- what trans do i have?
- B-Series Transmission Kit?
- ef trans/clutch issue help!!!
- LSD for Street/Track Use
- Used transmissions from Japan?
- lsd on ctr trans
- *Need Help Changing Clutch In Ls Tanny*
- tranny is knocking
- Has anyone shipped out a tranny?
- *SUPER STUMPED*! Speedo not working on my autotragic DB7 :(
- Writing on transmission
- Ctr tranny problem
- Help case will not close
- Problem with my tranny case
- Is it hard to change out a automatic?
- lsd daily driver
- need help picking out gears for a b series tranny
- What Trans can i use...?
- shift changer thingy blah broken, can i fix the individual peice, or replace the whol
- no 5th!!! HELP
- bluw auto need to know it s type trans will fit in a 97 base model prelude
- Couple of questions on H22 trans
- 06 Civic transmission service
- should I replace factory lsd
- tranny tear down tables
- skunk2 short shifter
- H22 transmission question
- h22 trans problems
- ITR tranny I.D.
- Half shaft install
- gsr trans no 2nd gear
- So I cracked my case and found...
- Tranny gods need yor help PLZ!!
- In which gearboxes can i use this clutch?
- LSD ys1 throwout bearing spring??
- do i have an lsd?
- D-series Case Gap
- H-to-B help!!!
- Clutch Pedal?
- transmission options
- Can't shift on a cold start!
- The BEST transmission setup (gearing wise)
- d16z6 tranny
- YS1 tranny in JDM EF9 or EDM EE9 chassis
- 97 Odyssey shifts hard
- New Clutch and Flywheel options
- Grinding/clutch problem
- Tranny RPM by MPH chart?
- EF CRX trans input shaft?
- 00 b16 tranny lsd?
- Hard to SHIFT!
- auto trans questions?
- Help can't shift!
- ring gear bolts, reversed thread????
- how to remove clutch release arm cable tranny?
- will this work??
- tranny advice
- cable lsd in to hydro trans?
- Where are all the LS tranny's?
- b16 s1 syncro sleeve help
- NEED MEASUREMENTS: D-series OBX LSD
- New 08' Civic LX w/manual trans, what are the gear ratios?
- What Diff is this??
- Wheels hardly turn?!?
- Is this the right fluid for ATS lsd
- b16 tranny removal
- Who has shifter bushings - 94 Prelude cable trans
- Transmission Swap?
- Engine swap options
- Your opinion On my transmission issues. PLZ REAd
- clutch / flywheel help UK ITR
- cable tranny gears interchangeable?
- tranny problem need help plz
- Frankenstein Transmission Setup. Thoughts?
- Final drive options?
- ITR LSD strength?
- M-Factory 1st gear
- Spoon close ratio into 98-00 DC2 Problem
- how many teeth on ys1 input shaft?
- Y21 Tranny....
- how many teeth on small spline ls main shaft?
- LS transmission with 3-4 VTI or GSR
- Identifying Tranny
- B-series transmission teardown/rebuild tutorial
- Name the problem? CV shaft is my belief
- 98 auto civic stalls when put in gear
- Swaping gears LS+ITR
- help with input shaft bearing and more??
- 93 Cable Trans...How to decode??
- GSR Hydro tranny, won't go into gear. need help
- Drivetrain Help!!
- NEED HELP ON MANUAL CONVERSION!!!
- lsd help
- Brand new clutch before dyno tuning ?
- DA jdm B16 trans problem. help needed
- ITR gears in ls tranny case?
- 87 accord transmission gears layout
- Gsr trans/clutch problem -- Please Help
- Need gearing advice (ive confused myself)
- fork slipped off bearing......
- Big Vss problem on 93 integra . Help
- Os giken gears.
- Diff Bearing
- changing to stage 2 clutch
- Anybody interested in a dogbox for h22?
- d series hydro and cable clutches
- flashing Drive Indicator
- shell for a trade
- cofusion of the cable to hydro conversion
- help uk honda integra itr
- Tranny number ten in the books... LOL
- Harsh Shifts 95 Accord Auto
- Cold automatic tranny making loud sounds
- K-series trans input shaft?
- WHINNING NOISE!!!! I NEED YOUR HELP!!!
- Longest Shorty Axles
- Squealing in 2nd and 3rd?
- b16a tranny
- 1994 Integra LS Auto Fluid Change
- d16 trans help
- car won't start what could it be
- help with b-series transmission
- 1999 Accord 3rd clutch pressure switch
- All Motor Drag Car Gear Ratio's
- whats on the hydro trans?
- options for 93 gsr transmission?
- Auto Transmission Rough!
