PDA
View Full Version : Transmission & Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31
  1. Difficulty Level on Installing LSD?
  2. Y80-GSR tranny Problem (help!!!!!)
  3. Bent 3rd-4th shift fork? 99 Si
  4. Transmission Surge
  5. second gear whine
  6. 92 accord tranny? code 1!
  7. Whining noise
  8. Unknown B-series Transmission
  9. auto tranny help
  10. Clutch
  11. Flywheel upgrade
  12. Pressure Plate Bolts
  13. gear swap
  14. interlock giude bolt
  15. LSD for S9B
  16. 92 Civic Auto Tran. help
  17. clutch
  18. D16y8 Transmission (s40)
  19. b-series Cable YS1 tranny
  20. ***s!
  21. m-factory final drive
  22. D16Z6 transmission upgrade/rebuild
  23. spoon b16 lightened flywheel?
  24. B series tranny identification
  25. automatic to manual swap?
  26. internal rust in tranny
  27. gear ratio charts for all D series Hondas?
  28. 2nd gear??
  29. J1 LSD question
  30. Flywheel Identification
  31. hard to shift
  32. Need help in looking for a new clutch and flywheel for 06 DC5
  33. Bad 4th gear.....what to replace?
  34. idk tranny problem
  35. Decent Performance Clutch
  36. transmission repair shop in pa
  37. B vs D series VSS (please help before I try)
  38. Does the ls final gear fit in the b16 cable tranny without changing the gear set?
  39. Driver side axle removal....help?
  40. p20 D series Transmission final drive question.
  41. HELP ~~ Output Shaft Seal Leak!
  42. trans poping out of 5th
  43. 2001 Lude auto tranny
  44. Stiff Clutch Pedal
  45. Competition Clutch
  46. Gsr lsd?
  47. transmission rebuild parts and shop?
  48. CV joint pulled apart
  49. car doesn't engage any gears, 94 Integra, auto trans
  50. jdm gsrr drivetraine promblem hlp plz
  51. j4d itr tranny
  52. throw out bearing question
  53. 4.9 Fd + CM 7lb flywheel/stage 4 clutch = Streetable?
  54. Tranny knocking cluncking
  55. After GM syncromesh. grind got worse?
  56. What do you guys think about this?
  57. D16 Trans Help!
  58. Vibration On Acceleration
  59. B series Trans issues :(
  60. civic tranny swap
  61. ITR Flywheel
  62. ITR Tranny
  63. A6 tranny issues
  64. Far Out Clutch Engagement?
  65. Is an Auto tranny easy to install like manual?
  66. Help please
  67. Help me diagnose..Strange Clutch/Tranny Problem
  68. tranny build ?
  69. Clutch engagement problems
  70. Transmission manuals exsist?
  71. GSR trans w/ LS 5th gear
  72. Hf 5th gear
  73. Y21 trans gears??
  74. Acura tsx / honda accord (euro) - same clutch kit?!?
  75. ACT clutch doesnt feel good
  76. JDM B16 lsd tranny ring gear?
  77. *Y21/S80 transmission help*
  78. AUTO into MANUAL?
  79. No Reverse
  80. How to tell difference between final drives
  81. sgiter is stuck
  82. 1st gear engagement issue...
  83. Replacing Auto Transmission...Torque Converter Alignment???
  84. help with gear ratios
  85. b series ring gear torque
  86. Double cone synchro on first gear?
  87. GSR tranny issue. I think somethings binding up.
  88. something is slippen. may be trans?
  89. 97 civic tranny help!
  90. Help please, I cant remove the c-clip.
  91. find out if the tranny is stolen????
  92. What tranny is this?
  93. How to IDENTIFY EX/SI TRANNY ?
  94. Mating a B18c5 hydro Transmission to B18a1
  95. Good Clutch
  96. jewelry
  97. Aftermarket Tranny Support
  98. 3rd gear jumping out of gear when i step on the gas
  99. r4 vs s80 both lsd, any difference?
  100. rebuild or new/used transmission
  101. NON-Honda Alert...clutch wear issue on E36 m3
  102. tranny swap question please help
  103. good or bad
  104. 93gsr ys1 tranny does it come with lsd????
  105. How much could i sell this for???
  106. Lsd install problem
  107. Forgot something during my final drive swap...is this ok?
  108. Unlock Your IPhone, Other Phones - How-To
  109. intermediate shaft and axle for eg
  110. Advice on D series LSD?
  111. b16 and type r tranny highway speeds?
  112. tranny interchange help!!!!!
  113. D Series Tranny Rebuild
  114. Humming noise at 50 mph and above
  115. Carbonetics LSD Noises?
  116. vibration under acceleration - tranny related? You decide!
  117. lsd install: cracked speedo ring
  118. Clutch Engagement issue, weird....please read
  119. Transmission driveshaft seal replacement
  120. Will ls cable final drive fit in an ls hydro??
  121. d16z6 tranny fluid?
  122. clutch question
  123. Update - How well will an LS tranny work with a b20 vtec?
  124. Transmission Problems
  125. Whinning Noise when clutch pedal is pressed
  126. Y80- GSR hydraulic tranny noise (B-series Help)
  127. So whos good with b series transmissions!?!?
  128. Tranny drivers side seal
  129. Question about JDM LSD and GSR final drive
  130. idk whats wrong with my 2nd and 4th gear...
