temporary axle boot fix
if your boot has a small hole you can fix it with superglue and liquid tape
or just liquid tape
clean the rubber boot with a rag and carb cleaner and inside the opening too just don't spray carb cleaner inside the hole or it will dissolve the grease
if you only use liquid tape it will last about 2-3 days with freeway driving
if you use superglue and liquid tape I don't know but mine is still on and not leaking a week later.
again this is temporary so it doesn't sht grease allover your engine bay or wheel
or just liquid tape
civicdelsol33
12
Dec 2, 2008 09:22 PM
