- honda CRV gear box issues
- Best/Worst Replacement Half Shafts?
- Code P0715 pleaseShaft (mainshaft) I put speed sensor failure
- changing automatic clutch
- CVT trans sound like noisy power steering pump in reverse
- OEM ITR LSD Into YS1 GS-R? Ring Gear Bolt Pattern?
- Harmonic wub wub noise only at 2500rpm
- K20 - 5th Gear slips out when accelerating
- Transmission mount hole through case
- Tps not full voltage range
- B- series half shaft
- 4.9 final drive ls 5th gear
- A host of strange sounds.
- Integra LS locked out of 4th gear
- Melted K series synchro hub?
- automatic transmission
- TSX 6MT Pick-up/Speed sensor interference within transmission
- Loud clicking / banging noise after transmission rebuild. I need some sugestions.
- Gsr trans will go into gear while running, but won't move
- Please help with a simple question. H22a4
- Transmission re-mount after clutch install
- anyone can tell me what this whistle noise is?
- Gsr trans problem help!
- Auto to manual transmission swap .
- Can anyone confirm this works on my Accord?
- clutch pedal/bleeding woes
- P1758 & sometimes flashing D4 after 35-min drive
- changing final drive and rear axle ratios on RT4wd civic
- transmission clatter
- CVT mods? anyone? Bueller?
- Gsr 1st gear sticking?
- 96 Honda Accord trans problem
- 01 civic 1.7l dx transmission help
- Viscous 14 bolt LSD B series Hydro Ball Bearing Conversion
- K20 & K24 transmission suggestion
- GSR detent bolts went bad?
- 05 Civic Hybrid CVT Transmission
- 04 manual civic stuck in second
- What trans will bolt to my 1999 accord f23a
- Help, transmission issues
- H series fd
- Whiny 2000 SI S4C
- Clutch Replaced, Lower Pressure - Normal?
- Clutch problems, please help!
- Which axles for 400whp B series street car...
- auto b series in the 12's? (good reason for running auto!)
- S20 bench shifting and sleeve question
- Need help diagnosing noise and vibration
- transmission swap
- Clutch or tranny issue
- B18 cable trans with hydro LS gear set, ITR LSD, 4.9FD. - what gears are compatible?
- 02 EP3 K20 Clutch System Issues
- Car can not go into 2nd gear
- Final drive upgrade and power
- 99 civic ex problems
- Check my itr 4.7 syncro
- Unknown B series transmission
- Can someone please explain this?
- B18c1 swap into delsol
- need help
- 2007 civic SI - Hard to get into gears
- Speed gear chipped
- Throwing P1768 codes &more
- Need help deciding what transmission
- H22a swap in 93' coupe dx??????
- 87 HF Trans Swap Into 88 Sedan Questions
- Clutchless shifting
- Honda
- Noise while turning left (axle?)
- Subframe Markings
- Cannot Select 5th Gear After Rebuild
- Can I install an AWD transmission into my FWD Element?
- Anyone installed a LSD into a 2009 TSX transmission ???
- Ridgeline/MDX/RDX/Pilot Rear Diffs (RWD 5th gen Prelude)
- 4th gear AT problem
- Shift linkage problems
- 91 civic manual
- Sticky Clutch Pedal
- Transmission Range Switch compatibility
- Transmission compatability
- manual to auto 2001 Acrura EL
- flywheel bolt circle diameter B and R series
- Can't put car into gear
- LOOKING FOR INFO OR TECTORIAL can I do ls 5th gear swap with a b16a tranny
- H22 final drive
- Gsr transmission problem. Car wont move! Please help!
- Difference between "B" and "R" flywheels besides weight?
- 00 crv auto to manual conversion?
- Shifting into 1st gear with lightweight flywheel
- 1999 Honda Civic Ex shift problems
- 2nd and 5th gear pop out
- A few transmission questions
- No Power Steering / Axle Wear.
- Engine swapped now gears shift terribly
- Rwd crv trans conversion
- Hard to shift from neutral to third
- Used JDM tranny pre install check list.
- Need quick advice on xmission issue
- Need help identifying diff
- Can grinds be cause by play in the shifter?
- K24 6 speed transmission rebuild problem
- Changed Hydrualic Clutch but feels like its forced when running
- B-series NEW FULLY Sequential Gearbox
- Mfactory lsd gsr clicking?
- B series lsd in K series gearbox
- LSD LS Transmission Question?
- transmission problem
- BMXA Main Valve Body Separator Plate
- Clutch Fork Release Bolt broken
- Flywheel bolts not wanting to bolt up..
- Is automatic EF hatch worth it??
- Will a b16 trans go on a a b18 without an adapter?
- Gear Set reversal?
- DC2R clutch feels weird
- Comp Clutch Direction?
- Axle won't fit in wheel hub
- Axle help needed.
- Understanding and modding D-series transmission ratios.
- air will not leave clutch line
- Bad CV Shaft causing hard knock?
- Speedfactory Shifter Return Spring
- MFactory Dual Synchro B Series Gear Reviews?
- is the RS5F32A FM41 gearbox tough?
- Tranny problem???
