- Metal Scraping Sound After Shifting and Accelerating
- Strengthening gears
- Synchrotech carbon coated synchros...
- Shift linkage/cable broken?
- 2001 civic where is the transmission control module
- ek9 b16b crank shaft pulley on ek4 b16a
- '87 Accord auto trans won't upshift from 2nd gear
- '87 Accord auto won't upshift from 2nd gear
- k20a2 2nd gear replacement
- help with left axle removal B18C
- Unusual question
- need help selecting a clutch for my setup.
- Identify YS1 gear set
- cable trans will not go into gear
- B Series Final Drive Install
- b16 transmission shifting issues
- ticking/rattle in 5th gear
- New flywheel pivot bearing loose. - F22
- 3rd and 4th gear problem
- Help!
- Hybrid 88 Si / 92 VX trans - 3-4 Shift Fork?
- Cant build pressure in clutch
- Clutch information
- synnchrotech rebuild kits
- No pressure at clutch, help !
- 91 honda lx trans probs
- First post can somebody tell me if this is normal?
- Flares all upshifts and harsh downshifts. No DTC. No line pressure.
- 2001 v6 accord oil leak
- jdm f22b auto transmission question
- How many quarts?
- F22 Tranny Problems
- Motor Oil for Transmission???
- Trans questions
- tranny b16a1 89 integra
- RWD CCW Transmission
- help: ls 5th fit in crv awd tranny?
- Accord not going into reverse 5SPD Help!
- so many clutches so much time
- 88 Honda accord trannys
- M2B4, T2T4, difference?
- Diff shimming issue
- D16Y7 A/T Problems
- slipping sound
- need help car wont move in gear
- Mix & Match GSR/b16/LS differential
- Which VSS to use
- Hard time going into reverse
- Any experiences with XTD clutch/flywheel?
- Trans will not shift to lower gears after 5th unless you go to 3rd first
- reverse thrust washer in b series wtf
- engine vibration after clutch install
- 1992 Transmission Issue
- Tranny Swap
- L3 Trans in a b 16th integra
- REINFORCED CUSTOM PARTS RTAWD & CRV GEARBOX
- clutch choice
- Tranny interchangability?
- Trans/diff issues.
- Mainshaft shim clearance question
- 05 Honda crv question
- h22 tranny acting up??? HELP!!
- Noise after clutch install on 09' FA5
- B16 Tranny Problems
- Tramsmission cases
- Some ZC/SI hybrid trans questions from a nOOb.
- Speedometer does not work/ D4 does work light up
- Engine Whine at Low Gears
- Phantom grip for D16 buggy?
- OEM B16 Y1 LSD into cable LS transmission possible?
- Replacement Gears
- d16 automatic won't catch gear after normal operating temp
- Cable/Hydro gearing interchangability ?
- Single clunk when braking
- Rare RTSi INTRAC rear diff info
- LS hydro transmission with GSR/B16 gears
- Whats a great shifter?? 1990 integra
- 04 TSX shifting issues
- Synchro rebuild kit or just gears
- Blown diff??
- swap automatic transmission k24
- How bad is this transmission?
- Cant get the driver side axle out of the intermediate shaft
- How to remove shift fork?
- Wilwood generic clutch master matching F22 manual box slave? For RA RHD conversion.
- b series tranny help
- Options for taller gears in 2012 Fit?
- Where do i find a exedy clutch alignment tool???
- 4.7 oem FD
- H22 4th to 5th swap
- 97 crv awd tranny issue
- Stolen Transmission
- HELP missing tranny bolt10
- Y1 Cable Tranmission. LSD or not?
- Cracked Casing
- Tricky CEL..
- need help identifying after market LSD (b-series)
- LSD ID in YS1 Trans
- transmission issue
- 96 gsr trans in 90 integra
- Late Shift/Delay 1999 Acura CL 2.3l 4 speed Automatic
- b16 s1 or b18 s1?
- 1990-91 integra clutch question
- seal leak or something else
- transmission shifts funny
- Gears do not mesh
- need help please
- D16Z6 clutch / slave cylinder bleeding
- car won't go into gear while is on but goes into gear while the car is off
- Need some towing info
- Mounting a B18 facing front/back
- no 2nd gear... please read.
- Phantom Grip Brace? or info on other brace
- RWD Swap Question
- my 91 integra grinds when i put it in reverse
- my 91 integra
- Shift linkage is hard to get into gear. Something's not right, help
- 2002 civic si ep3 trany is chirping??? please help!
- Towing car without axles?
- Built automatic
- Shift at high rpm but don't want to/vtec
- b16a y1 lsd compatibility.
- 1999 Civic AT grinding in Reverse
- intermittent slipping when accelerating
- Quaife LSD pre load spec with tappered enclosed bearings
- To LSD or not to LSD
- 2001 Odyssey trans speed sensor location
- p0715 honda code
- H23 - Clutch Pedal Increases?
