- k20 tranny problem...please help
- Leaking Fluid
- Torsen lsd - reversed rotation?
- shifting problems
- Tranny Not Working Right.. Help
- Axle Trouble..need some help please
- HELP, Rough Idle jumps from 2300k to 1200k constantly
- tapper diff bearings to ball bering change help
- Car wont start, possibly clutch?
- sprung or unsprung for dd
- Help????!!!! Grinding noise from trans, car wont move(Aquafina or Mfactory)
- Five Speed Trans ?
- Will an 88+ CRX 5sp MT fit in an 87 CRX Si?
- could anyone tell me brand of this twin disc
- Where to buy new/rebuilt performance cable transmission.?
- Shredded Y8 final drive, why?
- what lsd will work in my gsr tranny
- 4.266 Close ratio?
- Flywheel/pressure plate fitment issues
- Rebuilt tranny bad?
- anyone kno a good final drive write up
- 90 accord H22 auto. to 5 speed help.,.,plzzz
- Whole Lotta Shakin' Goin' On
- Competition clutch stage1 issue
- Ls tranny with si 1st and 2nd HELP
- A/T hard downshift (2-1) when stopping. 1998 Accord.
- 1989 Transmission Swap Questions
- auto trans
- 94 Integra Front Wheel Bearing replacement
- Differential Bearings?
- I want a 5speed ek conversion!
- no 3rd in 08 si..?
- '99 Odyssey Transmission Teardown
- Shift linkage issues
- thirth gear grinding
- Which tranny do i need??
- 96 integra clutch problem please help
- hard to put into gear
- Which shim do I use on my diff?
- Installing driveshafts on a 94 b18c
- Please help, tranny noob and i need a new box asap
- Is my transmission shot?
- trans mainshaft wont turn
- Axle won't go in all the way?
- 1996 honda civic h22 swap !!! axle help !!!
- Any single plate clutches good for 350lbft??
- Aquifina, Mfactory Customer Service
- single or twin?
- 98 odyssey (F23A7 Vs.F23A1) trans. 4cyl
- b16 vs gsr trans need help for honda day!!
- Ar the bearings the same on prelude cv joint and integre cv joint
- LSD for a 1970 honda 1300 coupe 9S?
- Will b16 gear set fit in a gsr tranny with out no problems...?
- f23a tranny (01 Accord Coupe)
- Tranny Starts Grinding 3rd and 4th
- Cusco LSD what fluid?
- Axle seperation during shock change?
- What LSD is best bang for buck?
- Cable tanny in a eg hatch, without a conversion kit?
- clutch question
- clutch, intermediate shaft idk ? HELP
- What pressure plate to use???
- transmission noise
- HELP! CC twin disc damage.
- Help diagnose my symptoms
- hi b16 auto tranny
- D16 S20 Vtec Trany with 4.40 final gear?? good for Turbo or not???
- Spec clutch r junk dont buy one
- Major transmission issues - b16 hydro
- shift issues
- transmission problem? Clutch?
- transmision intrechageability
- DSS customer service
- HELP CAR STUCK IN DRIVE
- mainshaft will not turn?!?!
- B16 Tranny for GSR w/ LSD? OPINIONS NEEDED!
- EK9 LSD to EK4 Gearbox?
- HELP!!2000 civic auto to manual tranny swap will not rev over 4200? Any ideas why???
- Odyssey MPJA gear ratios.
- b20a5 or b21a1
- clutch issues/tranny issues, i dont know but it's weird
- cable trans with aftermarket gears
- auto tranny in 97 civic????
- 08 Accord EXL V6 6 SPD Std Input Bearing ?
- honda orthia, what european model compares for mechanical parts
- Gsr with obx? need opinions!
- J1 transmission Q's
- Transmission noise from 2006 Accord Coupe V6
- 95 ls tranny ?
- *Short Throw Shifter*
- Mini Twin Spec Clutch Question....
- y1 tranny question
- no pressure in clutch pedal.
- Quick Question:Will a integra clutch resevoir fit/work with a 95 civic?
- Shortest tranny to a h22a4
- GOT A TRANS QUESTION
- k20a2 tranny problem....help
- Need help with 1993 accord TCU codes
- shift linkage pin
- knocking noise in my tranny need help
- Help to identify this plate LSD
- to anyone who daily drives with a mfactory 4.9 final drive kit
- Part number question
- ls trans flare-up?
- type r lsd trans shakes under load
- welding hydro case
- Final drive swap?
- gsr casing
- Hard to get into gear...
- Clutch for 600whp b16
- gsr locked up after case goes together
- B-series tranny/clutch trouble
- new clutch slave still leaking???
- 2007 Acura RDX transmission problems
- ACURA INTEGRA TCM SCHEMATIC??
- problem: hard shifting in/out gears b16
- vss/speed sensor
- Shifter Problem? Pic inside.
- A little help? : Starter spins freely
- Short Gear / Final Drive / Flywheel, Too Much?
- need another pros help
- ppg dogbox on the street .....will it last ...
- replacing my clutch master cylinder
- 2002 Civic SI Shifting Issues
- Axle will not clip into transmission... Literally tried almost everything.
