PDA
View Full Version : Transmission & Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. will a d15 trans fit on d16?
  2. 95 gsr transmission has loud clicking when driving/accelerating constantly
  3. b16 tranny wont shift after rebuild
  4. tranny? or clutch issues?
  5. Crazy VSS problem, help please!!
  6. Gear Changing... 99 SI with LS trans
  7. Clutch Free Play
  8. 91 integra with b16 needs new trans
  9. Car goes into gear without using clutch... pls help
  10. 1991 acura integra with b16
  11. choosing clutch
  12. what is the Honda part number for this part?
  13. Best Clutch for 300whp on ITR tranny?
  14. Let's talk clutch kits shall we?
  15. What is this Clutch line called? Please help
  16. b-series franken-trans
  17. f20b trans cable help!
  18. Lotus Europa
  19. ek axel ? really confused by part prices
  20. Trouble on the dyno.. What is it?
  21. Clutch problem!!
  22. strange vibration on shifter @ high rpm 3-4th gear
  23. h2b
  24. what to look for when buying used LSD?
  25. USDM ITR trans differential questions
  26. Identify my transmission.
  27. clutch recommendations for all motor wagon
  28. Clutch n00b. need advice on what to get.
  29. Trans problem???
  30. weird bump when accelerating
  31. Popping out of 2nd
  32. Identification s4c trans question
  33. cleaning gsr trans gears?
  34. si tranny weird noises
  35. How to identify a Honda transmission...
  36. canby, oregon.... needing some help!!
  37. Strangest GSR tranny problem EVER
  38. kaaz lsd troubles
  39. Question about CC Twin Disc setup on an H22
  40. minor leak
  41. any one used XTD stage 4 clutch before ??
  42. 1998 Prelude 5spd Swap Clutch Issues
  43. which axels??????
  44. CB7 Auto Transmission
  45. GSR face plated gear trans for sale
  46. bad transmission? 94 accord f22a1
  47. Transmission problems after rebuild
  48. Question about factory/aftermarket LSD
  49. USDM ITR tranny
  50. unsprung 6puck clutch killin me
  51. Grinding noise when shifting from 2nd to 3rd
  52. re-using diff bearings?
  53. want to buy liberty face plate gear set b-series
  54. Jdm gsr gearset plus LSD into usdm LS tranny case
  55. HELP exedy twin disc.
  56. twin disk users unite.
  57. clutch slippin with chromoly flywheel
  58. transmission
  59. ys1 diff bearing part number?
  60. what coating on forks?
  61. Leaking Fluid from drive axle I believe - Please help
  62. Clutch springs loose
  63. AWD Integra?
  64. Identifying FD
  65. 1st & 2nd Gear Whining But 3rd Don't 00 Civic Si
  66. B16 Y21 4.7FD & LSD.... no?
  67. B18b1 tranny oil refill spot ??
  68. can a transmission case be welded? Cast aluminum with a Tig welder?
  69. This is my comp stage 5 clutch after 2k miles...
  70. Tpe-R build Need Help!!
  71. ats 4.9 ring gear
  72. Another Transmission swap question
  73. quaife lsd install??
  74. Why am I breaking transmissions?
  75. Need a thread insert kit! M18x1.5 rent or own
  76. what do i need to fit a b16a trans on to my b16a2 in a 00' si
  77. Shift-Up light
  78. looking for help with tranny identification "pics"
  79. carbon synchros - brand preference and why?
  80. Transmission ticking noise?
  81. I'm looking for an H2B kit civic ef 88-91
  82. 4.785 vs 4.92 FD
  83. G series 5 speed?
  84. Official Albins Syncroed H/F series Helical 1-4 gearset interest thread!!!
  85. Transmisson with horrible sound.. Need rebuilt?
  86. grinds going into 3rd
  87. High RPM Won't Go Into 3rd Until RPM Drop
  88. HELP B16 Transmission Wierd problem
  89. b16 or gsr tranny?
  90. Innovative cable to hydro installed...please help!
  91. Where to buy a VSS gear for the differential
  92. need help with a bolt size asap!
  93. Is this bad ??
  94. 89 tranny in a 92?
  95. Exedy Stage 1 clutch. Is it for daily use? City & Highway?
  96. Question about differential bearings
  97. Where can I buy GM Synchromesh with Friction Mod??
  98. Hybrid s20 Tranny
  99. B16eng with D16transm
  100. H2b vs Rebuilding the H tranny
  101. H22a4 swap tranny issues
  102. rebuilding S40. d16y8 transmission
  103. Difference between Mfactory and Synchrotech LSDs
  104. Smog checks and transmission gearing.
  105. NEED URGENT ASSISTANCE!!!
  106. ek lx auto tranny reverse problems?
  107. clutch is being forced and doesnt spring up?
  108. K20 6 speed popping out of 4th gear. Help!
  109. LS tranny shot?
  110. H22 Turbo transmission
  111. b16 ring gear in gsr transmission
  112. 1990 Honda DX Transmission Issues
  113. Replaced the DIff. reverse Pops out
  114. VSS different on D series?
  115. Springs popping out of clutches?
  116. help on y1 transmission rebuild
  117. GSR- hard to shift/stuck in gear grinds 1-2 shift.
  118. What clutch for 320whp and daily driving?
  119. Slow Clutch Pedal Pressure Loss...
  120. ATF feed pipe direction- Which book is right?
  121. Which hydraulic line to use for my 2000 Si setup?
  122. Rebuilding my 01' 5speed crv trans-- FEW ?'s
  123. 4speed to a 5speed
  124. 600whp Quaife clutch/trans problem........
