PDA
View Full Version : Transmission & Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31
  1. help pls!! y8 trouble
  2. worth it to fix?
  3. wtt
  4. We Need this to be sticky'd
  5. Are final drives interchangeable between the VX and HF transmission?
  6. Trying to identify this transmission - A000 with 40mm bearings...
  7. transmisson options need help
  8. Integra Tranny grounding wire help
  9. Y80: speed increases, car sits.
  10. oem b16 clutch type lsd
  11. F1 Racing clutch kit
  12. engine spins freely
  13. Tranny damage, ran over something now leaks.
  14. how do i know what tranny this is
  15. need to replace ISB..little help & advice needed
  16. How LSD works with no load?
  17. ACT clutches
  18. Tranny slide/grind.... :(
  19. gearbox issue
  20. SPEC Stage 3+ Clutch
  21. What parts to replace when difficult to put in reverse? (links inside)
  22. ls vs b16 tranny bearings
  23. tranny stutter problem
  24. **URGENT** i need answers about a LS tranny
  25. Clutch issues?
  26. b16 tranny vs ls tranny
  27. replace the clutch?
  28. need help taking half-shaft off
  29. stress cracks in tranny. too much oil
  30. cracked tranny casing
  31. new clutch. car wont go in gear while running
  32. Jolting Transmission
  33. cable vss clip?
  34. B16 AND B18C DIFFERENTIAL BEARING
  35. Tranny Swap Problems!!
  36. Need help
  37. cb7 tranny sensor ???
  38. How bad is bad?
  39. Trans swap in EM1
  40. diff?????
  41. Phantom Grip -LSD-
  42. where can i get zc third gear
  43. Difficult to put in reverse
  44. Transmission Whine noise 96 integra
  45. need help with my transmission
  46. ebay axles
  47. Synchros for a JDM ITR tranny?
  48. Can a final drive affect dyno #`s
  49. car wont shift into gears than dies
  50. Is Honda AT fluid really Dexron
  51. b16 trans with gsr parts
  52. Civic Si
  53. 98 GSR transmission whines
  54. did i mess up my trannie?
  55. Input shaft bearing race stuck:(
  56. M2K4 on H22A2 ???
  57. shifting your automatic
  58. ls tranny on b16
  59. D15b tranny on a d16y8 in a 00 Ex
  60. Looking for a reputable transmission company in southern california
  61. Auto to manual swap questions.
  62. Car will not drive after engine swap
  63. Tapered differential bearing preload adjustment
  64. Best Release Bearing?
  65. b16 tranny problems just grinds
  66. how to make a tranny survive at high rpms?
  67. MFactory ti-moly coated gears and final drives
  68. 93 eh2 b18c1, Lsd or not??
  69. State Ref problem with transmission
  70. put on transmission, only goes into 1st
  71. Best stock axles for D-series?
  72. Automatic Tranny Problems HELP!!!
  73. trans not working
  74. hard to get into first and reverse!!!!
  75. 2 broken axles in 2 weeks....
  76. gsr tran wont go into reverse
  77. Possible clutch slippage on EK, help!
  78. VSS drive gear, possible problems?
  79. Cable B16
  80. What Kind Of Oil????
  81. stage 1 clutch question
  82. s80 w/ lsd aluminum chunks inside
  83. general tranny question...
  84. t2w4 vss
  85. Will my trans hold up?????
  86. Automatic transmission again.
  87. Where can I get a single CV joint?
  88. Tranny setup
  89. zc engine and tranny swap please help.
  90. Need some LSD and Clutch help
  91. Transmission pops out of gear
  92. Which Spec Clutch?
  93. tranny bolt part number
  94. light wieght flywheel
  95. Need help: phantom grip differential upgrade or obx lsd
  96. Can't get the castle-nut back on.
  97. VSS!!! WTF!!!!!!
  98. Known issue with HASPORT Shift Linkage
  99. need help on comp twin disk adjustment
  100. Need help removing the axle
  101. twin disk slipping but its still good? whats causing it??
  102. Transmission Control Unit
  103. Will this lsd fit in this tranny
  104. Swapping QUAIFE from 97 to 01 GSR transmission
  105. Ferio LSD???
  106. What Kind of Clutch would you recomend?
  107. Clutch decisions...
  108. I NEED CLUTCH HELP PLEASE
  109. Y21 noob install questions...
  110. Y21 or S80 for an ALL MOTOR GSR
  111. My 2nd gear is acting up?
  112. Transmission Guru's get in here.... broken bearing, WHY???
  113. hybrid b16/ls cable trans. will it work?
  114. Trans. aoil change...
  115. OBX LSD trubble with axle pop out.
  116. b16 passenger axle install
  117. clutch fork stuck. help.
  118. **NEED help on decision of LSD**
  119. axle problem
  120. H22 trans questions
  121. Broken LSD! rebuilable?!
  122. Help identifying this differential
  123. Problem with Y1 LSD Cable Tranny
  124. alrite?YS1 tranny?
  125. f1 clutch, 00 civic si
  126. Transmission Rebuild
  127. Transmission Failure - What's the Culprit?
  128. transmission instaled with engine in bay (tips?)
