PDA
View Full Version : Transmission & Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. DSS garage sale on 5.9 B/Hydro axles
  2. f seriers trans with h series case questoin
  3. Weighted shift knobs bad for transmission...true or false?
  4. GSR Hydro Tranny Parts Breakdown Your Input Is Welcome
  5. the "drive" light started flashing on my Honda odyssey 2004
  6. 600hp+ Tranny problem
  7. 88 Prelude transaxle clicking in 2nd
  8. JDM B16 SiR II A/T inquiry.
  9. clutch breakin/identification question
  10. Tranny problems (vid)
  11. tranny from 2.5TL to 3.2TL
  12. 00' Si B16 Trans w/ATS 4.9 FD & Wavetrac LSD Install Questions
  13. itr vs b16 with kaaz lsd
  14. Transmission Scraping Noise!! PLEASE HELP!!
  15. Poor shift quality
  16. Trans leaking at CV Shaft?
  17. 4-speed civic tranny with 5-speed hydro gears
  18. B16 Tranny. Grinding or something else?
  19. What would cause clutch pressure plate less pressure?
  20. 95 Odyssey : shift lever gets stuck at R
  21. 02 TL Trans
  22. whinning noise on 1st and reverse NEED HELP!!!
  23. Transmission Fluid Level Gauge ?
  24. any transmission shop or anyone else have this part! help!
  25. 1999 Acura Tl 99-2003
  26. FS: Rsx/DC5 Type R LSD
  27. looking for advice on possible transmission rebuild.
  28. HELP! How to remove this?
  29. 1st gear popping out? fresh rebuild tranny - S20
  30. Bad ISB?
  31. 98 Accord transmission
  32. 99 acura tl
  33. Opinions needed! choosing a final drive.
  34. Anyone want to make a $grand? Help!
  35. 2005 civic dx axle question(desperate!)
  36. How to tell if this tranny is LSD?
  37. Identify broken lsd please
  38. 2nd gear gsr and 2nd gear ls whats the diff
  39. Manual transmission fluid
  40. Transmission: shifter wont shift toward left or go in 1st or 2nd. HELP!!
  41. Transmission: shifter wont shift toward left or go in 1st or 2nd. HELP!!
  42. honda lsd vs aftermarket
  43. need help determining what tranny i got.
  44. phantom grip?
  45. need help with axle.. b16a
  46. handcuff installed incorrectly?
  47. Junkyard 5 speed
  48. engine swap now no clutch
  49. cable gearset into hydro case?
  50. Can Anyone Identify This LSD
  51. Hydro Tranny Or Cable?
  52. LSD Question and expereinces?
  53. replaced transmission, no reverse? wtf
  54. gsr trans help
  55. 98 Honda Civic Ex Automatic Convert To 5spd
  56. NEED ADVICE/OPINIONS
  57. is it easy to replace input shaft bearing?
  58. Exedy Stage 2 3 puck.
  59. TURBO D16z6 clutch info needed
  60. Stage 3 clutchmasters, Stage 1 Exedy?
  61. Quarter Mile: GSR vs. Si Transmission.
  62. Weird Clutch Problem
  63. Differential bearing swap?
  64. super stiff clutch ???
  65. Cable trans release arm bending/breaking?
  66. Honda Transmission Fluid
  67. Have to pump clutch to get into 1st..4th isnt there...
  68. OEM clutch disk Stage 1 pressure plate
  69. Clutch and throwout bearing compatibility
  70. Differences between clutch stages
  71. Possible Transmission Problem
  72. l/h axle seal fitment issues
  73. no pressure when i press the clutch
  74. Whinning noise in tranny ?/ No speedo
  75. obd2 ls tranny problem
  76. 98 JDM integra GSR s80 lsd into b16
  77. LSD queries and sourcing
  78. ITR Lsd help
  79. Clutch pedal stays on floor while shifting urgently. Help!
  80. Hard shifting and occasional grinds?
  81. S80(gsr) oem fearing w/ handcuff question.
  82. accord transmission help please!