  131. Who makes the strongest FWD manual tranny?
  132. Need help identifying Transmission Noise
  133. Transmission help!
  134. To get or not to get LSD? and why?
  135. Automatic transmission slipping after fluid change.
  136. To hybrid or not to hybrid...
  137. What grease to use on clutch fork pivot?
  138. obx lsd
  139. presure plate bolts.. can i reuse them?
  140. Wear and Tear - AUtomatic Trans
  141. Oil for tranny with Mugen clutch LSD
  142. How much is this trans worth??
  143. Gsr tranny noise help
  144. gone and confused myself (s4c 2/3 gears)?
  145. Transmission Help!!!
  146. clutch master cylinder which one to get?
  147. tough shifting
  148. ATTS light Help?
  149. can somebody confirm that i need new axles?
  150. Hard metallic sound when letting off clutch in first
  151. cable tranny questions
  152. mainshaft washers
  153. Manual transmission fluid
  154. Cable s1 rebuild
  155. D/B Series Fastline Shifters interchangeable.
  156. How to convert cable trans to hydro?!?
  157. USDM GSR YS1 (92-93), need help
  158. tranny rebuild kit
  159. Transmission help/advice
  160. pops out of 4th gear
  161. Aftermarket Flywheel, Teeth rounded, not starting
  162. Transmission internals = i know nothing, ha help!
  163. tranny causin motor to shut off?
  164. Part numbers for hydro LS, GSR, SI...
  165. need help with rebuilding my tranny
  166. ys1 countershaft s/ring
  167. D series trans intermittently not working
  168. b16 LSD
  169. 96 gsr tranny
  170. Need help please
  171. Trans feels like i have peanut butter in it
  172. Good Manuel transmission cleaner?
  173. Piston hitting sparkplug?
  174. tanny help
  175. ************helpp!!!************
  176. Transmission Problem With 01 EM2
  177. Rebuilding my J1 Tranny soon, need info.
  178. JDM B18C Transmission low rev grinds high rev smooth shifting
  179. GSR tranny problem
  180. should you beable to turn an lsd by hand?
  181. 1999 Accord LX 2.3 Auto Tranny Issues
  182. Fidanza 3.2
  183. best place to buy transmission?
  184. How much to repair?
  185. Tranny sound?
  186. having probs with reverse!!!!!
  187. 2002 civic ex please help me find out whats wrong
  188. ****B series trans HELP!!!****
  189. input shaft bearing
  190. is it time for a new clutch?
  191. Transmission makes funny noise
  192. 2002 Accord LXi CF8 2.3 auto - reverse problem
  193. k20a2 with ep3 tranny Help?! :)
  194. k20z3 Transmission
  195. ? advice on a clutch
  196. is it bad to leave a transmission cracked and open?
  197. when i let the cluth out i hear grinding !! please help????
  198. advice on rebuild
  199. crv transmission
  200. Is there a B16 lsd install walkthrough?
  201. Quick B-Series transmission question..
  202. fresh rebuild/ now wont shift
  203. my tranny makes noises like my axels are bad
  204. big shift linkage problem, help!
  205. B7WA/M7WA auto trans: have a look.
  206. b17 Tranny with LS Clutch?
  207. OEM d16y7 clutch for 200whp?
  208. 2 trannys to make 1
  209. input shaft bearing
  210. Tranny issues (3rd and 4th gear sometimes pops out)
  211. '03 tranny problem...
  212. New clutch, drove for 5 seconds, now nothing....
  213. Tranny noise please help!!!
  214. Cable tranny parts to hydraulic tranny
  215. act prolite or streetlite fw?!?
  216. What kind of Syncromesh
  217. b-series tranny conversion
  218. OEM or Aftermarket Half-Shaft (B-Series Q)
  219. 4bidden still in business?
  220. D-series bearing sizing - how to without opening???
  221. Lowest B-Series OEM 5th Gear?
  222. Help!!!!!!!!!!
  223. What Flywheel and clutch to run with 450-500HP?
  224. B18C LSD into B16a2 trans?
  225. putting a USDM ITR LSD into a S4 trannt(2000 civic si)
  226. oil seals
  227. Syncro problem??
  228. intermediate shaft!!
  229. D16z6 tranny issue!!!!
  230. Clutch Question
  231. squeaking noise
  232. Won't Go into ANY gear! HELP!!
  233. clutch plate warped, quick question
  234. b17a ys1 cable to hydraulic
  235. Car does not have 1,3,5 gears
  236. Replacing 1st/2nd Synchros/Sleeves
  237. swapping 5th gear for My ZC lsd tranny
  238. how in the hell do you change rear mainshaft bearings
  239. Gear box oil
  240. Calling LSD Experts: Help me pick the correct lsd
  241. d series tranny probs
  242. what happened to my clutch??
  243. 91 Accord clutch pedal on the floor (no presure)
  244. PLEASE HELP tranny issues!
  245. 98 gsr shifting issues.
  246. Vehicle Speed
  247. Grinding in 3rd and 4th, broken piece inside?
  248. ls case gsr gears ?
  249. GSR Trans Problem!!
  250. H22 final drive for all motor set up?