- RXS-S 02 Shaking front end under high load during acceleration
- Torco Question or Advice.
- transmission whine and grind
- Need help asap on flywheel resurfacing
- SPEC Clutches?
- j1 tranny/4th gear poping out!!!
- Are all B-Series Clutches interchangeable???
- Transmission seal / O ring question and axle will not snap in
- Exedy Stage 1 clutch for B series Review
- 90-91 twin disc nonexistent???
- uprated cv joints
- SP7A upgrades?
- LS GSR TRANNY
- Crx Short Shifter Problems. Need Help???
- LSD Grabs During Sharp Turns
- type r trans diff?
- Which transmission..
- manual trans transplant?
- need tips or pointers for changing a b series clutch
- F22 trans questions
- JDM Automatic Transmissions
- 2000 S2000 transmission rebuild ?
- Estimated New clutch install cost? If i buy the parts?
- need help picking new clutch for my da9
- please identify this lsd
- Weird clutch problem - soft pedal, Clutch master cylinder is gone?
- Hydraulic throw out bearing vs Slave Cylinder and Fork
- Clutch is loose, won't go into gear - help
- Need A New Transmission - JDM or Rebuilt?
- B series mfactory LSD for sale. For Gsr sytle trans.
- experience with Luk clutches.
- 90-91 Integra Throw Out Bearing in S80 Tranny?
- cable to hydro write ups, have there been any done?
- Brand new usdm itr tranny grinding!! ????
- The right dogbox 4 me?
- J1 Internals into a 90-91 LS integra tranny
- What drive shafts are these
- Two day old tranny/clutch not working?
- 5th gear grind after rebuild
- Keep breaking cv joints soon i move the car
- Hard to shift into gear when car gets into operating temperature
- MY SYNCHROTECH EXPERIANCE
- ULTIMATE TRANNY SETUP???
- D16y8 Tranny
- *reverse problem*
- D16z6 - 400whp - Tranny / Axel Advice / LSD
- bearing help
- LSD's in Snow
- Do I Need A New Diff?
- flushed the clutch fluid and now pedal is very firm
- in theroy would this work?
- EP3 clutch kit OEM or ???
- d17 clutch issues
- B16 vibration issue. Possible Differential?
- D Series Hydro Vs Cable Pressure Plate
- Re-Assembling DC2R Tranny --- Help Please
- thrown forward at accel
- p21 clutch fork
- Clunking noise on the driver side - need opinions
- Clutch or Transmission Failure??!!
- turbo d16 bracket racing car tranny?
- jdm YS1 gear box
- Parked at the Circle K and could'nt make the car start....D4 LIGHT BLINKING
- PPG DIY? Some questions before I attempt it.
- JDM 96 spec itr tranny gsr 4th Ls 5th gear help
- Car will not go into gear! need help.
- LS tranny with Type R internals Questions?
- Slipping atx?
- Tranny fluid leakage
- B-Series Tranny Vin Plate Holes
- Which clutch? F20B/M2Y4/Fidanza 8.8 FW?
- Help, how can I break open this gearbox? D16
- will TYPE R LSD fit a GSR transmission
- Car shakes in 1st gear/reverse
- kaaz honda Diff - Looking for a broken unit.
- 5spd first gear in a 6sp?
- 99 Civic Replacing Transmission...Any Tips?
- Transmission Problem
- 95 Accord F22b auto trans issues....HELP!!!!!
- Usdm Type R tranny, LSD jerky through turns
- gsr tranny problem?
- I cant id my b series tranny
- clutch engagement
- d series transmission help
- will a b18a/b differential fit on a b16a2 tranny??
- 92 Civic Auto Trans Kickdown Adjustment
- Clutch fork stuck
- Clutch stuck to the floor
- 96 jdm type r tranny in ls
- Car shaking when releasing clutch / flywheel question
- 2nd gear issue on a 2000 Si
- H22 tranny gear Compatibility
- b16 clunkng noise when driving?? stops when i enagage the clutch help!!!!!!!
- aftermarket lsd? witch one works, witch one to avoid?
- axel/cv joint question
- anyone used a welded diff??
- Which Tranny would you choose!? GSR
- syncro help
- gsr case replacement..
- Pressure Plate and clutch install
- Removing ring gear bolts that has loctite
- Transmission whine. Need some advice.
- Anyone know of built Honda automatic setups?
- how to check if tranny is bad
- S20 tranny giving out problems???
- GSR Transmission Problems...PLEASE HELP
- ttrany rad with verly low fluid
- If The Trans Is Over Filled
- Honda Odyssey 2001 bad transmission
- oem ecu signal for auto
- transmision identification???
- all vss's created equal?
- 1996 Honda Accord Auto Trans - Just replaced Tranny still slipping - HELP
- Throw out bearing? and?
- differential speedo gear
- j1 tranny problem broken release fork
- j1 tranny problem
- which Clutch and Which LSD?
- D16A6 Transmission Rebuild Problems
- Tranny swap q
- reverse issue with b16 y21 tranny
- MFactory FD installed, thank you Chris!!
- Tranny rebuild rehash
- axles, 30/32 spline
- Transmission code P0700
