- RWD j series tranny
- HELP: How can i apply gear oil into manual transmission?
- Changing Snychros & A LSD in a YS1 Trans
- Hydro To Cable Tranny ?s
- j series adapter plates
- Crack in clutch case
- d series shift forks
- del sol clutch ???HELP
- B16 Transmission Help
- Differentials
- 2nd gear grind...what else?
- first gen LSD b16a tran problem...
- Lockup solenoid function
- Fidanza Axles D-Series Anyone Used Them?
- which tranny for b16
- Bottom of Countershaft 1st gear rubs against Ring gear, is this normal?
- 4.4 and 4.78 fd
- 3 broken teeth on the countershaft FD gear, what could cause it to break??
- D16 Diff bearing Ques
- Need Help: ITR LSD into B16 tranny...
- how to tell what kind of trans I have
- clutch help
- Flywheel + Clutch combo for DD
- What is transmission part called where the left passenger axle goes through??
- Help Please: front cv shaft / axle question
- Please Identify LSD Differential
- Kaaz lsd
- Is there such a thing as a built Honda Auto Trans? If so who builds em?!
- JDM DC5 4-5-6th gears part# ?
- 91 LS trans case problem
- what you think about this clutch
- Help m-f gsr tranny has a bad 5th gear grind! need help with instal!
- ITR Trans Issue
- LSD Motorsport clutches????
- cant get the countershaft c clip seated!
- [HELP] Difference between Twin B-Series Comp. Clutches
- Redline MTL, Honda MTF, or GM/ACDelco Synchromesh Fluid?
- Will a TL type S transmission work in regular TL?
- Low milage trannys from Japan....
- Steering wheel jerks to the right crazily.
- New trans seems hard to turn
- Release bearing (TOB) not releasing from fingers (Searched and searched)
- Honda MTF Flush and Clunking
- ITR diff rubbing on install
- is my s1 tranny jdm??
- Tranny Codes?
- Clutch Cable Question (searched)
- best place to buy lsd
- inputshaft movement.
- what can cause 2nd gear to grind at high rpm?
- Prelude tranny interchangeability
- Diffirential moving normal?
- MFactory LSD Torque Specs
- passenger axle keeps popping out, has any1 had this problem b4
- Obx and innovative axles?
- ITR trans shift feels crunchy
- Clutch petal goes to the floor, tried bleeding but the fluid in the reservoir wont go
- did my diff lock up?
- Tranny woes!
- b16 trans w Type R lsd...Questions....
- Syncro issure? or motor mount? HELP
- Dual bend V. straight SS?
- Needing a clutch for an 07 Si
- Half-shaft Bearing B-series
- diff bearing falure?
- Car wont go into reverse
- Seeking Help/Advice on Spoon LSD Transmission
- h23a tansmission bolt to f22b2
- Trans isn't shifting smoothly
- k20z1 trans problems
- 98 HX tranny problems
- syncros: oem vs gear-x vs gearspeed??
- 1999 Accord V6 AT Woes
- what could have caused this? damage
- Aqua; 4 B series LSDs?
- S1 trans making a whinning noise in gear
- good clutch for DD
- Swapping from LS to GSR FD
- new clutch burning?
- 93 si tranny
- mfactory 3rd 4th 5th
- act clutch noise?
- How to Identify a B series trans with no tag
- B Series Transmission Woes
- Problem with 5-speed Back-up light switch
- lsd doesnt seem to work
- aim me clutch problems b16
- tranny swap
- Act heavy duty pp with stock clutch disk?
- D16 Trans ques
- Snap ring - Broken in 3 pieces
- LS 5th gear and GSR 5th gear, also slider
- Input shaft bearing or throwout bearing
- Question about D16Z6 tranny and how to get new tranny fluid in.
- s80 ITR trany pops out 5th gear.
- 95 GSR transmission Y80 mainshaft question.
- Axel carnage 2 passes, 2 axels
- ratio and meshing issues w/ hybrid B trans
- Speed Sensor Calibration H22A Automatic
- 2001 Accord Automatic Transmission buzzes after motor swap
- How to tell what type of diff bearing for JDM GSR tranny (YSK-1) ???
- what is this?
- B16 internals into LS??
- wtb civic torque converter automatic
- Violent Jerking
- synchros
- twin disc problems
- won't go into 2nd
- Slipping while driving
- Transmission Cooler built in the radiator???
- K20a trans ratios
- Question for Mista Bone or Aquafina
- tranny expert help!
- torque measurement for 91 civic tranny
- Countershaft question!
- HELP!!! Cable ys1 trans questions about LSD
- Front Axles broke twice TODAY!
- 97 Civic EX 5spd noises.....
- 5spd popping out of 2nd
- 97 Civic DX shifts hard at slow speeds
- stuck in gear( need help)
- s80 tranny
- Need Help
- car studdering
- DSS 2.9 problems
- gsr and ls tranny specs
- NEED ADVICE Please look.
