PDA
View Full Version : Transmission & Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31
  1. ACT pressure plate still good?pictures inside!
  2. What fluid to use?
  3. Car wont go into gear
  4. itr synchros
  5. si ?
  6. 1997 accord ex auto transmission HELP please
  7. How much power with stock gear
  8. b16 trans input shaft bearing....
  9. b16a tranny problem need help asap!!!
  10. LSD or not ????
  11. Timing Adjustment
  12. cruising speeds???HELP PLEASE!!
  13. Clutch or tranny???
  14. slipping..!
  15. auto vs manual mounts - 98 GSR
  16. Tranny/Clutch Problem!
  17. k20 6speed twin on a 5 speed???
  18. clutch question
  19. LS Mainshaft in B16 Tranny?
  20. type r tranny 5th gear swap
  21. Gsr transmission very notchy??
  22. Transmission Identification help
  23. Input shaft bearing - same between these trans?
  24. Is my Car Hydraulic or Cable Car?
  25. Rough vibrations during shifting
  26. Automatic Transmission
  27. replacement case
  28. OEM pressure plate EXEDY disc?
  29. Tranny Blues???
  30. new sync's 4th grind???
  31. Clutch Masters twin disk?
  32. EG8(stock) wont come out of 2nd gear?
  33. how do I...
  34. Tranny ID and Synchro problem, and I hate Craigslist
  35. breaking in new sync's
  36. Why am I in reverse when shifter is in neutral?
  37. jdm b16a lsd problem
  38. Itr tranny, rpm question...
  39. washington state need lsd installed
  40. D series transmission diy??
  41. lost my tranny bolts.
  42. LSD questions
  43. possible lsd failure?
  44. clutch issues
  45. ZC LSD tranny diff gone bad??
  46. tranny countershaft question
  47. Flywheel pin
  48. shimming my diff.
  49. LS tranny with gsr gears?
  50. Quick question Need my daily for work tomm !!!!
  51. 2003 honda piolt blinking d light
  52. gear identification
  53. B-series cable/hydro QUESTIONS!! HELP!!!!
  54. removing tranny
  55. difficult to shift in 5th gear @ high rpm
  56. Left drive shaft will not seat into the trans
  57. Is it normal to grind a little after a pass?
  58. Reason 91 Crx tranny won't go into 5th besides it being a 4spd?
  59. Mfactory 1st almost install...
  60. k question
  61. whining noise from tranny what could it be?
  62. MFactory D Series LSD Review
  63. F23a Gear box
  64. Kregan A1cardone Axles
  65. Where to get B series synchros?
  66. Please post your experiences with the OBX LSD
  67. hydro and cable synchros same?
  68. D series to B series parts swapping?
  69. Would anyone be interested?
  70. Need advise on adding gears to a GSR tranny
  71. Final Drive affects on gearing...
  72. Reverse Temporarily Screwed Up After Wreck?
  73. Tranny damage from hitting the curb?
  74. s1 transmission vss sensor
  75. Cable D won't go into gear with eng on?
  76. help ef tranny
  77. LS 4th and 5th in a gsr trans!?!?
  78. ***LS Syncros work in a gsr trans?? ***
  79. Have an SL3 civic/crx transmission, what is it?
  80. Quaife LSD and Axle installation
  81. D15 vtec trans
  82. cable trasmission lsds
  83. tranny needed
  84. DSS Driveshaft Shop Axle Q? Won't fully insert...
  85. Axles/Clutch??
  86. Is my clutch slipping?
  87. b series automatic trannys?
  88. heard something cracked...
  89. 98 Accord w. bad tranny, Rebuild or remanufactured?
  90. b16 tranny problem need help!!!
  91. need help bearing ?
  92. ***clutch fried***
  93. Loosing tranny fluid really fast + 5th gear pops out.
  94. shot tranny??
  95. question about b-serie clutches
  96. What type of Tranny Fluid!?
  97. shift linkage help
  98. GSR tranny with quaife problem HELP!!!
  99. Welded differential questions!!!
  100. 32mm main shaft nut
  101. tranny question ?
  102. Auto Tranns problem....
  103. Question about B-series Flywheels
  104. 1995 Acura Integra has failing transmission, maybe. HELP me with ideas to fix it!
  105. Help with gsr tranny please!
  106. jdm h22 transmission syncros
  107. how do i make my 95 civic all wheel drive?
  108. Free OBX LSD DIFF. should I take it? Help please!!
  109. Stuck in 3rd gear?
  110. Gsr tranny with 4.05 fd
  111. GSR VS B16 tranny
  112. Acura does not offer a shim thin enough; what to do? Differential shims.
  113. clutchmasters stage 3 or fidanza 3.2
  114. Best LSD b16a
  115. 00 Si, S4 hydro trans with no reverse
  116. Help identifying LSD
  117. have replaced vss and still doesnt work
  118. Cant find b16 gears for rebuild. HELP!!
  119. trans noisey and falling out of gears
  120. Help! Problem shifting @ high RPM's
  121. Just got my clutch replaced but..
  122. MFactory pro gears and final drive
  123. Transmission Issue With F20B
  124. hard to change gears - shift cable?
