- 2004 Accord 1st & R problems
- Cable OBX Diff In A Hydro Trans
- 94-95 Integra TCM Wiring
- Need Help Choosing A DriveTrain
- Is this gsr tranny gear usable?
- transmission oil in coolant reservoir
- B series ring gear
- Cv joint - where to buy
- PLEASE HELP IDENTIFY MY TRANSMISSION
- How to convert from Auto to 5-speed on 95 civic?
- '97 Civic Transmission or Solenoid?
- Auto to manual tranny swap
- Driveshaft popping out of sel sol
- 2000 Civic EX 5Spd - Transmission Swap (Bad Casings)
- Trans case swap s80 - s4c questions...
- Input shaft hard to turn after carbon fiber synchro install.
- what do you guys think of eClutchmaster anyone run it?
- J 30 transmission
- stuck in 4th can't move shifter
- Rumble and hard to change gear when hot
- 95 civic hatch, b18c. Axle doesn't seat
- Clutch pressure plate doesn't match flywheel?
- Cracked Transmission (PICS) Help...
- K20 Half-Shaft Question
- Semi Automatic Transmission question
- Honda Accord 2003 transmision problem
- Need help determining transmission
- Transmission stuck in 5th???
- 2002 Honda Civic Not Shifting?!?!? Stuck in D but not really?
- LS Transmission
- Need some accord help!
- What happened to my Accord?
- b16ls Manual Tranny Issues
- Transmission problem
- K series clutch side counter shaft bearing
- PPG dogbox 8month later and still nothing
- Low idle after auto to manual swap
- my M2a4 will not go into 5th or revers.
- BWR Racing Cuff Install
- ACT XT-SS vs Action Clutch 2MS vs Comp Clutch stage 3 Segmented
- del sol A000 to B000 swap
- Needs expert advice on vibration
- 80% torque increase would be??
- Lsd y80 problem
- shift issues h22 swap in accord wagon
- Odyssey tranny swap
- problem whith mt y80
- axle loose in tranny
- B16a2. Y21 gear box replacement.
- p2a5 transmission?
- Exedy Hyper Single VF Clutch kit...Anyone with Experience on This?
- Rebuilt transmission on civic and now can't get into gear.
- h23a3 manual transmission syncro
- 02 Civic Noisy Diff
- RPM sensitive grinding noise
- Linear Solenoid questions
- Turbo GSR Clutch recommendations
- M2a4 slipping clutch
- s80 transmission 2nd gear clunk, confused.
- 1998 CRV: No pressure in the clutch pedal
- B-series differential shim measurement
- B16 s4 trans clutch cover case
- rebuilding b-series intermediate shaft
- s80 trans aftermarket lsd ID
- Stainless Steel Clutch Line Length?? Help!
- spoon clutch type lsd and daily driving....in texas heat
- 00 ex cluster speedometer comes and goes??!!
- 98 crv 5sp. Clutch installment. Help
- wrecked lsd?
- t bracket issue
- 1995 Accord V6 auto transmission bangs
- Transmissions with same external specs as M2s4?
- Transmission 2001 accord Cpe 4 cylinder
- JDM-M6HA Tiptronic A/T Codes
- worn clutch?
- WANTED: Testers for our new prototype parts
- upgrading oem lsd to mfactory/quaife
- Based on technical information from manufacturer, can we tell which ATF is best?
- GSR / ITR mainshaft 5th gear compatibility
- what transmission fluid: 97 d16 5 speed?
- Will a 1999 JDM ITR LSD drop into a LS S80 clutch case without modification?
- i have 1. a z6 automatic & 2. a j30a4 automatic that are both sad. ATF advice?
- Buying Exedy? Plan on replacing your transmission!
- Eg transmission swap
- 88 CRX transmission compatability questions.
- problem with clutch / pedal
- weird clutch pedal
- crv turbo differential
- TRANS GURUS PLEASE GET IN HERE, NEED OPINIONS!
- My Spoon Lsd Broke!(Kaaz)
- lsd thrust washers
- 3rd gear syncro issues
- Wavetrac helical vs M-Factory clutch vs Quaife
- Z6 knocking where transmission meets block
- transmission build in my 2000 civic
- 90 honda accord ex transmission problem
- gear swap for my rsx type s
- Differential Bearing help
- 03 Odyssey trans issue
- Clutch info??
- Tranny help wat tranny should I run
- Exedy Clutch
- Stripped L bracket trans bolts
- Gsr 5th gear in a b16 trans
- 99 DX trans, how am I looking?
- Putting a 99 DX trans back together, quick questions
- Itr trans rebuild issu
- S80 trans torque specs.
- I blew out my clutch. Do I need a new clutch if I swap my car?
- axle boot? is my axle junk?
- Transmission fluid coming from torque mount bolt hole?
- D-Series Differential Bearing Identification
- Freshly PRO rebuilt trans ISB type knocking when clutch released
- transmission all gears work okay but reverse
- trouble with reverse
- goes into gear like butter, very had to come out of gear?
- CRV auto to manual swap
- Best CV boot to buy?
- b18c LSD trans. What clutch? Del Sol SI.
- B series trans casings, differences?