- Need info on a trans
- quaife LSD for edm ee8 crx
- Gsr hydro trans wont go into gear sometimes but shift fine while driving
- Noisy Carrier Bearing
- CC stage 4 after 4 years
- Transmission gets stuck in 5th and bearing/gear noise
- Tranny swap???
- Tips to driving a manual?
- Need Help ! Possible Bad Throw Out Bearing?
- Wagovan RT4WD viscos coupler powe capabilety?
- Power steering problem? - Jerky and thumpy
- HELP! Supercharger whine in 4th gear only!
- Please Help!!
- INPUT SHAFT NOISE?
- Linkage seal leak, S4C trans
- EP3 axle upgrade
- 1994 Honda del Sol Frozen Bolt
- Dc2 dual bend shifter in a 95 lx accord f22?
- MFactory 1.5way clutch/plate LSD
- How my fixed my severe 3rd gear grind
- Transmission 02 Honda Civic hx 5spd
- 2000 honda prelude speed sensor issues
- Loose Clutch pedal!!! please help!!
- 1998 Honda Civic Lx EJ6 Auto Tranny Problems
- Gear shift problem
- Difficulty Putting Civic Into Gear
- Upgrading tranny, 4.7 or 4.4 LSD
- Clutch pedal leaking & gust of air on disengage
- 03 Accord transmission into a 2002 Civic?
- PIC REQUEST: oem honda vs Quaife or obx lsd
- Manual transmission hard to put in reverse
- 2003 Acura TL Type-S Odd transmission Issues (help needed)
- Lookig for a used B7TA 1st-2nd clutch pack.
- Freshly rebuilt transmission not staying in reverse - S40B000
- Transmission intermittently slipping/jerking issue 96 accord wagon. Help/suggestions?
- Gear grinds and car jerks when I let off the gas
- Help! 5th gear cuff issues
- 95 eg vs del sol pedal assembly
- Transmission Swap 94 accord
- 94 accord clutch line flexibility
- mugen vs oem type-r lsd
- DTC reset, HDS tool, and PCM Idle Learn Procedure?
- Best place to get axles, upper + lower ball joints, and tie rods from?
- JDM/EDM 5th gen civic transmissions
- tran
- Gearbox Mount Stud
- Clutch Won't Engage
- Ls countershaft in gsr tranny??!!
- transmission fill hole
- Synchrotech MTF
- gear accord stuck
- Real CC Twin Clutch?
- difficulty level for 5speed rebuild
- do i need a new clutch?
- clutch lifespan once it starts slipping.
- Need new clutch kit and flywheel
- DC2R acceleration knock - diff
- Opt. For 2001 Honda Accord
- 1995 Honda accord d4 light not working at all. And has no power in d4
- B16 S4C Questions
- b16 tranny with all LS internals?
- d16y8 bad ISB, need advice
- possible clutch damage after stolen vehicle recovered.
- Comp twin disc adjustment
- 1998 Civic clunking when shifting
- 2009 civic dx tranny swap
- 1999 intwgra LS- asking noise when turning left and dropping into small indents on ro
- 2003 honda civic si
- Help identify GSR tranny issue
- GSR tranny Grinding 2nd gear
- hydraulic help (central illinois)
- Whats the best transmission for h22 swapped EG?
- What is this plug on the front of 1996 Automatic Integra b18b Transmission
- HONDA ACCORD 1999 ULEV VTEC TRANSMISSION 2.4 4CYL SWAP TO HONDA ACCORD 01 VTEC 4CYL
- B series tranny mph vs rpm
- '96 Accord Won't Rev Over 2,000 RPM
- Inner CV joint breaking EK b18c
- B series transmission help
- EF9 gearbox issues
- Passenger axle wobbly in tranny
- help ls transmission problem
- Want to double check (cable transmission)
- Automatic Integra Transmission with vtec
- hf trans better than 4speed?
- Pressure ate...
- Throw out bearing maybe? Help!!
- Just purchased CF synchros, anything I should know before install?
- Help!! 2000 civic d16 swap!
- Need opinions on GSR Transmission issue.
- B series cable tranny
- need help! 2000 civic auto
- Southbend/DXD Racing HD Stage 1 Clutch Review
- not shifting into 3rd from 5th and 4th (s9b)
- 2000 Acura TL Code po740! HELP!
- Trans grinding when not pressing gas
- S80 LS Won't change gears unless stopped
- 2006 Honda civic won't go in reverse
- quaife B-series 5 speed sequential finaly..
- need help with tranns fluid
- Honda '01 Civic Turn on but not moving
- HELP I feel like I am screwed!!!
- honda civic doesn't revers helppp
- Did I Get Fleeced?
- What transmission do I look for
- Transmission damage am I getting Screwed
- Car won't go in gear!!
- Explanation on my tranny
- Pops out of 1st after 15min of driving
- y21 counter shaft 1st and 2nd gear question
- Awkward shift
- I need HELP ???
- newbie question.
- 90 Integra b18b1, shifting problem
- S80 Tranny issue Please Help!
- Need HELP, Trans question
- 92 Prelude shifting problem
- how do i measure to shim a diff
- Transmission Stamp Font + Blue/Yellow Paint Spot
- best LSD for drag racing
- Replacing ISB Problem, can't remove main shaft
- throw out bearing for twin disk
- Re-stamping "V4D LSD" on JDM LSD GSR Transmission
