Big bearing L3 gearbox in CRX. What axles?
Hi everyone!
I've put a quife lsd in a big bearing l3 gearbox (CRX ED9, D16A9), but, someone else was stripping this gearbox before me, so it has different ratios, and it had... small side gears in a diff... yeah, they are for 26mm axles (again, big bearing diff 40mm, and smal side gears 26mm).
Now, I've got, big axle diff, and small 26mm axles.
What axles can i fit?
A DA Integra inner cv + crx shaft, and outer?
Seagull Management
Re: Big bearing L3 gearbox in CRX. What axles?
I'm pretty sure all the D-series inner joints are the same. 35mm and 40mm diff bearings both used the same inners. The outer joints are smaller on the HF models though.
JDMotive
08-04-2004 08:54 AM