- 2001 civic hx d17a6. 5 speed Slw
- 1998 Civic Automatic won't go into Drive after sitting
- Auto to manual
- Manual CRV tran shift cables compatible with h trans?
- Paper transmission Gaskets and Permatex Grey?
- b18 trans shifting issue...
- b18 & h22 clutch, differences
- b16b
- Countershaft teeth
- tras trouble
- how far do I go
- please help serious issue with h22a in 97 accord (JDM swap with LSD tranny)
- Help transmission problems!
- Click when I release my clutch. B16 SIR
- Exedy pull type twin disk help
- car started to smoke
- transmission problems
- Replaced isb wont go into gear...
- D16z6 Trans won't shift when case halves are mated
- b16a2 s4c tranny
- J1 B16 assembly issue after rebuild, help!
- throttle cable problem
- starter wont engage????
- p1456 and p0420 - NOT gas cap - already replaced cat - HELP!
- Anyone heard of Valeo clutch?
- new to k series, how to determine lsd or not!
- 310xxx should I flush the transmission?
- OEM type r or ctr lsd
- tranny/clutch problems b18c5
- Need your expertise! re: d16z6 mated with d16a6 tranny
- 2007 odyssey rolls in N
- Snap ring? on b4ra transmission main shaft
- Anyone using RedLine D6 in their A/T?
- All the sudden wont go in 3rd gear
- b16 vs gsr vs ls vs type r transmission
- 03 Honda Accord Transmission Question
- Y21 non lsd gearbox with S9B LSD?
- Transmission Identification
- ITR S80 Shifting problem.
- C.C. stage 3 segmented clutch
- Intermediate shaft play, replace bearing?
- Any suggestions for a replacement for 21396-P80-000
- PL3 1000 civic si transmission??
- B&M shifter not sitting right?
- Transmission wiring?
- Reassemble transmission to block? (B18c)
- 93 honda civic dx coupe grinds trying to go in park
- 01 civic jerking while accelerating
- Sticking in gear.....maybe simple???
- 1996 Clutch Pedal Spring
- Manual 2004 honda civic car slips out of gear around 4 or 5 rpms
- Problems with car walking in 1st gear
- Help figuring out correct axle.
- HELP car skips and dosnt spin
- 94 accord D4 light
- my 91 b18 automatic integra
- Abs driveshaft
- K20z3 lsd into k20a2 transmission
- si trans hybrid for dd and other events.
- GSR tranny rebuild. Parts and cost?
- Comp Clutch pressure plate and disc differences
- Axle to short? I'm stumped!
- j30a4 transmission options, 6mt or auto rebuild. ??? and level 10 respectively
- Hub/ bearing question
- Honda EG6 (axels?!) problem
- Does final ratio 4.928 able to fit in to S80 96+ spec with s9b LSD?
- straight edge
- Tranny fluid
- 89 Integra LS Automatic
- D series hydro conversion questions
- New Type R Transmissions
- any links or tech sites to j series transmissions?
- Synchro Sleeve and Hub Interchangeability between B series Transmissions
- 96 Accord Transmission Hole in housing.
- 3rd gear missing now what?
- b series transmission suggestions
- Whining culprit??
- Grinding my gears
- J30a4 5at factory rebuild guide desired
- M2F4 help.
- 98 Honda Accord Transmission issue?
- B16 cable with ls5th gear. hard to find 5th
- 97 Accord f22 Auto Tranny HELP!!!
- Experiences before/after clutch hydraulic line replacement?
- something wrong with my clutch?
- gsr tranny seals ??? help please
- Does final ratio 4.785 able to fit in to S4C LSD gearbox?
- CRX engine swap
- 1999 civic si trans code
- Welded bellhousing
- Clutch for 400 hp+
- Big d tranny problems
- s4c gears on s1 shafts
- kaaz lsd clutch plates wear?
- 2006 honda civic clutch?
- Car rolls downhill in 1st?
- Best way to strengthen a tranny case
- Can you take the LSD out of an h22 tranny and put it in an f22 tranny?
- Act 6 puck sprung to exdedy organic clutch HELP!!
- transmission slipping!
- Tranny to use, GSR or ITR
- 1995 honda civic cx NEED HELP?
- Pop locking transmission 90 honda accord ex
- B series transmission component suppliers?
- Broken Final Drive and cracked case
- Main shaft question
- s80 transmission cracked, jb weld or no?
- GSR vs. S40 vs. Y21 S4C
- Dfference between Mfactory and JDM type R LSD
- transmission id
- Play in gear shift rod
- Axle slipping out of transmission
- Better Syncros?! (GSR Tranny question)
- need help with first rebuild
- change ls tranny 3rd and 4th gear with gsr gears
- d16y8/ZC trans and axles
- Auto to Manual swap help.
- What LSD is this ???
- Cable B-Series transmission bearing
- replaced CV's, car does not move!?
- Aftermarket differential identification
- exedy/daikin twin disc include TO bearing and alignment tool?!
- 1st gear
- B16 Cable J1 grinding problems
- B16 SIR and B18c JDM R box. parts interchangable?
- Havein troubles diagnosing problem
- Owner of New 2013 Civic si 4dr Need advice
- Clutch loose??
- k24a2 axles
- Integra 98 auto tranny into a 00 question
