- which clutch should i get? k20a
- People who have rebuilt your trans, Chime in!
- Problem with axle and OBX LSD!! Help!!
- Grinding into gear, abrupt clutch release, whirring noise.
- CLUTCH WON'T ENGAGE
- Carbon Synchros, how many miles so far?
- My flywheel
- f22 Transmission Opinions PLS...
- altenator problems leading to trans going out??? or coinsidence?
- trans and axle help !!!!!!!
- 4.785 fd trans or 4.4 fd?
- time for some technical crap
- help cv axle
- Issues
- a little tidbit of info for those who like to mix and match their gears
- DIY Short throw shifter/bearing conversion.
- gsr lsd recommendation(400+whp)
- Strange Trans noise y7
- r/s hasport axle broke fully build gsr
- LSD off center?
- b16a transmission whines
- HELP-Tranny Issues
- shifter doesn't move side to side, only goes into 3rd and 4th
- Rack and Pinion
- Trans Experts: Shop botched Quaife Install?
- clutch pedal says on the floor when pushed?
- thought crossed my mind here....auto related
- b16 trans jammed after rebuild??
- Need help asap. New clutch not engaging
- Trans lurching in my 94 Civic... Help plz!!!
- Straight cut gear kit
- picked up a 2000 integra ls auto 500 bucks blown trans tho
- Transmission help badly!
- Tall gearing for B series trans
- flywheel opinions...
- Adding a fifth gear to EF STD tranny?
- Does a 97 civic tranny fit my 94 civic? help!
- Winter Trans Oil recommendation
- my teg making some noise
- B series Tranny ID (wierd Gearing)
- 97 Acura CL 2.2vtec auto tranny problem
- K-series cuff
- BIG PROBLEM! with newly rebuilt trans.
- Basic Honda Auto Trans maintance
- Strengthening/Hardening..
- 4.4 final in ls trans
- multiplate clutch
- help to identify gearbox
- ITR differential? strength/fitment?
- Is this clutch stiff?
- non lsd diff in itr case issues...
- 2001 Gsr Tran problem. Car lunges forward.
- Hybrid Tranny Question
- welded diff
- NEED HELP REMOVING MY AUTOMATIC TRANSMISSION OUT OF MY DA
- won't go into gear when engine is running
- flywheel question
- "Delay" with clutch disengaging at high RPM
- My quest fro a nice tranny
- fidanza flywheel loctite pressure plate bolts????
- B-series clutch and flywheel on K motor?????????
- Need help identifying diff
- jdm j1 trans on 92 DA? clutch Question.
- gsr tranny issues
- automatic tranny
- Transmission Type
- B-series tranny question.
- usdm itr trans
- main & *o*ntershaft bearings: p*ller req'd?
- Diagnose This Sound!
- what tranny is best for b20 auto 90DA swap??
- Shifting issue
- D17a motor, 95 DX Transmission?
- New Clutch
- Need Help.. Clutch Fork B-Series.. Which one do i need????
- YS1-Y1 question and trouble
- Please help:Chattering noise and no clutch engagement after new clutch and new engine
- What do I need for 5-600hp?
- Findanza Fail ....
- Final Drive Swap 96 to 98 spec???
- B-series reverse gears..
- 93 EG6 SiR Gbox Whining When down shifting
- tranny swap question
- Trans HELP Asap!!
- Torque Range Inputs for stock transmissions
- shifting problems
- having tranny trouble, PLEASE HELP!!!
- simple question
- Difficulty shifting into first and then second
- Light whining noise in 3rd 4th gear
- Need New Clutch Advice Asap
- Need answers baaaaadly!!!
- Help Identify this LSD please
- Is this the part i need? 23471-P20-A00 GEAR, COUNTERSHAFT THIRD
- not going back together
- GSR Tranny Issue
- 97' Honda civic lx
- Need help identify which bearing inside tranny going out
- ls vtec turbo clutch
- Buying a transmission online?
- good clutch for b16?
- clutch engagment issues d16z6
- GSR tapered bearing help
- hole in my tranny...
- B16 hydro trans help
- differential question
- tranny questions
- s80???
- no start/ crank condition
- Clutch Master Cylinder 3rd F'ing time!
- 96 civic gsr auto
- This is for All You ACT users Beware!!!!
- Will my transmission last?
- Need Z1 ATF for 2005 Odyssey.
- Can shift gears at a stop with out pressing the clutch & car does not move.
- Reversing trans output rotation - flipping R&P - Reverse cut gears, etc.
- Shift fork bolts with spring inside and ball please help me!!!!!!!!!!!!!!
- clutch from B motor fit K motor?
- HELP!!! NEED TO FIND CLUTCH FOR MY BUILT MOTOR...
- trany questions
- b16a2 2nd gear grinding
- twin dics or single clutch kit
- tranny oil leak
- shifter
- Using GM syncromesh to stop 3rd gear grinding???
- NEED SPEEDO DRIVE GEAR
- Whats the difference? 99-00 S4C b16 tranny vs 96' Spec jdm ITR tranny
- Team honda did not do something right when they put my tranmission back in my 07 si!!
