PDA
View Full Version : Transmission & Drivetrain
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. Inner cv joint
  2. j32 swapped eg hatch. help!! not going into reverse
  3. B16 transmission only shift to third an fourth after installing new outer case. HELP!
  4. B16A Y21 transmission
  5. rwd 2000 prelude
  6. B16 Cable Trans LSD
  7. H22 Cluch in F20A4 Engine
  8. Synchrotech Transmission Installed
  9. Clutch problem 95 teg
  10. 02 2.o si no 4th or 5th gear no noises
  11. 2002 honda civic ex tran went bad what can I swap wit
  12. k20 type s final drive into k20 type r tranny
  13. 2001 Acura CL TYPE S transmission swap question
  14. Need Help Please!
  15. '93 LS B18A1 in a '91 EF hatch, cable tranny not wanting to shift....
  16. Hard to shift
  17. How to install ls 5th into gsr tranny
  18. B16 outer trans case install
  19. Jdm f23 auto trans vs usdm auto trans
  20. gsr internals into ys1 case??
  21. interchangeable lsd?
  22. Which to tranny to use S4C or S80
  23. B18C with B16 type r tranny. Speed sensor not working! HELP!!!
  24. Hard Shifting, Can't Downshift, Jerks with clutch pushed in cruising in gear
  25. Hydro LS 1-2 sleeve in cable B16 transmission?
  26. Are b series gears changeable within different tranny cases?
  27. gear teeth stripped
  28. First gear is a pain to engage and disengage
  29. RSX clutch issues?
  30. Gear Lube Advice: Feeling-Like-A-Noob Fridays
  31. Gearbox advice: Feeling-like-a-Noob Fridays
  32. my 92 cx b18 swap plan
  33. gsr and ls info needed
  34. stock exedy organic clutch disc power holding
  35. '01 accord 3.0 auto
  36. '01/3.0 autotrans not happy
  37. My clutch dilemma
  38. manual transmission Help
  39. BMXA REBUILD SPECS
  40. Leaking Transmission
  41. Countershaft bearing noise? M2U4
  42. "Best" d16 cable tranny?
  43. B Series Axles / Driveshafts
  44. stupid question?
  45. Which clutch should I buy
  46. 1999 Honda Accord shifts too easy
  47. Gas pedal doesn't work after 70 mph
  48. Hesitation and Jerking
  49. Whining noise
  50. GSR TRANNY HELP!!!
  51. 94 integra ls automatic trans won't shift to 3rd?
  52. clutch barely passing
  53. ITR 10 bolt lsd into b16 case... what bearings/shims?
  54. are all b series tranny cases the same?
  55. Differential bearing failure?
  56. Possible transmission solenoid?
  57. P0740 Code on 2000 Honda Civic EX w/new transmission
  58. Clutch help??b20b
  59. 1996 honda accord transmission won't go in reverse
  60. Play in steering wheel
  61. Axle moves but flywheel doesn't - New Tilton Hydraulic T/O Bearing
  62. 5th/reverse problem
  63. GSR Tranny with LSD
  64. 3rd gear grind
  65. Transmission whine/transmission mount bolt size?
  66. Long or short gears?
  67. Prelude trans speedometer gears
  68. what brand clutch to buy
  69. Clutch Fork Spring 93 Integra Cable Tranny
  70. 09+ Si countershaft differences?
  71. reverse not the same after opening case.
  72. d15 automatic transmission woes
  73. B18c dc2r LSD s80 gearbox problems.
  74. Transmission advice
  75. Car jerks forward when re-pressing in clutch pedal
  76. Which cv axle shaft do i need for my car? Help please!!!
  77. Multi B series trans rebuild
  78. b16trans in crx locked up
  79. shifter not going side to side *cables good*
  80. d16y7 motor
  81. 2005 Honda accord EXL V-6 Transmission problems
  82. H22 shifter cables
  83. Possible differential problem? Im stumped..
  84. 97 Civic Auto Trans Modifications
  85. Is there any way to tell if a tranny is working?
  86. WTB : GSR 3rd and 4th gearsets
  87. What FD...
  88. handcuff for b cable small spline
  89. Clutch cable adjustment
  90. A000 to B000?
  91. b17 cable trans help!!!!
  92. GSR transmission whine!
  93. Oil leak after tranny install...advice needed!
  94. recommendations for differentials
  95. JDM honda accord 2001 ex trans not working please help!
  96. Continued transmission research...
  97. Transmission question
  98. 2000 Honda Civic EX ATF Change Help
  99. 89-91 civic/crx spindles
  100. Albins Helical Gearset with Synchrotech Carbon Rings
  101. 00 Honda Accord 4cyl clutch bleeding
  102. BROKEN/UNUSED TRANNY PARTS? - We'll buy them from you!
  103. K series shifter H22 Transmission
  104. Clicking Noise when driving around 30-35mph once only
  105. S4C Final drive
  106. Clutch Cable Adjustment, cable is tight, releases off of the floor
  107. Need help diagnosing what I need to replace in my tranny
  108. Whine when i accelerate in gear
  109. Help choosing a clutch under 1K
  110. Tranny issues
  111. LS 4th in a GSR trans swap
  112. Who can measure a 92-2000 Civic Axle for me
  113. New flywheel w/clutch upgrade?
  114. help identify this LSD
  115. 3rd clutch pressure switch-2006 Honda Civic
  116. Final Drive whine???
  117. Honda "B" engine trans gears interchangeability
  118. Honda "B" engine series trans friction reduction
  119. Help Required for M4VA CVT Tranny Juddering
  120. LS/GSR HYBRID TRANNY
  121. All new synchrotech synchros and still have shifting problems?
  122. newish clutch issues
  123. Transmission jerks when turning left
  124. Exedy OEM Clutch/PP Issue
  125. 2006 Accord Trans slipping...is it toast?