- JDM s1 or USDM s1? How to identify?
- Wanted to share my experience with Gearspeedinc / HNATRANS..
- Y1 Gearset into an S4C Case possible??
- transmission help 1990 accord
- 95 Accord Manual Tranny problems
- 92 YS1 trans question?
- Honda Transmission Syncro Install
- Final Drive/LSD install
- when torque converters fails
- 93 integra speedometer cable
- GM/Chevy synchros in a Honda?
- problem shifting into gear after engine swap
- cleaning a clutch???
- y1 cable tranny w/ lsd?
- b series clutch/flywheel fitment?
- Transmission Swap Guide
- ACT XXR6
- EM1 fix asap. Help!!!!
- 2001 acura 3.2 cl Tranny Shift
- this is a weird problem
- 92-95 EX tranny vs 96-00 EX tranny
- My transmission and lsd upgrade build
- Larger diameter clutch master cylinder
- jdm b16 cable tranny question
- clutching needed help
- mfactory LSD reviews?
- Is this a bad tranny?
- gsr or b16???
- B-16 hydro trans?
- need help h22 m2b4 trans
- shift linkage
- which gear set is 5th?
- help with tranny setup
- 5th gear grind outta no where? wtf? seriously? help me!!
- Clutch issue. Please help
- convertign my zc from cable to hydro
- LSD for d-series question
- what is this thing? can it be eliminated? wtf! please help!
- weird trans gear ratios
- need some torque specs ASAP!!!!!!!!!!!!!!!!!!!!!!!!!!
- Tranny Fitment Problems..
- final drive for my CRV??
- W/B YS1 Diff
- h22 m2b4 lsd tranny 5th gear
- B16a tranny internals
- S80 Shift Linkage Snapped off Transmission
- no power to wheels
- Clutch problem...New clutch or something else?
- Is there an lsd for an ef b16 cable transmission
- D16y7
- Clutch Squeak?
- leaky s2 tranny
- best tranny for big hp street car with slicks
- all motor transmission help
- B16 Transmission removal
- R18 tranny - is there an LSD available?
- What determines the amount of feedback from the clutch?
- Cable speedo in hydro clutch car?
- b17 cable with lsd
- h22 in eg wont go into 5th gear
- Clutch master cylinder rebuild kit? 93 Accord
- weird cvt trans issue
- cable tranny help
- lsd, how to torque down bolts
- Counter Shaft differences
- CrankShaft differences
- Inspect this bearing on my differential
- looking at a S1 tranny is it b16a or ls how can i tell
- Are these clutches the same?
- What trani for this setup.
- How to for Tranny
- the transmission roll call!
- Tempermental Competion Clutch stg.4
- What axle seal for CTR transmission ?
- Noisy clutch rattle turns out to be worn splines on clutch disc
- Cable tranny. Help lower clutch pedal engagement point
- how to open case
- finding neutral with out linkage
- Gears popping out problem
- Kaaz LSD problem
- B16B differential repair?
- ITR Shift Linkage into EM1
- Removing Driver Side Axle Nut for Clutch Job - Necessary on DC2?
- Pic request please
- Tranny Or Clutch
- 06 TSX Jerky Manual Transmission
- question about clutchnet.com
- 1990 Civic LX - Transmission Compatibility
- 5th gear whine on recently rebuilt trans
- trans gearing question?HELP
- can u put cable gears in a hydro case
- b16a tranny wont go reverse when install OBX LSD !
- Can you use J1 FD and Diff in Y1 box?
- what is this thing on my trans?
- Help...Tranny stuck in first gear
- K20Z4 (FN2) into dc2
- b16 transmission
- Cable YS1 Questions
- what tranny is this?
- ITR Tranny Rebuild Grinds with Gearspeed Synchros
- Issues with 97 itr tranny with cable to hydro conv. HELP ! ! !
- 5th gear just kinda dissapered!!!
- Brand New LSD Differential for b16
- ITR gear's in GSR Transmission?
- how hard is it to switch from auto transmission to manual???
- Tranny oil leaking. Possible that the shim is going bad?
- A20 Manual F22 motor?
- Competition Clutch Good?
- removing and replacing clutch?
- Is it time for a new clutch?
- Fidanza Kevlar clutches
- JDM spoon lsd in B16 tranny
- need help deciding
- Transmission Oil?
- Quaife LSD from an LS in a B16
- Clutch? Tranny?
- OBX LSD IN S1jdm cable tranny
- weird clutch noise?
- d16 transmission in d17?
- tranny or gearbox problem?
- 2nd gear problems
- Downshifting
- gsr lsd what to look for
