tranny with Type R ITR block what clutch kit to use ???
  170. 99 ls manual transmission
  171. Tranny FS/WTB section???
  172. Shift fork and throw out bearing issues HELP!!!!!!!!!!!
  173. Release arm doesnt move ONLY when tranny is bolted to the engine...
  174. GSR tranny, VSS not working, tried 3 different sensors...
  175. WTB!!! auto trans for a 99 civic lx!!
  176. cusco 1.5 with t1r 4.9 fd fit my jdm hydro ys1
  177. D16Z6 motor with an SI L3 trans clutch question
  178. d16y8 clutch
  179. b16a2 4.785 final drive from m factory trouble help
  180. Y1 LSD with J1 gearset? help.
  181. Question on my clutch
  182. Buy a new(er) low mileage one? or rebuild the one I got?
  183. gsr cable 3rd gear
  184. ACT pp had two washers?
  185. Did new clutch now makin wierd noise...?
  186. 2001-2005 civic clutch in 2000 Civic
  187. need input on gearbox problem.
  188. whats your opinion on the JDM B16A SiR I transmission non LSD?
  189. ls 5th/reverse in a b16 tranny?
  190. Automatic transmission fluid Change question?
  191. FD swap LS tranny with b16 4.4 FD What parts do I need
  192. Who has the best price on Brand new Type R transmissions
  193. S80 Tranny ran low on fluid and seized up
  194. Type R Transmission problem!!!! help
  195. Results for the Mfactory LSD after thorough testing.
  196. k24 tranny will fit k20 type r???
  197. grinding into 3rd??
  198. Is there any way to have a custom gear set made?
  199. would I be able to swap my automatic transmission to a manual?
  200. civic hatch wit B16 and a1 trans
  201. MFactory 4.92 FD
  202. In need of inner CV Joint, help!
  203. Having issues with installed GSR tranny with OEM ITR LSD
  204. transmission problems....need help asap
  205. Transmisson ID
  206. Problem with clutch, tranny, axle. no idea!
  207. OEM or aftermarket clutch for N/A use ?
  208. my exedy clutch broke. now what?
  209. Clutch Help
  210. Rebuilt Kits??
  211. Dual Bend or Straight Short Throw?
  212. Tranny Q for the Tranny Guru...
  213. auto vss??
  214. imput shaft??
  215. help: open diff
  216. Recently purchased A new type r trans.... Unhappy
  217. quick tranny ?
  218. Gen 5 CX/VX into Gen 6 car?
  219. ATS lsd clutch lock ajustment???
  220. How To: Determine your gear ratios.
  221. assembly of b16 tranny?
  222. Conversions
  223. Part 1: MFactory LSD review
  224. Help!! H22 Tranny question
  225. 5th gear keeps popping out!!!
  226. manual transmisson for 98 civic
  227. which ring gear for ctr lsd in gsr trans
  228. Using regular oil for a gsr grinding tranny?
  229. I need help choosing a new clutch for a DC Integra?
  230. Ammco?
  231. Car Pulled Hard right, made bad noises, pull over then fine. Quaife LSD
  232. In a bind - need help quick - fd install
  233. tranny code
  234. Trans help
  235. Differntial Question (B-Series)
  236. Rattling/Noise comming from GSR Transmission
  237. Questions about S1 Transmission.
  238. pulling out transmission
  239. clutch and flywheel
  240. itr lsd on a 95 gsr
  241. type R tranny grinds to go in 1st
  242. 95 civic clutch/shift problem
  243. 95 civic clutch/shift problem
  244. ring gear torque settings
  245. brand new competiton stage 4 clutch and flywheel
  246. how many cans of mobil 1 gear oil in gsr tranny?
  247. Clutch Sticking
  248. transmission locks up!!! please HELP...
  249. Car will not move with clutch pedal depressed
  250. auto tranny differences