  83. handcuff gear box vs dog gears
  84. 89 EF AWD crv rear diff?
  85. High RPM trans pop?
  86. !!Rebuiilt H22 Trans from Synchrotech Transmissions!! PICS!!
  87. Junkyard Transmissions
  88. Accord M/T flush
  89. Clutch Recommendation Please!
  90. Quaife LSD
  91. clutch grabs really high (at the top)????
  92. Transmission Noob ?...LS Final Drive
  93. Axle clacking?
  94. 93 Accord Help Please!
  95. NEED HELP
  96. cable to hydo confusion
  97. Help identify 3.80 Final Drive
  98. Anyone Try Synchromesh Additives for Grinds???
  99. 2nd brand new ITR trans grinding?? help!!!
  100. Kaaz LSD Transmission Oil Selection Info
  101. No reverse after rebuild?
  102. axle problems for 05 Accord
  103. transmission code and gearing education (civic 92-2000)
  104. 1996 Acura Integra GSR Clutch & Flywheel Install
  105. 1996 Integra GS-R Manual Transmission Rebuild
  106. Rebuilding 5AT transmission
  107. Is it the diff or something else.
  108. Trouble shifting at high rpm's
  109. Any DSM tranny guys in here? Twin Disc? Center diff? Nasty sounding VID.
  110. Odd countershaft issue
  111. Real LSD or did I get ripped?
  112. GSR TRANSMISSION HELP
  113. Stage 1 clutch? B16 , CRX SIR tranny.
  114. need an exploded view of a mainshaft.....
  115. can't get new axle back into transmission 95 accord
  116. car goes into gear but wont move
  117. Car won't go into reverse
  118. Tranny Help
  119. 85 crx can only find second gear after transmission rebuild. 5th gear synchro?
  120. b16 tranny problem
  121. B Series Differential Bearing Failure - Pics Inside
  122. Pic Request: B18b1 and b18a1 intermediate shaft
  123. D series cable and hydro FD question.Thanks
  124. squeeling while letting out clutch
  125. HELP
  126. Replacing oil fouled clutch, how clean does the housing need to be?
  127. Weird LSD ITR transmission issue???
  128. jdm transmission help!
  129. gear changer
  130. H22A4 Transmission Issue!!??!
  131. 91 ef hatch axle prob.... READ READ READ all the big boys please read
  132. confused on diff bolt PNs
  133. GSR Transmission problem
  134. 99 f150 with 4r70w... Broken torque converter?
  135. s1 tranny and gsr motor?
  136. CB7 Torque Convertor
  137. differential bearings
  138. S80 help
  139. Engine Braking Noise/Rubbing
  140. 2nd Transmission, Issue with Reverse on both
  141. Gsr or Ls transmission
  142. car died
  143. gsr S80 issue.. help!
  144. The end all trans fluid thread.
  145. Case wont fit with the main shaft bearing in place
  146. B16A3 w/GSR trans. Will flywheel help?
  147. Tranny leaking fluid, no visible cracks?
  148. Dual Mass Flywheel disc play?
  149. Trans Hard to shift in every gear!!
  150. Ways to identify if your trans is a b16 or gsr
  151. 3rd gear question.