  125. Stiff pedal and wont go in gear
  126. Changed final drive, now locking up in 4th?!
  127. 04 CR-V A/T 4wd Rebuild
  128. New isb, now won't shift
  129. Is there a demand for a groupbuy Mfactory custom gearing?
  130. Rebuilt tranny, new clutch, stuck in gear...
  131. 94 civic ex auto trans issue
  132. gear box leakin major oil
  133. What transmission is this with pics
  134. 2000 Civic Si
  135. OBX replacement bolts
  136. Auto to Manual swap help!
  137. s80 or y21
  138. LSD vs non LSD
  139. urgent wheel bearing help!!
  140. CONSTANT NOISE AFTER REPLACING CLUTCH
  141. GRINDEING NOISE HELP NEEDED PLEASE!!!
  142. tranny or diff problem help!
  143. Parts number for AT drain plug
  144. 109.8mm ID Ring gear 4.4 ratio
  145. having problems getting in and out of 1st and reverse
  146. 99 civic ex auto problems wont go in gear
  147. clutchmasters twin discs help
  148. Recent transmission troubles... what could be the problem?
  149. 2000 Civic EX Auto Transmisson problems
  150. tranny question
  151. Which clutch would be best?
  152. Transmission heading out the door?
  153. 2nd to 3rd gear problem
  154. 93 cable LS 3rd,4th,5th in 99 hydro GSR trans??? 3/4 fork not working
  155. Trans won't shift in hot weather
  156. ATS lsd vss
  157. Need help
  158. xtd stage 3 exedy stage 2...what should a dooo!?!
  159. itr trans w/ gsr 5th and reverse gear problem
  160. BEST OE REPLACEMENT CLUTCH? EXEDY or COMPETITION?
  161. 94 civic cx transmission on 94 dx, gear noises
  162. differential choices?
  163. Shifter Fork Questions
  164. Cable to hydro 5th gear swap
  165. Trans gears will not go into 2nd,4th and R
  166. Weird transmission noises that are slowly getting worse
  167. Bastard gears in GSR, help with ratios and what to expect
  168. Post your engine tranny and oil
  169. dont know what linkage to buy
  170. b16 gear set on ctr tranny
  171. 93 Accord Wagon Automatic Troubleshooting
  172. 2000 Prelude SH Clutch advise.
  173. GSR transmission help. case questions
  174. Need help with tranny build
  175. GSR transmission to be built with custom gear ratios, need some advice
  176. problems with CC stage 5 clutch kit, again!!
  177. gsr tranny
  178. 93 Civic Auto Trans Problem
  179. clutch problem 2
  180. Ordering axels?????
  181. 2000 Accord 4 cyl auto - whinning noise
  182. what trans comes in a 90 civic EX????
  183. any ideas??
  184. No clutch adjustment left
  185. 89 Accord FI Automatic - Shutters violently on take off
  186. B-Series Hydro case + LSD question
  187. CV Joint, Axle, or Wheel Bearing Problem?
  188. measuring clutch pedal
  189. JDM ITR Tranny>> LS 5th gear swap
  190. ls or gsr counter for a turbo car? have both need to decide
  191. 2009 Honda Odyssey fluid change frequency?
  192. gsr b17 cable tranny with lsd
  193. Real theory behind clutch braided line
  194. Is this shaft fubar'd?
  195. Hydro b series transmission top hat? HELP!
  196. Clutch making noise...
  197. B series shift linkage or D series?
  198. something is wrong with my drivetrain. bad clutch? need help ASAP
  199. WEIRD NOISE AFTER CLUTCH INSTALL
  200. LSD for Honda civic ex 1999? Quality or?
  201. driveline vibration and transmissin problems
  202. d16y8, comes out of 2nd easily
  203. wavetrac LSD seller gets me confused? Pics.
  204. ATS close ratio gear set tooth count
  205. when my car hits 40 mph, it feels like it's not in the right gear
  206. swap kit flywheel
  207. need help to know what kind of lsd is this
  208. tranny fluid
  209. Driver side CV axle not fitting (2000 civic with B18B1)
  210. d16z6 transmission help
  211. b series tranny whining in third gear
  212. Best LSD for Integra Type R ?
  213. Tranny Help
  214. D series lsd questions
  215. Handcuff installation video/tutorial?
  216. Adjusting CMC rod cause slipping?
  217. lost clutch pressure again
  218. Need Help pulling differential off y21
  219. CC Stage 4
  220. looking for a d series si cable trans
  221. Hasport CMA
  222. y8 trans noise hell i dont know
  223. d15b2 trans help car moves forward in neutral!!!
  224. Cusco LSD, 4.4 final drive?
  225. diff question.
  226. need help asap please.. crx transmission question
  227. Can anyone tell me what this LSD diff is from or will Fit??
  228. auto tranny jumps in reverse not a blown mount!
  229. clutch pedal lower after clutch replacement
  230. ITR tranny need syncros
  231. Help diagnose problem - LOUD noise at certain rpm's ('99 civic)
  232. 94 civic dx Transmission repair questions
  233. Clutch Slipping Issue
  234. shift change assembly and interlock problem???
  235. 00 civic si S4C transmission question
  236. Help, odd transmission grind
  237. '00 BMW 323i Transmission Porblem...
  238. GSR 3rd grind Synchrotech Carbon Synchros
  239. EP3 Clutch problems. Need advice..
  240. vtec and non v harness
  241. synchrotech trans
  242. Cable b16 tranny won't go into 4th
  243. Need a Transmission Swap
  244. need help picking a clutch
  245. 6 Puck sprung fircition disc on a stock pressure plate?
  246. exedy twin disc???
  247. ITR tranny wont shift into reverse
  248. new 5th gear stopped shifting
  249. 04 civic EX Transmission Burning (White smoke)
  250. DSS garage sale on 5.9 B/Hydro axles
