- y8 trans, rail detents causing no/hard shift
- Clutch not fully disengaging..
- b20/vtec swapped del sol no reverse
- Transmission Differences?
- ys1 internals in Y21 case?
- Gear Oil?
- tranny squeels?
- Clutch Master Flywheel with Fidanza Replacement Surface
- B18 no reverse. Help
- No reverse? help
- Y21 B16a w/ clutch pack LSD...it clicked and clunked but it is ok? *PICS INSIDE
- LSD question....thx
- mainshaft thrust alittle loose
- tranny sound, thinking of a swap
- b18c clutch & flywheel upgrade
- Awd eg!
- Indicator light blinks
- clutch question on 2000 accord coupe
- Whos knows their stuff? What kind of tranny is this?
- Question about ls transmission
- Odd Noise..
- Need auto tranny diagnosis 97 accord se, performed many tests
- flywheel bolt size
- Best H22 Trans?
- internal swap question
- Rebuilding an L3 tranny using S20 write up?
- Jumps when accelerating
- Wheel hard to turn with car in gear
- Sourcing hybrid transmissions?
- Pressure plate Bolt length
- DC2 shaft differences?
- Helical gears/ dog gears
- Possible to flip the 5/R Synchro Sleeve
- GSR Trans with 4.7fd & Quaife LSD or BNIB USDM ITR with OEM LAD
- GSR Transmission -Won't go into gear
- s4c vs s80 vs y21
- b series bearings
- D series Trans Question
- What is needed to install a LS 5th gear?
- GSR trans with 2000 SI shift linkage??
- S4C B16 tranny stuck in gear
- How transmissions work....
- Axle pop out
- Clutch change, power cuts out when turning key
- Thinking about going B-series with a H trans...
- B Series Transmission Strengths
- m2b4 trans with aftermarket final drive
- lsd clunking noise???
- Help with my acura tl clutch? w/ vid
- help removing GSR/LSD transmission
- 97 b18c5 popping out of reverse
- B16 gears in LS case...Question
- Tranny Fluid
- Need clutch recommendation
- JDM D15B auto tranny on D16Y
- Yet another 'need HELP!' diagnosis thread.
- lightend flywheel oe clutch, or stage clutch and oe flywheel ????
- Need Help Figuring Out Correct Throwout Bearing
- 91 CRX Si gearbox in 88 hatch??
- Need help!!!
- Tranny problem(release bearing fork)
- Identifying Syncro's & Syncro Sleeve/hub (bseries)
- a good flywheel/clutch combination
- Car won't go into gear
- b series trans not able to move in gear
- CC Twin Disc questions
- Clutch
- need some help troubleshooting the noise
- Clutch for a daily driver/street LS ????
- B16 transmission weird ratios. Trans guru step on in!
- welded differential
- how to id. gsr or ls differential
- Need help with a tranny swap
- Transmission sqeal?
- Differential Question
- EP3 Clutch pedal stays stuck
- h22 eg not shifting right?
- SiR1 cable trans lsd into a SiR2 hydro trans
- 03 ACURA MDX trans problem code p0721 and p0741
- 3rd gear hard to get into on downshift
- Lay shaft and driveshaft seals, HELP
- To Shot Peen OE Gearset?
- b16 cable S1 quaife lsd install queation?
- obd code P0717 and shifting isues
- Gold washer under reverse gear
- Transmission with bent mainshaft?
- Need help with JDM B18B in 95 civic SI USDM
- Are '91' Prelude and 91' Civic CV Joints the same?
- Spool Differentials Reviews?
- Synchrotech Service Bulletin (SSB 001) K20 synchro fitment
- 1999 honda accord automatic transmission grinding noise
- MFactory LSD Install Question
- GEARSPEED - Announcement
- Gear oil in left front rim...
- b16a passenger wheel grinding noise
- Help me!
- b16 hydro trans new clutch flywheel burning
- Mugen LSD - Friction Modifier?
- New to K-series - are all manual gearboxes created equal?
- 1994 accord trans started to leak took pics
- B16 trans, need help finding correct CV seal
- noise with tranny or clutch or something (with video)
- New Honda MTF bottle?
- Noise when spinning Int. Shaft
- have shop rebuild or buy rebuilt??
- H22A EG Shifting Problem
- Transmission help requested
- D-series VX 5th gear into 92-95 Si transmission ?
- Firrst transmission build. anyone have pointers or maybe a manual
- Humming when off throttle
- 2nd and 4th grind
- B18C tranny problem... never seen this before...
- 3rd gear grind
- SH Tranny Swap
- differential question
- Clutch won't go to floor and can't shift into gear
- Hydraulic clutch issue.
- Can you tell me if this blocker ring has been used?
- Transmission clicking while clutch pedal not being pressed.. with video
- SYNCHROTECH ANNOUNCEMENT:
- Question about shifting
- 3rd gear grinds
- D-Series first gear useless?
- PPC SPEC or KUPP Racing Flywheels?????
- Bell housing bolts?
