PDA
View Full Version : Transmission & Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. Crv transfer case to corvette c4 ids help!!!!!
  2. new to the site ! best bang for the buck.
  3. HELPP s4c/y21 final gear
  4. rebuilt b16 transmission wont go in any gear
  5. mtf honda fluid
  6. synchrotech rebuild kit install. help
  7. How to identify B-Series Cable Transmission Year Range
  8. Small spline b16 Interchangeable
  9. 92 integra Auto trans s3 light fix? No cel
  10. Trans ideas?
  11. what year tranny do I have
  12. HF transmission question
  13. LS Transmission help
  14. east coast shops that do transmission rebuilds?
  15. Stick moves when in gear
  16. installed new clutch, now it doesnt feel like its grabbing.
  17. Tranny fitment question
  18. D15 cable transmission rebuild
  19. lsd question???
  20. I need help with my tranny
  21. S80 trans making weird noises when clutch is pressed in/out
  22. Hardened vs non hardened cross pin?
  23. B18 with GSR or B16 Trans??
  24. Transmission Questions
  25. Three bad D-series Auto transmissions. Scrap them?
  26. what type of LSD is this?
  27. Can't install seal.
  28. Transmission fluid for KAAZ Clutch type LSD
  29. 1st Gen CRX Clutch/Brake Pedal Mount Failure
  30. ACT Clutch/Pressure Plate ID
  31. mfactory in a s1 tranny
  32. transmission on my ep3
  33. H22 civic LSD issue
  34. may have a speed sensor issue
  35. Transmission flush vs drain and refill
  36. B18 clutch
  37. Cooler tranny fluid help
  38. HELP: RSX Type-S / CRV Right Passenger axle too short? (K-Swap)
  39. S80 GsR question
  40. Occassional "clunking" sound (getting worse)
  41. F20b integra Tranny Issue/HEadache .
  42. Honda S80 gearbox after market lsd kaaz??
  43. trans downshifts
  44. Fins broken inside case
  45. XTD 8lb Flywheel Strength?
  46. tranny blown
  47. Bad front left axle
  48. tranny removal question
  49. Clutch or trans problem
  50. The ever changing clutch pedal...
  51. Wavetrac Or Quaife Or Mfactory
  52. fitment questions regarding 96 accord auto trans
  53. ls 5 gear into s9b?
  54. gsr trans not turning wheels while in gear
  55. Is putting a front gasket seal going to be worth the trouble?
  56. clutch chatter?
  57. typical b16a 3rd gear grind question
  58. need help gsr tranny ball spring thing?
  59. help! ball spring on gsr tranny?
  60. axle questions
  61. lsd tranny questions.
  62. F1 stage3 clutch kit?
  63. LS Hydro Tranny TROUBLE! PLEASE HELP!
  64. gsr tranny
  65. y80 lsd tranny worth?
  66. Need 3rd Gear Synchro and Sleeve YS1 Cable Tranny
  67. LS 5th gear and counter gear for CABLE trans...
  68. help with VTEC Mini Cooper build!
  69. Grinding 1st and 2nd
  70. size of bellhousing bolts in b18a1???
  71. Need help with release bearing
  72. Clutch gone, help?
  73. What is this sensor?
  74. Question about transmission
  75. S80 LS tranny - no reverse
  76. F20b axle help please !!
  77. clutch/flywheel ?s
  78. car jerks on acceleration/deceleration
  79. No 5th gear
  80. SL3 or L3
  81. Shift Linkage problem?
  82. Do i have to long of an axle?
  83. zc dohc tranny
  84. Will gsr 1-4 fit in b16 tranny? Both hydro
  85. F23b P2A8 5th gear swapped in H23a T2T4
  86. 4th gear issue in high rpms
  87. Drive-axle freeplay tranny side.
  88. Replacing Tapered Differential Bearing with Ball bearing GSR s-80 transmission
  89. Gripper lsd ..Anybody ever use ??
  90. ITR clutch / biting point - issues?
  91. D-series trans problems.
  92. What kind of trans fluid should I run in y21 clutch type lsd?
  93. trans top speed help
  94. 2007 civic si clutch issues HELP
  95. 5th s1 sleeve
  96. 3rd grind in LS trans
  97. JDM ITR
  98. gear 1/3/5 don t want to go in after tranny rebuilt...
  99. 2002 Odyssey Transmission Leak But Cannot Determine the Cause
  100. Clutch pedal changed distance needed to engage
  101. 1st gear thrust shim reuse with jdm fd?
  102. Radiator Cooling Fan
  103. Need assistance with LSD identification
  104. transmission or longer axle?
  105. Part Replacement advice needed on 90 civic ex manual transmissoin
  106. 1991 Acura Integra Axle Mystery
  107. will it work?
  108. Redline Lightweight Shockproof in B series
  109. Shifter Bushings
  110. ITR Tranny Overhaul, help with final Assembly stages
  111. B Series Mugen LSD Question (2 way clutch type)
  112. Limited slip
  113. Clutch Shopping
  114. output shaft seal
  115. 1990 accord manual trans problem
  116. What clutch do I need for my 98 Civic Hatchback that has a S20 B000 Si Tranny?
  117. best tranny option?