- MOD: Delete
- 4.785 98+ Spec ITR FD
- MFactory shift bushings vs Energy poly
- cable main,counter,& final into hydro LS case?
- Reverse Grind (cable B)
- Shifter question please
- H22A tranny question.,
- K-series engine/ what transmission for rear wheel drive
- 1998 GSR 5 speed transmission
- Q for Honda bull
- put a b16 tranny on a gsr
- how much power stoch gsr trans
- Loose flywheel ring gear?
- transmission question. h22/f22
- Will not shift into lower gear at higher speeds.
- Transmission questions (lsd, axles, size)
- Opinion on Gear-X FD. Questions about quality...
- automatic fluid change?
- D16z6 w/ Stock D15B Tranny Concerns??
- New Slave, basiclly new MC, bled 3 times, still nothing..help
- Just checking for LSD fit in LS
- Can someone transmission smart explain this part to me?
- need new clutch and eventually going turbo..should i go straight for a STAGE 3/4??
- Shift bushings for B&M buzzzzzz
- Clutch became very stiff towards the bottom.
- stock clutch on a stage 4 pressure plate?
- hard to get into 1st and reverse.
- Tranny swap?
- tranny code
- Busted tranny case want to swap B16 internals into LS...Sleeving?
- has any one ever done this type of setup before??
- Can you put a B-series Pressure Plate on a D-series engine
- Hard to shift into 1st and Rev. Clutch?
- F1 Racing Stage 3 clutch?
- HELP! G2 Integra Extension Rod Bolt ?????
- NEED HELP WITH MY LSD B16 GEARBOX(JAMAICA)!!!!!!!!!!!!!!!!
- Omnipower M/C VS OEM....help!
- more obx runout issues
- b16a2 stock axles?
- Trans parts question need help.....
- Whats wrong with this transmission?
- Is My DC2 Tranny F$#@ed Up..
- 04 Accord Ex V6 A/T Transmission Question
- Hard shifting
- Handcuff?
- Clutch Master/Slave Cylinder Failure?
- 05 honda accord
- cant get into 3rd and 5th at all!! help
- 90 Ex Accord With A F23A1 Vtec
- Cv axles problem
- Free ride in my VTEC Mini for answers
- notchy shifting gsr teg
- New Clutch for a B20VTEC, stock GSR tranny HELP!
- S21 TRANNY QUESTION?
- Won't go into gear while car is running
- what other Honda trans has a triple cone countershaft 1st??
- 2nd gear lockout on downshift???
- clutch problem
- LSD
- Is the notched ring on this axle for ABS?
- Trans leaking really bad in front of clutch...
- for those you you with k24a2's
- Clutch ProblemO Hard Pedal (nudes of my wife)
- broken gsr casing
- eg and db shift linkage the same/different
- ITR lsd in ls trans!?!
- where to buy honda trans parts?
- B series syncro question???
- ISB seal question...
- GSR Hyrdo into DA ??? conversion help
- new clutch installation
- LSD noise
- Transmission Leaking
- Broken Differential. Why?.... pics inside
- Slight third gear grind
- Need help about building a GSR tranny With b16 1st & 2nd with ls 5th.
- Loud Squeal/whine when 5th gear is engaged
- axles
- tranny squeal! what is it???
- Is My Type R LSD Broken?
- synchro swap?
- '01 GS-R Transmission | Does Not Engage 1st or 2nd Gear
- Mixing Fluid
- Need help with D16Z6 Tranny (Pics)
- What Cable to use
- OK so my 92-93 GSR tranny turned out to be a LS tranny RIGHT???
- Help, Don't know torque amount for flywheel bolts, D16z6...
- Competition Clutch- Series 2300...over all experience?
- 98 accord v6 trannsmission help please.
- Aluminum flywheel
- LSD question
- 90si tranny in 98?
- HELP!!!!!
- I dont know if i have lsd or not?
- Tightened bolts and locked up gears???
- labor for clutch install?
- Can anything be improvised as a clutch alignment tool?
- Changing MTF on d16z6 tranny
- Hard to shift when raining
- heres a question for you...tranny problem
- Transmission Release Bearing (Help)
- clutch and flywheel opinions-cv boot
- Une piece LSD?
- Need a TCU for a '91 Accord (HELP!!)
- s1?
- Flywheel/Clutch quick question...
- How do you identify gears by themselves?
- 03 ex painfully slow shifts?
- hard to get in gear
- Quick Question: Currently installing ITR FD in YS1 case
- Axle install went wrong.
- Pass. axle keeps popping out after raising the car
- Clutch not engaging after tranny swap (already searched)
- what tranny is this?
- transmission choice
- Y1 b16a non lsd tranny pop out
- 1986 accord dx trans problems
- Helpppp axle keeps poping out of tranny
- 2004 accord clutch slipping
- ECU for d16z6 manual trans conversion
- What oil to use when running clutch type LSD
- trans bearing
- need NTN number for newer gsr/itr diff bearing