- trans fall out
- 2nd gear wont go in HELP ME!!!
- Clutch for JDM B16a with B16 LSD tranny??
- 2nd gear hard to put in when launching
- Transmission work in Nashville Area
- Veectory cluch D15B Engine
- Transmission problem/ grinding noise
- What fluid do you run in your manual trans?
- b20 with gsr tranny
- 97 civic hatch w/ B18C...bad passanger axle...what axle do I need?
- What goes in this bolt hole - B16a tranny
- trans only shifts into 3rd and 4th
- CC Twin disc problem or trans issue?
- lsd tranny
- Hard to get into gears when first start
- 2000 honda civic lx
- tranny swap
- Auto to manual.
- Trying to figure out this odd gear set up. Look inside....
- Which Tranny Is Best for B16A, GSR OR LS
- Clutch for 300whp B18C1
- b16 transmission hard gears. HELP!
- 1998 honda accord ex, car jerks when going from park to reverse, automatic
- what should i do to a transmission before installing
- Rebuilding LS transmission
- m2a4 tranny lsd problem tore apart and found this ???
- uneven pressure plate and clutch wear take a look
- jdm b16 lsd into us b16 hydro
- Whistling/whining before upshift - mystery, need help
- Ys1 final drive swap ?????
- popping and jerking in front left LSD ?
- Looking for some general info on Honda autos and rebuilding/replacing.
- Need a Quick Answer! Help with Flywheel concern!
- Helical vs straight cut?
- axle popped out? 91 civic dx
- b18a1 Trans options
- Gsr Trans Wont Disengage
- cvt auto Transmission????
- honda d series transmission rebuild video with question
- Good trans shop near Tulsa, OK?
- D16 ebay lsd gone bad
- input shaft bad? if so how do i replace?
- Kazz Ring Gear Bolts Won't Clear *Help*
- Anybody pay Honda out-of-pocket for their trans rebuild?
- Cracked GSR Tranny case. need urgent advice
- i need a new clutch for a d16? what can i get for a good price//stage 2
- Turbo 500HP Clutch
- Reputable trans shop in DFW TX area?
- B16 auto trans swap into auto 94 Integra- HELP NEEDED!!!
- gsr trans case broke need info
- Short throw shifter problem
- Tranny or clutch seems screwed up
- HELP! Clutch/Tranny may be broken..
- H22 LSD
- 2005 CRV shift solenoid problems
- what affects clutch pedal travel?
- Does this mean it has LSD?
- mtf
- ARP flywheel bolts
- **B16 Transmission Issues**
- How Smart are You? - VSS Problem
- B16 Gearbox sticking in gear! Help =(
- Rebuild S40 or buy used?
- strange gearbox problem
- F/D and speedo..
- Chipped Speedo Gear Teeth
- 92 Integra B16 cable to hydro
- Need help with possible transmisson problem
- b series opinions
- Need advice, trans problems for a 96 GSR
- Help me identify this lsd
- Shimming a gsr trans?
- axels
- Flywheel question
- Transmission Problem?
- This slave cylinder has been out for a while
- Should i resurface the flywheel or just throw it in?
- best paired tranny with d16z6?
- ATS/Carbonetics LSD/Diff Bolt Issue. Urgent :(
- D series XACT Streelite Flywheel/Xtreme Clutch Kit, Any Reviews?
- HELP me be a good seller....Wavetrac. Pics.
- S80 USDM Trans Lockoutout! Help me ASAP!!
- D16 pressure plate bolt torque
- swapping k-series trans internals, 04-09?
- M2Y4 Countershaft Top Needle Bearing - Orientation
- Gear bow prob
- tranny problem car wont crank
- LSD Non LSD
- 99 CRV AWD trans problem after towing
- Shift Linkage all screwed up?
- Swapping gear set and diff into different trans case
- Help to identify LSD, Quaife or .... ?
- B series trans question
- 97 Civic Ex coupe, Automatic d16y8. Tranny help..
- FW-694-AL flywheel Replacing Friction plate
- Which clutch?
- Looking forward to my transmission rebuild
- Gears
- F22b1 problem
- Gsr trans leak
- Driveshaft not staying fixed
- scraping sound from transmission
- Transmission confusion
- Carbon fiber syncros Vs. Oem syncros...
- wierd issue with fresh trans rebuild
- Shift rod problem
- Strange clutch fail. HELP, ADVICE please
- Who would you recommend to put together a tough transmission?
- LSD L4E stamped tranny? Searched EVERYWHERE
- Stock b16 tranny hold up?
- b17 shift shaft seal?
- 93 civic si won go into gear
- Need advice for a turbo automatic d series
- ***GSR Tranny Won't Take Reverse Unless Off****
- clutch engagement issue
- Modified Clutch Question
- Type-R Dual Synchros?
- civic si 03 k20a2 trany
- Prelude AXLES problem
- 2003 crv clutch not engaging?
- a1 trans
- 98 Honda Accord issues
- ATF help
- performance b-series trannys?
- Carbon Synchro question