  152. B series hydro noise
  153. k series trans case issues
  154. Transmission problem Spins with case off But not when case is on.
  155. kswap clutch. F1/XTD/XTR
  156. rattle noise when pushing in clutch
  157. obx lsd
  158. Type R LSD in a 90-91 cable LS trans?
  159. Syncromesh
  160. few questions before i finish up my clutch install
  161. Rebuilding B16A2 tranny, good tips and tools inside
  162. Piece of clutch material missing from 6 puck - is it ok?
  163. gear swaps
  164. D SERIES AUTO TRANNY HELP
  165. s2000 noise
  166. CV Shafts - Which to get..
  167. what a good a decent clutch & flywheel set up for a gsr turbo
  168. S4C differential shims for spider gears?
  169. Help me adjust my clutch pedal!!!!!
  170. 1st gear touching ring gear, bad wear pattern
  171. what trans fluild i should gsr/itr trans
  172. Action 1ms Ruff take offs and chatter??Normal??
  173. flywheel fitment accord 2.0 vtec
  174. H22A M2B4 LSD transmission issue advice?
  175. Intermediate shaft not fitting
  176. Can Someone HELP ME!!!
  177. Questions about b18 cable and b16 cable Transmission
  178. awd tranny help
  179. Helical lsd
  180. RSX transmission shift linkage question
  181. cable2hydro broke!!
  182. gsr clutch?
  183. silcone CV boots hightemp grease where to buy???
  184. Skunk2 short throw or B&M?? And how are they compared to stock?
  185. Civic Type R 5th gears trade
  186. y1 rebuild kit
  187. 92-95 eg auto to stick help
  188. XTD Clutch Scam - Wow.
  189. GSR/LS transmission and gear questions.....? Help
  190. B series inner ring gear diameter measurments?
  191. Diff Bearings Axle Seal Leaking
  192. Need Tranny Help Or Engine
  193. lightweight flywheel
  194. 2002 CRV - rear differential noise?
  195. Trouble taking trans off of b series
  196. '93 Honda Prelude Acceleration Problem
  197. 3RD generation Prelude need help plz!!
  198. Weird sound after 7k rpm
  199. 5th gear grinds sometimes
  200. ACT sport vs heavy duty clutch
  201. Clutch bein weird?
  202. EG hatch with a Y8 swap, stutter when taking off?
  203. D15B SWAP INTO CRX CLUTCH HELP!!! ASAP
  204. s2000 transmission
  205. s4c/s80 constant synchro failure 360whp.
  206. eBay Jdmland11's B-Series axles. Have you used them?
  207. y1 vs ys1 questions + b20vtec
  208. Looin for a strong clutch for 98 Civic EX
  209. b16 vs ls vs d2b
  210. CRX B16, Need new clutch.
  211. EG trans in EK what mounts?
  212. Boost comming in later than usual
  213. Boosted D16z6 DX first gear in EX tranny??
  214. 1998 civic ex tranny swap
  215. k20 6 speed to 5 speed
  216. Transmission Swapping/Converting?
  217. Odd sound while on the throttle - transmission?
  218. busted pressure plate?
  219. K series and B series clutch compatability...
  220. Transmission Experts, please help - LS 5th question (ratio + final drive questions)
  221. Sticky/non-disengaging clutch and grinding while in gear
  222. ys1 speed sensor trouble!!!
  223. 5th gear bearing noise?
  224. Please Help, 96-00 civic auto trans Gurus!
  225. grinding and hard going into gear help
  226. gsr wont go in gear if u drive for a while :(
  227. PLEASE HELP IDENTIFY BRAND OF LSD
  228. HELP: B16 HYDRO TRANNY PROBLEM.. NO REVERSE
  229. S4C with LSD or 99 Civic SI with LSD?
  230. Spoon Ratios
  231. competition super single lasts how long?
  232. LSD swap
  233. Transmission help for my 98 acura 2.3 cl
  234. Where to get rebuild kit for 5 speed 98 civic tranny
  235. Counter shaft snap ring bearing question...
  236. Y1 gearbox can't engage 2nd and 4th in high rev.
  237. Info needed: Transmission removal 04 Civic
  238. Transmission cooler hoses
  239. How does my mainshaft look?
  240. Exedy OEM + light flywheel, or Exedy stage 1 (necessary?)
  241. what tranny is this?
  242. transmission issues w/ a 02 civic
  243. Competition clutch does not engage
  244. in the market for a new clutch
  245. B-Series diff question
  246. royal purple?
  247. transmission from d engine interchangeable?
  248. Not all cheap clutches are bad ... heres proof
  249. Transmission pb with P0730 engine check code
  250. d16z6 tranny making odd noise...