- ***Need major help with grinding kaaz lsd trans!***
- i need help with my leaking trans! da ys1 help!
- b18 clutch in a b16 tranny?
- b16 cable and hydro question
- question
- mainshaft bearing went bad..can i use this bearing?
- D16z6 Tranny Question
- Curse of the '90 Hatch, new problem with transmission, please help
- gsr tranny help!
- FYI: B-series LS 64-tooth ring gear
- Half Shaft Shopping for my SI Swap
- Axel keeps poping out of LSD Help!
- b16 non lsd tranny replace or fix
- '01 Accord (auto) Transmission Problem
- A1 Transmision Grind
- Hydro LS Syncro Sleeves in YS1 possible?
- Gear housing Axles Seal... Leak,, advise me please!
- y1 lsd into ys1 case
- Shifter Bushings
- Difference between hydro and cable trans and how do you tell the difference
- Help me on This Tranny!!!
- opening b series trans case
- 2001 honda accord
- how do i tell if my gears are no good
- Short shifter and parts question
- clutch on and off?
- How to inspect a Quaife lsd.
- b16 wount go into gear
- Final Drive q's
- after market lsd in jdm Y1 lsd tranny
- stock z6 trans rebuild for a friend. need syncros and.....
- b16 tranny clutch wont engage
- Clutch wont engage all the way,but goes into gear
- i just replaced my tranny but now my car wont start.
- Swapping B series gears
- 2010 zdx won't downshift with paddle shifters
- Countershaft Snap Ring Won't Seat
- 1988 Honda Accord Lxi 5th Gear Out- Need Help Please!
- destroyed reverse gear
- HELP PLEASE!!!1992 Honda Accord EX trans problem...
- Reuse diff bearings from one diff to another
- Competition Clutch stage 4 installed
- cross country or not...
- SHIFT LINKAGE MOUNTS
- need feedback ASAP on ACT or Exedy Flywheel???
- CAR SHAKES WHEN I TAKE OFF.. HARD TO SHIFT GEARS! HELP ME!
- S8G - Is anyone familiar with this transmission?
- GSR vs ITR Tranny for B series
- which tranny to go with????
- Not really sure whats wrong. Probably trans related
- Using an exedy stage 2 pressure plate with an act disk?
- Big spline
- Just a test thread
- LOUD Screeching noise when clutch pedal is pushed in.
- DIY upgrade zaxel questions......?
- 4 speed to 5 speed
- F1 racing clutches
- cable b16 tranny into 97 ek? questions
- Masatsu Engineering Carbon Clutch Disc Blue Print
- Oil Seal on Y21 gear box
- Fill bolt stuck
- Question about a numerically higher final drive?
- 90 integra doesnt stall?
- 99 accord crap tranny
- K series transmission failures. Give me a better way!!!
- All B-series differentials the same
- stock b16 lsd or obx?
- 3.5 swapped auto Legend wont down gear...
- Car will not go into gear help please!!!
- cable guts in hydro case
- k series twin disc help
- 1993 Honda Accord Automatic transmission slipping
- 92 integera Clutch
- Flywheel installed backwards?
- differential weld up to make lsd ???
- Gear ratio for 86 Civic HF California, Federal, High altitude?
- Hard to shift on Transmission
- half shaft problem please help!!
- ISB Part Number
- 99 accord automatic
- Are Cardone Select axles good?
- Axle popping out after gsr to b16 trans swap
- Flywheel question
- Ebay axles worth using temporarily?
- D16 Trans making a odd sound
- B16 y21 gearbox top speed
- Gsr Lsd install in a s1 b16
- 3rd gear grinds a little only at higher rpms???
- Can anyone ID my LSD? pics included
- wacky tranny problem
- adjustable slave cylinder??
- transmission ID
- LSD tranny only spinning 1 wheel?
- b16 lsd on gsr???
- ls 5th gear hydro b16 trans
- S4 Transmission?
- Tell me how my 3rd gear sleeve and 5th gear look!
- Help please Transmission fluid Quest
- Looking for higher ratio F/H22-23 FD
- What vss to use in cable transmission in a hydro car
- what are the symptoms of a TOB going out besides noise?
- B*tch Pin
- Problem: Clutch Masters Twin Disc/Getting into gear
- axle problems
- Boost with LS tranny
- 2010 Pilot rear differential oil change at 9k?
- Reinstalling a clutch, disk orientation question
- s80 tranny ???????
- frustrating front end noise
- Distributor problem!
- clutch juddering with refaced exedy flywheel?
- Stripped tranny bolt - Question about time sert kit
- 2nd gear popping out
- Trouble could use some help.
- Help, What seals & bearing for JDM b16a (1stgen) tranny
- New Clutch not working properly?
- COMPETITION TWIN DISC THROWOUT BEARING ISSUE
- Clutch noise
- New Clutch + Popping Out of Gear
- THE TRUE DEFINITION BETWEEN A 4 PUCK AND A 6 PUCK
- k20 tranny problem...please help
- Leaking Fluid
