92 accord won't go in to gear even when off
Hello so at first it was driving would just have some moments where i would have to pump the clutch to get it into gear but now that doesnt work even when the car is shut off it wont go into gear it just drops as if it is in nuetral. I hope someone could point me in the right direction to solving this issue thanx
MM Gruppe B
Re: 92 accord won't go in to gear even when off
Look for a leak under the dash, you may have to pull back the rubber boot on the CMC.
Check the fluid level in the CMC reservoir.
Check for a leak at the SC mounted on the transmission.
Have someone watch the slave on the trans for operation when you pump the pedal.
I suspect the CMC has gone bad. Could always try to rebleed the system and see if it brings it back.
edogmb
10-08-2011 06:08 AM
ajengen
08-03-2011 01:26 PM