  118. S20-B000, just swapped noises/issue
  119. tranny swaps
  120. howi know if my tranny is GSR or LS
  121. B16A cable trans snapping clutch cables
  122. H2B Comp Clutch twin disc
  123. '80 5 speed will not shift into 3rd gear
  124. Swap whole tranny or rebuild?
  125. Hybrid B Series Transmission
  126. Act stage 4 clutch Could possibly bend my clutch forK?
  127. Possible H22A LSD problems. Help!
  128. ITR TRANNY 96-97 4.4 FD SPEC WITH 5TH GSR 5TH?
  129. To do or not to do?
  130. Who's a reputable tilton clutch dealer
  131. CV Joint help
  132. What is a GSR Cable Tranny
  133. Honda Civic Won't Shift in Hot Weather
  134. i need a longer shaft...
  135. 94 accord hesitates in reverse when cold
  136. Bent Gearshift Rod
  137. 2001 Honda Civic LX automatic
  138. Comptech header from b16a to 98 type r
  139. 91 integra clutch cable broke
  140. Torque converter stall speed
  141. 94 Integra LS Auto to Manual Swap (Issues)
  142. A quick question
  143. d15b, d16y8 tranny and clutch
  144. blox magnectic drain plug
  145. Trans experts... diagnosis help appreciated
  146. 140MPH all-motor
  147. A/T line identity picture (prelude)
  148. B16 issues after syncro install
  149. 06 accord auto to Manual swap, whats needed for swap?
  150. 1977 Accord CVCC Tranny
  151. speedo jumping occasionally and humming from tranny
  152. Feedback y21 4,785 vs y21 4.4
  153. Accord manual swap trans mount question
  154. b series cable internals in hydro tranny
  155. S80 transmissions started grinding
  156. 5th Hub Issues (B-Series Mainshaft)
  157. What is this bit called?
  158. Problems after trans work
  159. Cable S1 B16 Tranny questions
  160. Whining/grinding then hard shift reverse/drive
  161. fitting lsd in non lsd gearbox
  162. lsd problem
  163. 97 ls clutch pedal shaking and really bad vibration
  164. replace clutch or whole clutch kit ?
  165. jdm itr tranny no reverse
  166. Accord auto trans + Boost, will it hold up?
  167. tranny stuck in gear
  168. 01 Civic Ex D17A2
  169. manual civic shifts better when cold out side?
  170. Can't downshift into 3rd until rpm drops. Not grinding
  171. Transmission Problems
  172. Clutch chatter
  173. T2W4 lsd trans need info or sell?
  174. Hybrid Racing Shifter Assembly for RSX!
  175. flatten an exedy flywheel?
  176. 2 Transmition questions
  177. Help: based on photos what needs to be changed - 3rd gear grind
  178. What tranny and gear set shall i go with
  179. 3rd Gear grinds caused by damaged 2nd gear? causes?
  180. Shorter-ish geared D series trans question
  181. Itr tranny with 5th gsr gear
  182. m/t but dont roll
  183. Third gear grinds, reman trans
  184. 99 Si clutch hose fitment?
  185. Please help! Can't Shift out of Park
  186. 00 Prelude 2-3 grind and no reverse
  187. Is this the ATF fill plus on a 2003 Odyssey? (I apologize for the cross-post.)
  188. 91 integra cable to hydro questions
  189. Help me figure out this,Tranny 2nd gear whining
  190. del Sol auto to manual swap - confirming details
  191. 94-01 GSR 2nd gear.
  192. VSS,speedo cable
  193. OBX LSD
  194. b16 speedo ring on itr lsd?
  195. Kaaz diff comes with bearing?
  196. clutch cable lengths
  197. 99 civic Auto Transmission Problem
  198. gsr final drive into ls?
  199. swapping transmission internals
  200. 1990 Honda civic DX.. Loss of AT Reverse
  201. need help clutch issue
  202. Jdm 4.7 itr tranny hard to shift when warm
  203. 1990 auto integra issue please help
  204. oil seal on diff.
  205. Small spline B16 YS1?
  206. tranmission question
  207. Exploded isb outer race.
  208. Transmission grinds
  209. 2001 ITR trans 5th gear popped out twice then this.
  210. 99 civic clutch master cylinder help:/
  211. Building a D16
  212. GSR or Civ clutch master cylinder
  213. tranny rebuild feels funny
  214. Convert gear box b16a automatic transmation to gear box B18 automatic transmation
  215. 94 Integra LS Auto to Manual Swap
  216. 01 civic tranny problem-parts..
  217. Simple Goodbye.
  218. Wrong Clutch kit on a Y1?
  219. LSD going bad?
  220. S4C grind
  221. Cable transmission rebuild help
  222. trany rebuilt with clutch replacement pedal issue???
  223. Shift Shortening DIY
  224. transmission Help
  225. bolt sizes
  226. Is this possible?h2b,h22,crv tran,rt4wd
  227. Clutch and LSD Options d15b7 with Si Transmission
  228. stock k20 turbo act clutch failure
  229. Gsr won't go in gear
  230. decieding on tranny
  231. civic 2001 auto trany sound
  232. new flywheel weight?
  233. 35mm diff bearing part number?
  234. 94 Accord Wagon H22A w/M2Y4 trans: What axles should I use?
  235. Gear cone scuffing to fix score marks
  236. 6 Speed swap
  237. Changing tranmission oil?
  238. GSR 3-4 shift fork excessive play
  239. Transmission repair/questions
  240. clutch kit price?
  241. shifter cable and assembly questions.
  242. transmission/clutch going out on a b16
  243. M24A (auto) tranny won't fit D15B7
  244. Car not well after CV Axle replacement
  245. b18 tranny help
  246. 04 TSX A/T problem
  247. Motorcraft full synthetic manual transmission fluid okay for Civic?
  248. Honda accord 2006 exec stiff clutch
  249. 91 Ef B18a Trans grinds in third and fourth
  250. confused about my trans