  126. VSS Compatibility Question - GSR
  127. clutch release fork bent mildly question
  128. B16 Clutch Bleeder Valve Thread Size!!!???
  129. S9B Transmission w/turbo
  130. 2008 fit sport confused with issues
  131. Is the OEM XTR HD clutch any good?
  132. Cant shift into 1st and 2nd
  133. ATF Leak Issue??
  134. New Mfactory special/program.
  135. M2b4 trans.
  136. Countershaft snap ring - remove/replace
  137. 1995 civic manual trans problems
  138. Torque Converter lock up Shutter and Vibration
  139. DB9 Integra auto to manual trans swap NEED HELP!!!
  140. LS trans doesn't fit a b20?!?
  141. B4RA Troubles
  142. B16 EG ac bracket trouble
  143. 2011 odyssey vibation
  144. 1990 acura integra ls 5spd
  145. b series 2nd gear.
  146. B-series 4.7fd with LS 5th
  147. Manual B series housings interchangeable???
  148. AWD EF HATCH
  149. CompClutch question/issue
  150. Is my transmission done for?
  151. Honda D15B Dual V-tec engine with Autotranssmission need help in transmission wiring
  152. sequential shifter for honda B series?
  153. b16 hydro transmission countershaft differences
  154. Trans gear cuff measurements needed
  155. Upgrade axel options??
  156. What starter for B17 trans?
  157. B series trans mounts into eg
  158. Hx ISB problems
  159. gear-x reviews HP
  160. NINJA Gearbox question! If anyone can answer this they win a prize!
  161. D series lsd
  162. Engine swap, different transmission setup
  163. What are my options?
  164. fidanza ring gear need help?
  165. How to Repair your GSR/ITR/B16/H22 3rd Gear
  166. Manual Transmission Problems
  167. Shift linkage loose on shift selector shaft
  168. My Synchrotech Order is Here!
  169. is it worth it....honestly
  170. 93 Civic slipping out of gear
  171. DSS?
  172. D16y8 transmission pressure plate fingers bent?
  173. B18 trans problems
  174. New rebuilt tranny shifting issues
  175. LSD problem ?
  176. Clutch Master Cylinder quick question
  177. Accord transmission mounts-installation and pricing?
  178. chain like noise when in gear
  179. Rebuilt LS Hydro Transmission Whining
  180. Mfactory Final drive to big for my b16 diff
  181. Clutch or Tranny?
  182. Dropping Trans
  183. b series trans seizing crank??????!!!! HELP!!!!!
  184. Trans issue
  185. S80 Tranny won't go in to gears.
  186. Can't shift into second - GSR Tranny
  187. Clutch fork hard to pull by hand does not return
  188. Cable to hydraulic swap
  189. clutch vibration?
  190. Replaced transmission and I have same problem
  191. B18c Transmission grinding after rebuild...WTF
  192. shift fork question
  193. Upshift & revs drop to idle, slow acceleration.
  194. speed sensor problems
  195. Strange 2nd Gear grind on rebuilt prelude
  196. CRX Si trans vss stuck
  197. DSS 5.9 axles informations
  198. ek transmission problem
  199. Converting from automatic to manual
  200. rebuilt aoya
  201. B18c Type R w/ LSD Tranny Runs High RPM's in 5th Gear
  202. D series trans fluid options
  203. GSR YS1 VSS problem. Cable NOT broken, speedo wont read.
  204. GSR YS1 VSS problem. Cable NOT broken, speedo wont read.
  205. 93 civic si clutch grinding when releasing clutch pedal
  206. late engagement and very soft pedal
  207. SEMA 2013 Las Vegas
  208. Fourth gear grinding
  209. Remanufactured trans leaking when placed in gear.
  210. EP2 Driveshaft
  211. s4c gearbox confusion?
  212. 6 Puck Clutch now Grinding.
  213. will a 4 click work in a 6 click
  214. 01 shifting issues when cold
  215. car wont go in Gear No air
  216. shifting issues
  217. h22 block f22 tranny
  218. 2003 Honda Accord V6 automatic stuck in 1st gear Help
  219. Torco MTF vs MTF-R
  220. Em1 problems with reverse
  221. Rebuilding slw transmission. Question on mainshaft
  222. Transmission Failed after Pep Boys visit
  223. Exedy twin disc
  224. M2b4 issues please help
  225. B-series clutch disc diameter
  226. D16y8 Transmission free spinning by hand issues/questions
  227. 99 Civic Ex Coupe slips out of 2nd?
  228. Gsr low clutch pedal engagement
  229. car won't drive after rebuild
  230. shifting problems
  231. Clutch help
  232. B16 S1 USDM transmission
  233. Custom 5th gear for cable B16 S1 transmission?
  234. 04 tsx green light blinking!!!!!!!!!!!!!!!!!! HELP!!!!!!!
  235. D series swap in 2000 Civic Si
  236. not shifting correctly...help
  237. 95 Civic Dx clutch issues
  238. 3rd gear doesn't work
  239. Possible Clutch/Tranny Prob - 97 Prelude
  240. Clutch Slave Cylinder Alternative?
  241. lsd from gsr into a b16 tranny questions
  242. Clutch problem
  243. t2t4 in 4gen.what transmission mounts
  244. 3.5L (L66) 5 Speed AT Fluid Question
  245. '97 Accord A/T stuck in park except w/key
  246. what tranny to go with B16A2
  247. 97 Accord Automatic upgrades?
  248. Spec Twin disc in backwards?
  249. Clutch pump up!! Help asap!!
  250. Oem LSD? Aftermarket?
