Transmission & Drivetrain Gearboxes, Differentials, Clutches
Hydrolic clutch line problems?
Old 04-04-2018, 01:30 PM
5honda's Avatar
Default Hydrolic clutch line problems?
1996 Civic dx
My master and slave were kind of leaking. One of the finally went out and I lost all pressure and couldn't go into gear. I got duralast replacements for both. Air bubbles kept coming out. I replaced seals on stock slave and put it back on.. same thing. Bench bled. It feels better, but when car is running the clutch pedal looses pressure kinda and feels squeaky like it's dry or skipping ..
Anyone have any experience with something similar??
Old 04-04-2018, 02:33 PM
holmesnmanny's Avatar
Default Re: Hydrolic clutch line problems?
do you have a half inch of clutch free play ?
adjust and rebleed
Old 04-04-2018, 04:26 PM
5honda's Avatar
When off not much play. When on its spongy. It is all the way adjusted. No threads showing on inside.
Why does the clutch pedal feel completely different when the car is running though, and feels almost normal when car is off?
Old 04-05-2018, 12:04 AM
when you press the clutch pedal, is there about a half inch of play before there is any resistance in the pedal ?
Old 04-07-2018, 03:34 PM
5honda's Avatar
Yeh. There's play, and I adjusted. Still not good.
someone said if pedal feels different when car is running, it could be pressure plate.?
Old 04-07-2018, 05:11 PM
yeah, sounds like it's giving out, eventually it will completely go
Old 04-11-2018, 05:18 PM
5honda's Avatar
It was the pressure plate
98trooper
10
08-22-2012 05:03 AM
mattthethug
09-26-2010 10:23 AM
JDM_SOHC
11
05-09-2007 10:52 AM
Quick Reply: Hydrolic clutch line problems?