- online dealers
- Honda b16b Engine/tranny not connected
- Magnefine Transmission Filter Installation on 6th Gen. Civic
- 1987 crx si transmission questions
- 98 Integra GSR stuck not typical 5th gear issue
- tranny swap
- all motor set up b16 trans or gsr
- 1997 Accord EX (auto) Shifter Issue
- 3rd gear syncro replacement
- B16 Trans Reverse Problem HELP!!!
- Gator axle replacement boots
- D17A1 Transmission compatability
- Type r tranny and h2b questions. Need help
- ITR HELP!!!
- Hydraulic leak ? Please help
- d14a4 gearbox swap
- Phantom Grip, do they really work
- civic swap
- What axles to run on a b16a trans in eg
- 99 Honda Accord ECM/ECU Transmission question
- whats interchangeable - cable to hydro b series
- H23 trans on an F23 block??
- Ek9 clicking noise diff/axles??? HELP PLEASE!
- 2001 CL type S transmission
- Need Help
- B16 del sol driver axle
- What US spec clutch fits a 97 JDM spec b18cr?
- can't accelerate beyond 3.5(x1000r/min) on my acceleration meter.
- H22 input shaft ?
- 94 Honda accord tranny ?
- transmission confusion?!?!?!
- HELPPPP!! New Clutch Slipping!!!
- tranny swap
- Innovation hydro to cable mounts?
- 2000 honda civic si problem HELP!
- Using 03 TL (non-S) transmission in 02 Odyssey
- Honda Shuttle EE4 gearbox hybrid
- 05 civic hybrid CVT shudder and stall if I try to move it to gear
- Auto to manual swap possibility??
- 3.471 FD
- what sohc cable trans is this ?
- UR clutch and 8lb flywheel question
- Rebuild kit (with bearings) for BMXA automatic transmission?
- Y7 Transmission metal spring
- What clutch to get for my 1997 honda civic lx?
- S4C Noise has me lost! Helpppp!
- VSS bad in tranny??
- 2014 Honda Pilot Transmission/Shifter Noise
- my syncrotech si tranny just arrived mating to b8!
- my transmission blew up two days ago whats a good replacement
- 1997 obd2 teg, getting built obd1 swap
- think my clutch went out. any help would be appreciated
- stage 1 clutch advice
- Hydraulic Clutch Issues (91 Accord w/ pix)
- viscous lsd info?
- LS trans dead?
- case wont close after taper to ball bearing swap
- Lost 5th gear
- b18 itr synchro problem
- sagitaux
- Da9 Clutch Problems, PLEASE HELP
- 1998 civic transmission issues
- Spongy clutch
- Ls trans casing on Gsr transmission
- 98 civic hx transmission compatibility
- problem!!!
- The dealer installed an aftermarket trans...is this acceptable?
- B16 Trans grinds in 3rd & 4th after rebuild
- h22 transmission.. help!!
- TL Cruise Control
- b16a2 aftermarket LSD
- Whining noise from tranny
- 94 accord auto transmission slipping
- B16 lsd or type r tranny??
- OBX LSD Diff passinger side problem resolved!!!!
- P2U5/P2A5 LSD?
- MODs can we have a stickied 'for sale' section like other sub-forums in here?
- TSX AT to MT
- gsr LSD transmission wtf
- B-series Trans Seals
- 97 civic HX 1st pops out.
- Need Honda Part # for EM1 Front Wheel Bearing
- OK to replace auto trans fluid with synthetic?
- Help me drive stick better please! New clutch!
- B16 LSD Trans making Noise
- 94 Civic 5spd Won't Go Into Reverse
- EM1 Inner CV Joints have play causing axles to wobble
- New clutch/Lost Pressure Help!
- transmission leak
- wha lsd can fit in a d series transmission?
- Pop/knocking when letting off the clutch pedal
- Transmission builder in Toronto
- Fit valve adjustment
- About to get a new clutch, please help.
- Continued transmission
- b16a2 and s80 gsr allmotor
- tranny
- Stage 1 Exedy Clutch Kit Replacement
- Strange vibrating noise while accelerating
- need help I want to know what transmission I have
- Sequential shift for a run of the mill honda automatic
- 2000 Honda civic stainless steel clutch line for this?
- Automatic transmission hard shift from wrong tranny fluid?
- Honda constantly engaged throw out bearings
- 96 integra runs but will not start
- Auto trans goes neutral
- 1st Gear Problem
- Cable to hydro, confused? Need inputs
- tranny wont go in 4th gear
- Transmission problem
- 1996 Honda Accord V6 Auto. hard downshift and Tranny Fluid capacity
- ls final drive on b16
- D16 JDM w/Auto Tranny, Any hopes/Performance?
- transmission lock up
- F to H trans swap
- is my clutch/tranny bad?
- Won't shift
- gsr tranny mount on b16 motor ?
- need opinion on ex 99 s40 and important ? and on my s20 in eg hatch
- H22 tranny gear swaps