  125. Best place to buy a rebuild?
  126. HELP! freash install/shifts but NO GO
  127. Cable Axles work on a Hydro tranny?
  128. CRX Flywheel/Clutch/PP Compatibility
  129. Noises from my tranny
  130. GSR tranny wont shift into 5th or R
  131. High Horsepower RSX Transmission
  132. can't shift problem
  133. help tranny wont spin in gear..
  134. Are GSR hyrdro & GSR cable synchros different
  135. K24: What flywheel and clutch
  136. No reverse Dont Know Whats Wrong
  137. Reverse gear clicking.
  138. tranny fluid
  139. shifter won't go into gears
  140. civic shifter/del sol bushings
  141. Adjust clutch cable? . . . HELP!!!!
  142. Car won't go into park randomly
  143. ys1 transmission wont spin freely
  144. How noisy is a Cusco 1 way?
  145. Shifter bushing compatibility question...
  146. cable tranny on b20vtec
  147. Has Anyone converted shift-rods to cable shift on B-trans?
  148. honda/rover 2.7 manual gearbox help
  149. Cr-v auto tranny 4wd/awd help!!
  150. syncromesh
  151. need help, just put in new clutch and it is slipping
  152. '00 EX Sedan Will not shift
  153. lsd ys1 vs. y1 trans??
  154. Torque Capacity of Exedy OE & Stage 1 Clutch Kit
  155. lsd is stuck in positive traction
  156. How to Bleed Clutch?
  157. does this fly wheel need to be resurfaced?
  158. honda stepwagon(97) need help
  159. Hydro conv.90 da?
  160. clutch not engaging/ disengaging
  161. Noise inside gearbox!
  162. EFB2 Cable To hydro W/Twin Disc Issues
  163. Jdm gsr + itr lsd?
  164. clutch or tranny problem whatever it is the car wont move
  165. Viscous lsd??????
  166. possible transmission issues?
  167. B16 Hydro Diff into B16 cable tranny??
  168. Don't know whats wrong!
  169. clutch install... any words of advice??
  170. Interest for PPG/Bullhead Straightcut Syncroed H22 Gearset
  171. tranny doesn't want to drop??
  172. M2A4 H22 TRANNY 3rd Gear grind.....aahhhh need help...wtf...noob
  173. C-clip Part #
  174. 2000 civic ex auto tranny fault code p1768
  175. EBAY LSD Differential kits for SOHC
  176. What tranny do i have????
  177. B16 LSD Install
  178. where can a trans leak from ?
  179. j1 build info needed
  180. Wheels turning in neutral
  181. Needed some advice on if it is good or not
  182. 92 Civic DX 5 speed shifting issue
  183. trying to get some transmisison info
  184. shifter..
  185. alxes nut spins but wont come off
  186. Axle Question
  187. Does anyone know bearing part numbers to go to tapered input shaft bearings?
  188. no reverse, transmission apart, slider still won't move
  189. Transmission won't shift right when cold- 90 Civic LX auto
  190. CV Axle keeps pulling out! Help!
  191. Going H2B what do i need?
  192. torque specs for diff?
  193. Ls integra tranny problems. Please help!
  194. B-series Gear Identification Post
  195. B series OBX LSD
  196. Camp 1320 aka tom...
  197. gearing?
  198. stumped BADLY! speedo not working no error code
  199. 92-93 integra gsr clutch
  200. Passanger axle popping out at high rpms
  201. Driving Auto for Gas Mileage
  202. How can I inspect my LSD?
  203. looking for a good auto to manual how to threat for 92-95 civics
  204. won't go into gear when car is on
  205. honda replacment clutch (del sol vtec)
  206. HELP!!! JDM b16a tranny (STICKER VIN?)
  207. can someone help me out with my eg shifting?
  208. 3rd and 4th gear grind after rebuild
  209. Automatic- Drive gear problems
  210. Another tranny noise issue....
  211. which blind hole puller's do you use?
  212. Any Mfactoy 3.070 1st reviews?
  213. Automatic shifting issue
  214. tranny will not go into 1 or 2
  215. gears popout
  216. extreme clutch chatter
  217. GS-R Tranny identification?
  218. 94 civic trans help
  219. Dropping the engine with out a cherry picker
  220. ZC Block.. means what axels?
  221. transmission parts asap
  222. how much to rebuild tranny? ball park
  223. how useful are transmission and oil magnetic drain plugs
  224. K20a Info requested on Automatic Transmissions?
  225. K20a Transmission Questions
  226. honda to chev trans adapting?
  227. clutch slip
  228. jdm itr final drive install?
  229. HF 5th gear
  230. Seals in slave cylinder keep going out?
  231. Crx tranny
  232. transmission key
  233. prelude gearing
  234. tranny shifting problems at high rpms
  235. massive shifting problems!!!!!!!
  236. S80 transmission - what to look for when purchasing?
  237. b16 tranny or jdm gsr tranny
  238. D series OEM Flywheens
  239. how to clean inside of transmission
  240. What rebuild parts for a J1/Y1?
  241. I need a b16/gsr cable tranny asap
  242. speed sensors
  243. What year transmissions fit my 2002 Accord?
  244. exedy clutch and act disc...
  245. h22 tranny help needed!
  246. D16 Transmission HELP!!!!
  247. 96 ACCORD VTEC AUTO P0715 extreme cold
  248. Help!Best Gear Ratios for 300Meters
  249. Trsightcut race guys... What trans fluid are you using???
  250. What axles would I use...