  129. Good Ratios
  130. how to break in a clutch properly
  131. tranny wont go into reverse
  132. For those of you running the 4.92 F/D in USDM/ITR tranny.
  133. Wheels spin while in neutral
  134. Wheels spin while ne neutral
  135. Stuck Oil Pan drain plug!
  136. Pilot Bearing
  137. can you use motor oil on your transmission
  138. Flywheel question
  139. **** Hybrid tranny rebuild ****
  140. TRansmission fluid change 2003 3.2 TL???
  141. GSR Differential Play
  142. honda s2000 ap2 tranny on ap1
  143. someone please help me with my tranny issue!
  144. New transmission break in period?
  145. Stage 2 Clutch Help
  146. Clutch slipping?
  147. Transmission Problem
  148. K Series Clutch Case Swap
  149. Shift Linkage Issue ( Limped Shift Rod )
  150. s80 with lsd what throw out bearing?
  151. j1 trans wont stay in reverse
  152. Axle Pops Out
  153. CLUCH MASTERS
  154. b16a and LS vss compatability?
  155. Problem putting back transmission on
  156. itr s80 vss gear part number?
  157. shift solenoids causing issues on 99 Prelude automatic?
  158. 1999 ITR tranny problem
  159. Gear ratio & WHP.
  160. 94 gsr ys1 trans what is it really
  161. Automatic trans?
  162. B series tranny dowel pins?
  163. where to get 3rd gear type R?
  164. synchro replacement
  165. ACT Clutch
  166. I need TOYOTA help...I know this is HT but you guys are smart!
  167. Tranny fluid?
  168. Tranny Problems!!!!
  169. LS trans with 4.7FD and typeR LSD
  170. intermediate shaft problems
  171. New fidanza flywheel and pilot bearing question
  172. hybrid tranny reliablity..
  173. what clutch to buy for gsr swap?
  174. Clacking noise coming from 2nd gear ONLY
  175. Helical LSD- fluid
  176. Help needed... Car dosent move
  177. B-series Mainshaft blues..F**K!!
  178. obx lsd. . .to spin or not to spin
  179. Short Shifter.. dual vs. single bend. skunk2/BuddyClub
  180. Interchangeabilty
  181. Transmission Problem (Stock EM1)
  182. multiple transmission assembly problems
  183. F23A1 Flywheel question (replacing with Fidanza 8.5lb)
  184. jdm hydro b16 tranny w/lsd
  185. Opinion needed... B16A what tranny???
  186. [Info] 91005-PS1-003 = 91005-PPS-003
  187. HELP Base RSX won't shift into GEAR!!! HELP
  188. frankinstin h23 tranny w/ b16 tranny???
  189. clutch issue
  190. tranny leak help!!!!!!!
  191. check for lsd tranny?
  192. B series cable trans v. Hydro Trans
  193. What axles...for a B swap 89 civic..
  194. Hydro To Cable? And tranny swap
  195. bseries obx parts?
  196. Poly Transmission Mount Broken?
  197. clutch got oil soaked and is now slipping....can it be reused?
  198. Two questions regarding tranny fluid change for my 4 cyl, 2006 Accord SE
  199. Lockup solenoid
  200. Synchro Wear - Abnormally High?
  201. INFO: NEEDED... Y80 tranny
  202. New Clutch - Clutch Slipping in 5th
  203. Wierd Noise in Tranny
  204. Clutch replacement
  205. master/slave procedure
  206. NEW GSR TRANS OR NOT.
  207. Throw out bearing going?
  208. Redline MTL???
  209. Hard to get in and out of reverse???
  210. what TCM to buy?
  211. ITR Mainshaft? need a new one questions and How to tell usdm from jdm?
  212. Problem getting out of gear.. Clutch?
  213. Another Shuddering on Acceleration Thread...
  214. gear oil for stage 2 clutch
  215. Can I swap my tranny internals?
  216. Acceleration: Full automatic (CVT/V-Matic) scooters vs semi-auto/manual
  217. help with final drive
  218. 2000 Accord LX Automatic Transmission Trouble
  219. 2002 Honda Civic EX (automatic) Transmission Problem at 77,XXX miles?
  220. Phantom LSD ???
  221. Cant get housing halves back together
  222. good clutch/flywheel set-up for my motor?
  223. b series trans internal question. LOOK ASAP
  224. Hard to get into gears when on.
  225. B16 Cable Gears INto Hydro GSR trans
  226. Running Transmission Upside Down
  227. transmission problem, help!
  228. battery light not coming on
  229. Does the inside of a 97 H22 atts tranny fit in a 97 F23 tranny casing?
  230. Clutch Disengage Spinning Grinding Whining Noise
  231. Clutch Problems
  232. ex tranny vs lx
  233. D-15/16 AND B-SERIES SIMILARITIES?
  234. transmission problem PLEASE HELP!
  235. re-assembly stuck in gear? WTH
  236. auto to 5sp should i or why not?
  237. sound in my tranny
  238. B series trans removal from ek chassis...stuck
  239. going from hydro trans to cable trans?
  240. L3 cusco lsd
  241. Kaaz Diff... need some help with it
  242. whats the difference between s80/y80?
  243. 1991 accord automatic transmission wont shift and acts weird
  244. what halfshafts work for this.
  245. question about testing functionality of a transmission..
  246. Finding the optimal final drive ratio
  247. tranmission seized after rehaul....help
  248. No 5th gear in high RPM's
  249. Heat spots on twin disc???
  250. Swap AUTO transmission case or is it ruined??**PICS**
